7th November 2016, 22:47 | #25202 | Link |
@jdobbs and Mark_Venture
quick encode of Ninja Turtle movie All is good Code:
[11/07/16] BD Rebuilder v0.50.18 [16:12:42] Source: TMNT_2_OUT_OF_THE_SHADOWS_00800 - Input BD size: 29.28 GB - Approximate total content: [01:52:07.595] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - AVS Filtering is enabled - Mode: MKV, CRF, Intact Audio - Quality: Good (Very Fast) - X264 Tweak(s) enabled - Decoding/Frame serving: DGDecNV [4-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [16:12:42] PHASE ONE, Encoding - [16:12:42] Processing: VID_00800 (1 of 1) - [16:12:42] Extracting A/V streams [VID_00800] - [16:17:15] Reencoding video [VID_00800] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 161,301 frames - [16:17:15] Reencoding: VID_00800, Pass 1 of 1 - [16:38:43] Video Encode complete - [16:38:43] Processing audio tracks - Track 4352 (eng): Keeping original audio [16:38:43]PHASE ONE complete [16:38:43]PHASE TWO - Rebuild Started - [16:38:43] Building ALTERNATE OUTPUT Structure [16:43:08] - Encode and Rebuild complete - WORKFILES folder removed. [16:43:09] JOB: TMNT_2_OUT_OF_THE_SHADOWS finished. Code:
[Status] LABEL=TMNT_2_OUT_OF_THE_SHADOWS VERSION=v0.50.18 SOURCE_SIZE=31443320832 SOURCE_VIDEO_SIZE=31443320832 TARGET_SIZE=24641536000 REDUCTION=.783681091817828 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=3 USE_LAVF=0 INSTANCES=4 DGDECNV=-1 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00800] AUDIO=10000 PGS=11000 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24641536000 SPLITS=4 NSIZE=0 FLINK=0 MLINK=0 |
8th November 2016, 03:47 | #25204 | Link | |
Now I guess its time to figure out what is going wrong with my system... I just booted to my win10 partition.. and with 50.18, same INI, etc... and TMNT_2 worked.. So its got to be something with my Win 7 setup. I guess I'll completely blow away my BDRB folder, and start it over. |
8th November 2016, 06:56 | #25205 | Link | |
DAMN! That is awesome that we now FINALLY have a way to send JD something decent. Yeah, I get almost bloody EVERYTHING from Amazon, so that is a frigg'n great idea! |
9th November 2016, 15:55 | #25206 | Link | |
10th November 2016, 16:00 | #25207 | Link |
Well.. No, but I got it working...
First I made a fresh new folder, unzipped 50.18 to it... When I started BDRB for the first time I got told about LAV not being configured, did I want to fix it? I said yes, It errored saying something like SetACL_x64 wasn't compatible with this version of Win 7. I got past that by copying the SetACL_x64 from my 50.17 folder. Trying an encode, it failed nearly immediately saying "Failed to retrieve audio, aborted." Again, 50.17 continued to perform just fine. I verified FFDshow settings per the OP, even made sure what versions I was running, etc. Still 50.18 failed, but 50.17 continued to work. Finally, I deleted all folders of 50.18 I made while trying to trouble shoot this. I unzipped again into a new "new folder." Again on first launch I got the LAV not configured.. I answered yes... and it didn't error. I manually setup my options and tried again with TMNT2, this time it worked. While I've had issues upgrading in the past by just unzipping the new version on top of the old, in this case, I did that weeks ago (ok, month and a half?) and had been working fine. So I'm not sure why all of a sudden I ran into problems when I hadn't changed anything on BD-RB. And other than updates to windows, DVDFab Passkey, Nvidia Geforce drivers, and iTunes, I haven't changed anything on my Win 7 install or BD-Rebuilder since the end of September. |
10th November 2016, 16:37 | #25208 | Link | |
http://www.videohelp.com/software/Pr...Filter-Tweaker |
12th November 2016, 12:10 | #25209 | Link |
My OS is Win 7 64bit with NVIDIA GeForce GTX 750 graphics card. When shrinking BD movies I always use the "Highest (very slow)" encoder setting. This worked just fine with all versions of BD RB and on average took 3 to 4 hours to complete (movie only). For some reason with the lates build of BD RB (0.50.18) the processing time doubled. It now takes overnight to do the same job. I tried clean install of everything, tried it on freshly installed OS, tried with and without LAV filters and Matroska splitter installed but it still takes more than 8 hours to complete a job that would previously take 50% less time. Is there a known issue that I need to be aware of and also is there a solution that would reduce the Reencoding time to previous levels?
12th November 2016, 15:42 | #25210 | Link | |
12th November 2016, 16:13 | #25211 | Link | |
12th November 2016, 19:34 | #25213 | Link |
quicktime codec support
Will BD-RB support quicktime codecs to import? My projects include DNxHD 1080p 10-bit (50fps progressive) 4:2:2 output files coming directly from the editor program. I would like to import and reencode them into mkv format using the power of x264 in BD-RB.
Thank you for the help. |
12th November 2016, 19:47 | #25214 | Link | |
The source would have to be in a supported container as well. Last edited by jdobbs; 12th November 2016 at 19:54. |
13th November 2016, 00:23 | #25216 | Link |
The boldfaced setting above is your problem. Select DirectshowSource instead. If you can't select it, then you're not configured properly -- go back to the instructions in the first post of this thread and uninstall/reinstall.
13th November 2016, 03:40 | #25217 | Link | |
But, ffmpeg has support for VC-3, so you should be able to directly use ffmpeg to recode to H.264. So, take a look at ffmpeg. |
13th November 2016, 10:18 | #25218 | Link |
Did as you suggested: clean install and selected DirectshowSource. Unfortunatelly it is still taking almost 8 hrs to process a movie that would previously take no more than 4 hrs. Thank you for the time to try and help.
13th November 2016, 15:27 | #25220 | Link |
I will do that way. The second option would be to output from DaVinci in AVC format and then import that file to BD-RB, but that would be a "unnecessary" extra step that may degrade the quality even more. In these specific projects of mine I will use ffmpeg instead.
