9th December 2020, 17:29 | #341 | Link |
Okay, so it's back to having to specify the whole GOP structure. I can reproduce the same error when removing all the Frame lines.
In config files, it refers to this: https://vcgit.hhi.fraunhofer.de/jvet...vtm.cfg#L20-51 I don't know if they can be specified by command line |
9th December 2020, 22:25 | #342 | Link | ||
You should use the vvenc and vvdec with multithread versions. Quote:
11th December 2020, 10:27 | #344 | Link |
https://github.com/fraunhoferhhi/vvdec
https://github.com/fraunhoferhhi/vvenc plus my fix I have added codecs and compilation issues in my threads |
11th December 2020, 22:52 | #345 | Link | |
Broadcast Encoder
Last question: from what I see it's still uncompressed .yuv input file only, so I assume a -f yuv4mpegpipe - | from FFMpeg wouldn't work, right? |
13th December 2020, 09:37 | #347 | Link | |
Artem S. Tashkinov
Sharp meanwhile has announced a real time decoder for up to 8K VVC streams: https://global.sharp/corporate/news/201204-a.html I've tried to dig deeper but it looks like the corporation is averse to open source ;-) |
13th December 2020, 10:37 | #348 | Link |
Artem S. Tashkinov
Speaking of the reference encoder, vvcenc, it's already quite fast without tons of hand-written optimizations/assembly: https://www.streamingmedia.com/Artic...ow-144235.aspx
Looks like when it gets properly optimized it'll be a lot faster than aomenc (though now the reference AV1 encoder is SVT-AV1 which I haven't yet accepted as its quality is quite poor IMO). |
14th December 2020, 21:51 | #349 | Link | |
Huba Huba
Afafik av1 ist a "simply try everything" encoder, because patented mpeg fast prediction tools aren't included. So even if vvc has added complexity vs hevc vs avc, it should be still more tuned for fast encoding - while av1 is designed to avoid patents and tuned for either "quality doesn't matter" video calls or "cost doesn't matter' encoding by streaming providers.
"The innocent have nothing to fear" :stupid: |
17th December 2020, 04:48 | #350 | Link | |
Angel of Night
AV1 threw out lots of baby with the bathwater in trying for a total do-over of codec development, instead of just building off of VP9, because it ended up so different. (Not the VP9 was any peach.) Other AV1 implementations have tons of freedom to do much better, which is both better and unfortunate. A future AV2 will have the benefit of whatever portion of aom's code and optimizations are reusable. It's not like AV1 finalized pie in the sky proposals, though; just like every MPEG process, there was a painful period of cutting them down to what met a size and performance budget, and that's a huge part of why the final spec was so delayed. But also, AV1 didn't benefit from the large number of experienced chip designers who weigh in on all MPEG proposals regarding baking it into transistor budgets. C'est la vie. |
17th December 2020, 13:12 | #351 | Link | |
1. lots of patents will have expired. 2. sisvel published a list of patents they claim that av1 violates therefore av2 can be developed to make sure that those aren't violated. 3. unifiedpatents.com have been successfully invalidating some av1 and hevc patents which means that some of those patents will be able to be used. I do hope that AV2 isn't ratified within 5yrs of AV1 though, otherwise it might make a difficult for AV1 to become popular. Last edited by hajj_3; 20th December 2020 at 01:24. |
6th January 2021, 22:07 | #352 | Link |
Untested info
No video player can show this. Full compatibility can be expected in a year's time! mp4box.exe -new -info -add import.vvc output.mp4 Codec VVC in conteiner mp4. Track Importing HEVC - Width 1280 Height 720 FPS 25000/1000 SAR 0/0 VVC Import results: 55 samples (144 NALUs) - 55 SEI - 3 IDR VVC Stream uses forward prediction - stream CTS offset: 55 frames VVC Max NALU size is 63768 - stream could be optimized by setting nal_length=2 # Movie Info - 1 track - TimeScale 600 Duration 00:00:00.000 (recomputed 00:00:04.240) Fragmented: no Major Brand iso4 - version 1 - compatible brands: iso4 Created: GMT Wed Jan 6 21:02:22 2021 # Track 1 Info - ID 1 - TimeScale 25000 Media Duration 00:00:00.000 (recomputed 00:00:02.200) Track has 1 edit lists: track duration is 00:00:04.240 Media Info: Language "Undetermined (und)" - Type "vide:vvc1" - 55 samples Visual Sample Entry Info: width=1280 height=720 (depth=24 bits) Visual Track layout: x=0 y=0 width=1280 height=720 VVC Video - Visual Size 1280 x 720 VVC Info: Profile 1 @ Level 64 - Chroma Format YUV 4:2:0 NAL Unit length bits: 32 Parameter Sets: 1 SPS 1 PPS Bit Depth 8 - 5 temporal layers SPS#1 hash: CD7EE785B89AF3327C233B50CA28C755D751EAFA PPS#1 hash: FF54700DA8418365C4BB4330DEE1EF986AA37AAC RFC6381 Codec Parameters: vvc1.1.L64 Average GOP length: 27 samples Max sample duration: 0 / 25000 0.500 secs Interleaving |
7th January 2021, 12:30 | #353 | Link |
Broadcast Encoder
Sweet, so it's possible to mux in mp4 as well and not just mkv. Good.
Apart from the container, is there any player at all (beside the DecoderApp.exe) that can play VVC files? And last but not least: any news from Multicoreware about x266? |
9th January 2021, 11:18 | #357 | Link |
What is this talking about?
GPAC did what it could. I exerted pressure. There aren't resources for modifying new codecs in GPAC jpeg2000, avif, heif. I remind you that in jpeg.org propaganda heif photos can contain and convert to HTJPEG2000. It is fantasy right now. There are no funds or there are paid programs somewhere. https://jpeg.org/jpeg2000/index.html JPEGXS will not come out free this year. It was supposed to be the successor to jpeg2000. https://www.iis.fraunhofer.de/en/ff/...on/jpegxs.html https://www.intopix.com/ffmpeg Google codecs are for google and the rest don't count. The rest as competition will not support google. The mpeg5 container had new features mainly anti-piracy in the network under vvc, evc codecs. The strange thing is we have mp4 and matroska from vvc. SONY is sure to be happy as he fought with matroska. https://github.com/MPEGGroup/isobmff The creators of m-ad-s laughed at me with the answer. Write better, create your own library, but they advertise google codec aom. https://github.com/m-ab-s/media-auto...commits/master Last edited by Jamaika; 9th January 2021 at 11:25. |
9th January 2021, 11:28 | #358 | Link |
x266 Open-Source Encoder for VVC by MulticoreWare
https://ottverse.com/x266-vvc-multic...ource-encoder/ If you have any questions for the MulticoreWare team, please get in touch with Shivakumar Narayanan at x266@multicorewareinc.com. Last edited by Jamaika; 9th January 2021 at 11:35. |
9th January 2021, 11:33 | #359 | Link |
Untested
Main Features Spliting video by scenes for parallel encoding because AV1 encoders are currently not good at multithreading, encoding is limited to single or couple of threads at the same time. PySceneDetect used for spliting video by scenes and running multiple encoders. Fastest way to encode AV1 without losing quality, as fast as many CPU cores you have :). Target Quality mode. Targeting end result reference visual quality. VMAF used as substructure Resuming encoding without loss of encoded progress. Simple and clean console look. Automatic detection of the number of workers the host can handle. Building encoding queue with bigger files first, minimizing waiting for the last scene to encode. Both video and audio transcoding with FFmpeg. Logging of progress of all encoders. Install Prerequisites: Install Python3 When installing under Windows, select the option add Python to PATH in the installer Install FFmpeg Recommended to install vapoursynth with lsmash for faster and better processing Encoder of choice: Install AOMENC Install rav1e Install SVT-AV1 Install SVT-VP9 Install vpx VP9, VP8 encoding Install VTM VVC encoding test model Optional : Vapoursynth ffms2 lsmash mkvmerge https://github.com/master-of-zen/Av1an |
9th January 2021, 13:40 | #360 | Link | ||
Broadcast Encoder
