5th November 2017, 22:11 | #1221 | Link | |
1. Uninstall your old driver 2. Start the 340.52 installer and select "Custom". 3. De-select everything except the display driver 4. Install
Groucho's Avisynth Stuff |
5th November 2017, 22:32 | #1222 | Link |
Groucho,
Yup, that's what I did. I did think of unchecking all that other stuff, because I never use it. When I get back to the XP boot drive, I'll do as you suggest. Back to my main problem. I've made real progress. I've switched over to the Win7 64-bit boot drive and after a lot of stupidity (forgot to copy the MT AVISynth+ version after installation of the old 2014 version), I have AVISynth+ running and KNLMeansCL is working without crashing. I've tuned the parameters and like the results. However ... My one remaining problem is that I can't get MT to work. I have all the SetMT calls in an AVSI file that is loading at startup, and I have the Prefetch(4) at the end of the script. I've used MT many times in the month since I first installed AVISynth+ on my XP partition, so I'm getting somewhat familiar with the syntax. I'm not sure what is going on. I only get 2 fps without it (I have to use d=3 to get decent noise reduction on this 1981 VHS dub of someone's wedding inside a dark church, which I've brightened to within an inch of its life). The result is remarkably good, far better than I've seen with the old fft3dfilter, MDegrain2, and other spatial, temporal, and fft denoisers I've used. But because of the multiple frames that must be processed, it is pretty slow. So, I am now really close and all I have to do is figure out how to speed it up. I've tried the script with and without the "requestlinear" statement. I don't think it is needed in my script. Here's the script I'm using. For troubleshooting, I've temporarily removed the MtModes.avsi file and since there is only one plugin, I'm setting the MT mode explicitly within the script. [edit]I just did a quick test, and MT is not working for any script. So, it is not this script and it is not KNLMeansCL. [/end edit] Code:
loadPlugin("E:\Documents\My Videos\AVISynth\AVISynth Plugins\plugins\KNLMeansCL.dll") setmemorymax(1200) SetFilterMTMode("knlmeanscl", MT_SERIALIZED, true) d_input=3 #number of past/future frames default=1; 0=1 frame; 1=3 frames a_input=1 #radius of search window; default=2; 0=1 pixel; 1=9 pixels s_input=4 #radius of similarity; default=4 h_input=10.0 #filter strength wmode_input=0 #weighting function; default=0 source=AVISource("E:\fs.avi").KillAudio().Requestlinear() separatefields(source) even=selecteven() odd=selectodd() den_even = KNLMeansCL(even,d=d_input,a=a_input,s=s_input,h=h_input,wmode=wmode_input) del_odd = KNLMeansCL(odd, d=d_input,a=a_input,s=s_input,h=h_input,wmode=wmode_input) interleave(den_even,del_odd) output=weave() return output #Enable MT Prefetch(5) Last edited by johnmeyer; 5th November 2017 at 22:37. |
5th November 2017, 22:40 | #1223 | Link |
Try placing the Prefetch call before "return output" (everything after a return statement is ignored).
Groucho's Avisynth Stuff Last edited by Groucho2004; 6th November 2017 at 01:18. |
6th November 2017, 00:36 | #1224 | Link | |
"You enable MT by placing a single call to Prefetch(X) at the *end* of your script, where X is the number of threads to use." I didn't put the asterisks on either side of "end," so whoever wrote that really want to emphasize, I thought, that it should be the very last statement in the script, period. I'll try it when I get back to the Win7 boot partition and let you know (I'm back into the XP partition to try your suggestion about how to update the GPU driver). Thanks! Last edited by johnmeyer; 6th November 2017 at 00:37. Reason: added thanks for the GPU driver suggestion |
6th November 2017, 01:28 | #1225 | Link |
I followed the directions exactly for installing just the nVidia driver, but the installatio program gave me the same error message. I'm not going to waste anymore of either my time, or anyone elses' time on this. While I still use XP a lot, it obviously isn't supported any more, not just by MS, but by any other company. Add to that the general incompetence of video graphic software programmers (I can't believe that the bugs and installation nonsense that started back in the 1980s is still going on today), and its a quagmire not worth entering.
However, thanks once again for the help. No to go back to the Win7 64-bit and see if I can get MT to work. |
6th November 2017, 01:57 | #1226 | Link |
Moving prefetch to the line before the return statement did not do anything.
I'm going to take a break and see if I can figure out the error in my ways ... [edit]Actually, I'm going to give up trying to get it to use MT. I just read through a huge portion of this thread, especially the long discussion between Groucho and MysteryX about using MT with this filter, with the KNLMeansCL author also making posts. My take from that is that MT may not even be possible with this filter, and at best, it is only going to provide a few percent improvement, not a 2x or 3x speed-up. Last edited by johnmeyer; 6th November 2017 at 02:15. |
6th November 2017, 02:19 | #1227 | Link | |
The script you posted above uses very few CPU cycles so depending on how you measured you may not have noticed a difference.
6th November 2017, 03:33 | #1228 | Link |
I viewed the AVISynth script output in VirtualDub. I used VD's "Run Video Analysis Pass" and watched the fps readout. I then moved the Prefetch call to a place both before and after the return statement. There was 0.00% difference: I got 2.04 fps for 30 seconds in both cases (I aborted after that amount of time). I also tried different thread settings from 2 all the way up to 8 (my computer's number of cores). No difference.
6th November 2017, 08:14 | #1229 | Link | |
"Prefetch(5)" placed after "return output": Code:
FPS (min | max | average): 22.66 | 23.51 | 23.41 Memory usage (phys | virt): 79 | 97 MiB Thread count: 23 CPU usage (average): 25% Code:
FPS (min | max | average): 22.65 | 23.52 | 23.41 Memory usage (phys | virt): 80 | 97 MiB Thread count: 28 CPU usage (average): 25% If you use a filter that's heavy on the CPU such as MDegrain you will see a difference in speed and CPU usage.
6th November 2017, 08:19 | #1230 | Link | |
6th November 2017, 08:31 | #1231 | Link |
Really, this is a topic that we have really talked about many times.
github.com |
6th November 2017, 10:09 | #1232 | Link | |
Excessively jovial fellow
You can definitely multithread KNLMeansCL by running multiple instances of it (MT_MULTI_INSTANCE, and I hope you have a ton of RAM) but the main benefit of this isn't that it improves the performance of KNLMeansCL itself, but that it allows filters upstream of it to run in parallel. Avisynth's parallelism is brain damaged, news at 11. Last edited by TheFluff; 6th November 2017 at 10:13. |
6th November 2017, 21:01 | #1233 | Link | |
Your idea of MT_MULTI_INSTANCE is very intriguing. I didn't know about that. I'll pursue that and see what happens. I do happen to have a "ton of RAM," although whether AVISynth+ running KNLMeansCL will use it, or not, I don't know. It should be fun to try it and find out. Thanks! |
8th November 2017, 19:17 | #1234 | Link |
i'd like to share a little story in case you got the same problem.
so lately my knlmeanscl didn't work. it always threw some missing dependency errors. i tried everything mostly reinstalling ms vs runtimes, but i couldn't figure out the problem. my graphics driver was up to date - that's what i thought. here's what actually happened: i got a new Win 10 Upgrade lately. what i didn't expect/know is that it replaces my graphics driver with a worse one - which doesn't have opencl support(?) completely reinstalling the nvidia driver fixed everything and KNLMeansCL is working great again |
8th November 2017, 21:59 | #1235 | Link | |
As for having something replaced by a background upgrade that I don't authorize, I turn off ALL upgrades for everything, including Windows. Neither my Win XP or Win7 installation has been updated in seven years. As a result, I never have had the pleasure of turning on the computer, only to find that it doesn't behave like it did yesterday. As a result, I get a lot of work done because I don't spend any time in the "care and feeding" of my computer. I partition my hard drives so that only the O/S and programs are on the boot partition. I can do an image backup in less than five minutes. So, if something bad does happen (people always worry that I'll get a virus or something like that, especially since I don't run any anti-virus programs), I can restore the computer in less than ten minutes. I've had to do this a few times when I've installed a new program that screws things up. So: no background updates; no anti-virus software; no background programs (task manager only lists three processes in XP after I boot); and partition the boot drive. I highly recommend this to anyone who wants a fast, trouble-free computer. |
15th November 2017, 22:50 | #1236 | Link |
The result is different, which one is correct?
SetMemoryMax(3000) ImageSource("1.png", end=0).Dither_convert_rgb_to_yuv(lsb=true,output="YV12").DitherPost(mode=6) ConvertBits(bits=16) KNLMeansCL(d=2, a=4, s=4, h=0.4, channels="Y", stacked=false, device_type="GPU") ConvertToStacked().DitherPost(mode=6, ampo=1) Code:
SetMemoryMax(3000) ImageSource("1.png", end=0).Dither_convert_rgb_to_yuv(lsb=true,output="YV12").DitherPost(mode=6) ConvertBits(bits=16) ConvertToStacked() KNLMeansCL(d=2, a=4, s=4, h=0.4, channels="Y", stacked=true, device_type="GPU") DitherPost(mode=6, ampo=1) |
22nd November 2017, 14:33 | #1238 | Link | |
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
I realy would like to test this filter. Unfortunately I'm getting the following error message:
I'm on Win10, opencl.dll is there, both in system32 and in syswow64. Any suggestions please? Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
22nd November 2017, 14:42 | #1239 | Link | |
https://www.geforce.com/hardware/not...specifications
22nd November 2017, 14:52 | #1240 | Link | |
