7th July 2021, 20:10 | #61701 | Link | |
it will break at one point if it is a new video codec a new windows version or just no new software for 32 bit (very reasonable if you ask me) it will happen. and it doesn't really matter what nvidia supports on the driver it will not allow everything with 32 bit program if you would use copyback for 8k it would just die. |
7th July 2021, 20:35 | #61702 | Link |
In other words, it still works now for all the needs of people who use it, and for the near future (I don't care at all about 8K either, and my media center front end even is still 32-bit only).
With a little hope, when something finally breaks ReClock there will be some way in GPU drivers to create custom refresh rates with very precise clocks with the help of HDMI VRR and we won't need to find an alternative.
7th July 2021, 23:06 | #61704 | Link | |
Today my setup can decode 8K. The driver, today, can. And it works with 32 bit software. Unless I change my setup, nothing is gonna change that. New video codec? We've kept H264 for the whole BluRay generation. We'll keep HEVC for the whole 4K generation. 8K on physical media is so far from becoming reality that I don't know if it'll ever happen. By then, maybe, things might get more problematic. But that will be true for madVR x64 as well, since unless you resort to ripped content from the scene, there will be no way to playback stuff streamed in 8K through madVR. And if you go the ripped content way... pretty sure HEVC will still happen for a very long time. Reclock is a temporary solution until I can get some answers as to why I can't make 10 bit working on custom resolutions. But that doesn't detract from the fact that Reclock works perfectly to this day and, for reasons I've explained, for quite a long time in the future. Say it doesn't work in Windows 11... there's another four years, minimum, of guaranteed updates for 10. After that, for a dedicated HTPC machine, it's not too hard to lockdown the OS from a security point of view, if you limit yourself to media viewing.
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM |
7th July 2021, 23:44 | #61705 | Link |
you know that pretty much every couple years youtube adds a better codec which is now AV1 which your cards also supports BTW.
and if your device can do 8k decoding try copyback may actually work. because if the driver can do something it doesn't mean it will work with a 32 bit program that's simply not how it works. an 8k image is 96 mb if it is 4:2:0 for 4:4:4 we talk about 192 mb the default queue size of madVR is 16 so madVR and other programs better don't use any RAM at all or subtitles. of cause you can just disconnect your device from the inet and leave it as it is. doubly vision update in a driver could be more than enough to kill 32 bit. BTW. you can right now stream 8K from youtube in madVR not relevant. |
8th July 2021, 08:01 | #61706 | Link | |
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th July 2021 at 08:09. |
8th July 2021, 13:15 | #61707 | Link |
That's fine. As mentioned I don't care about 8K now and for the next few years. I did not try 8K because I don't have an 8K screen and I don't think I will own one for the next 5-7 years. Also, to each his own, but considering content on YouTube, it's not as if I would tear my hair out to be able to watch that through madVR. More power to those that care, obviously. Dolby Vision would be worth it, I agree.
Also, considering how well I see Reclock performing, it's a shame it's not been updated for 64 bit.
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM Last edited by ashlar42; 8th July 2021 at 13:17. |
8th July 2021, 13:27 | #61708 | Link |
anyone else having issues with seeking movies now after the latest update? build 1083 I've repeating green artifacts and repeating images. using potplayer with lavfilers and madvr with 6900xt 21.6.1. the windows 10 movie player works fine
seems Lav Video Filters is causing the issue. it only happens with 8bit movies not HDR ones.... Last edited by x7007; 8th July 2021 at 14:18. |
8th July 2021, 14:28 | #61709 | Link |
If any of you Reclock users have any programming experience, then consider the possibility of implementing its functionality in MPC-HC. Audio resampling ability is already present in the internal audio renderer. So the only main thing that is missing is adjusting the playback rate to compensate for the small difference in refreshrate vs video framerate.
MPC-HC 2.2.1 |
8th July 2021, 14:40 | #61710 | Link |
that's easy if i would just do a normal c++ project to do some math but just looking at sanear and i'm simply not qualified.
in the end it is just calculating the drift let say +0.1 % (reclock even shows you the numbers). to slow the audio down by 0.1 % i take 47952 samples and resample them to 48000. speed up 48048 to 48000. want to be more accurate super sample. else do some float point stuff. extremely simple getting the timing information and understanding the data type or even possible different data types it a different story. |
8th July 2021, 21:40 | #61711 | Link | |
- only d3d11 should be check in madvr - set 10 and higher under device in madvr - we only get 10bit in fullscreen - here when I set custom res via CRU, there's a 2nd id information tab under devices, the first right one every necessary info but that is disabled, the 2nd only says 8bit and that's the active - sometimes it stops working (when windows does something with the vga), a reboot helps
9th July 2021, 10:13 | #61712 | Link |
off topic - I know its unlikely MADVR will get Dolby vision support but are there any players or renderers that work yet that anyone knows of?
9th July 2021, 13:40 | #61713 | Link | |
While the default resolutions show as RGB 10b 4L10, the custom one is shown as RGB 10b TM. But everything is good, 10 bit and all (2160p24/23.976 does not need HDMI 2.1). Unfortunately I alternate between the AVR 5.1 and Corsair Orbit Cloud S headphones (same as Audeze Mobius, best virtual surround I've heard so far and I've tried many). Which has internal DAC/clock/everything (basically they work as an external soundcard). Timings should be different and there's no easy way to alternate (I know CRU can export an EXE but it's really too cumbersome to go that way). As such I'll remain with Reclock (as Kodi's sync to display is crashing for me and madVR debanding during fadeouts and fadeins is quite better).
9th July 2021, 13:43 | #61714 | Link | |
Sent from my SM-G998U1 using Tapatalk
9th July 2021, 14:35 | #61715 | Link |
you'd think MADSHI would have implemented DV by now if he's gunning for the high end market, a few quid for a DV license per unit isnt really going to add much to an already unaffordable unit for 99.99% of us
9th July 2021, 14:42 | #61716 | Link |
I expect sooner or later Envy will go that route. But maybe they've tried to get the license and there are obstacles, I don't know... to date, there is no way to get Dolby Vision through a Nvidia GPU in a PC environment. But Shield does it. I suppose it depends on how locked down the environment is.
10th July 2021, 06:51 | #61718 | Link |
Hi folk, could I get help with two things?
1) My MadVR version is 92.17. I need to reinstall Windows. Should I stick with 92.17 or go to one of these new trial versions I just read about? I watch OTA TV standard definition (old TV shows) 1080P TV and 4K movies on a 4K projector RTX 2060 Super. Is there a settings guide to follow like I used for 92.17? 2) I recently started watching a lot of old school TV shows on broadcast TV via my HdHomeRun + Antenna. Are there any suggested MadVR tweaks for cleaning up the crappy image quality? MeTV and Antenna TV are the two channels I mostly watch. Shows like Gunsmoke, Emergency, MASH, Barney Miller, etc. |
10th July 2021, 13:43 | #61719 | Link |
I've had a look. Too mumbo jumbo for my tastes. I understand companies need marketing. But in this case all I see is marketing. After 15 minutes trying to understand how they would work with a PC for 5.1 output virtualization I've had enough and got bored.
If you wanna talk about it, let's use PMs, this is off topic here.
10th July 2021, 19:09 | #61720 | Link | |
