6th April 2010, 20:51 | #7601 | Link |
@jdobbs;
I have a second XP Pro installation on a seperate hard drive, since I like knowing I can boot from either drive if one has a problem. I have not used that OS for some time, so after booting to it, updating antivirus and windows, I unzip a fresh BD-RBV03302, and run the inspect tool to check things out. I get the message that " HAALI Splitter: Isn't recommended version", so I uninstall the one I have, run Regedit, delete all entries of Haali, reboot and download the one from the first page of your thread. After installing that one, I reboot, and run the inspect tool again, but I get the same message. MatroskaSplitter says 1.9.42.1. I have not tried BD-RB yet, but why would I get this message from your download version? |
6th April 2010, 21:45 | #7602 | Link | |
7th April 2010, 11:32 | #7604 | Link |
Hi!
how can I use "Hiddenopts" Rebuilder keeps on ignoring TWEAK_PASS although it says " - X264 Tweak(s) enabled" i have them in the following format: TWEAK_PASS_ONE= --slices 0 --keyint 250 --min-keyint 25 --b-pyramid normal --bframes 5 --ipratio 1.4 --pbratio 1.4 EDIT: found the problem, it puts my options after the other options and the first option is taken, i think this is a BUG thanks in advance! user Last edited by user822; 7th April 2010 at 11:55. |
7th April 2010, 12:02 | #7605 | Link |
Forced subs missing after 1080p to 720P movie only encode projects
Hi jdobbs and all,
If I run a project and keep the original movie size at 1080P, keeping the main languages subs, the forced subs will automatically display. The standard subs are off by default but can be enabled at any time by the player’s subs on/off option. This is how I like so as to be the same as the original movie. But if I run the same project but resize from 1080P to 720P the forced subs do not display automatically. I have to turn on the subs on the player but then I get all the subs and not just the forced subs. If I was to set subs to on in BD_RB then I guess I will get all subs on again and not just the forced subs. Question is: How to setup BD_RB to just show forced subs defaulted to ON when resizing from 1080P to 720P? |
7th April 2010, 13:08 | #7606 | Link | |
Programmer (or just 教务长)
7th April 2010, 13:09 | #7607 | Link | |
it gives much better qual. so i would really like to use those options |
7th April 2010, 14:30 | #7609 | Link | |
This is why I hesitated to add the "tweak" option and why it will probably be removed eventually. Last edited by jdobbs; 7th April 2010 at 14:41. |
7th April 2010, 14:35 | #7610 | Link |
Just because a player will play it doesn't mean it should be allowed. The problem is that some may not -- and folks always seem to "forget" to mention that the problem was self-inflicted when they tell me that BD-RB created a coaster.
7th April 2010, 14:36 | #7611 | Link | |
While people like to play with the options that violate spec, and sometimes they're seem to work fine, it would really be a disappointment when you buy a new-and-improved player next year only to find that none of your discs work anymore. A specification is there for a reason. Last edited by jdobbs; 7th April 2010 at 14:42. |
7th April 2010, 14:58 | #7612 | Link | |
7th April 2010, 16:46 | #7613 | Link | ||
worse compatibility, true and i will not be disappointed when i buy a new blu ray player because i exactly know it might happen Last edited by user822; 7th April 2010 at 17:29. |
7th April 2010, 17:28 | #7614 | Link |
This one works 100%, the problem isn't BD-RB, it's your decision to do it wrong. If you want to encode outside of standards, I'd suggest you use something else, because that's one thing that isn't going to change in BD-RB.
7th April 2010, 17:34 | #7615 | Link | |
7th April 2010, 17:35 | #7616 | Link | |
How can i enable the "blank this item" option? it is greyed out Last edited by user822; 7th April 2010 at 17:40. |
7th April 2010, 23:51 | #7620 | Link |
Snow White and the Seven Dwarfs undersized
Encoded this with my normal settings, keep English audio and subtitles, custom target size = 23800. Plenty of space on the drive, encoder high quality
final size after rebuild = 16.4 GB (17,625,186,304 bytes) thanks here's the log file Code:
[20:21:39] BD Rebuilder v0.33.02 (beta) - Source: SNOW.WHITE.AND.THE.SEVEN.DWARFS - Input BD size: 33.01 GB - Approximate total content: [02:14:21.553] - Target BD size: 23.24 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:21:42] PHASE ONE, Encoding - [20:21:42] Extracting A/V streams [VID_00054] - [20:21:44] Reencoding: VID_00054 (1 of 48) - [20:21:44] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 359 frames - Bitrate: 11,175 Kbs - [20:21:44] Reencoding: VID_00054, Pass 1 of 2 - [20:21:57] Reencoding: VID_00054, Pass 2 of 2 - [20:22:20] Video Encode complete - [20:22:20] Reencoding audio tracks (if req'd) - [20:22:20] Multiplexing M2TS - [20:22:21] Extracting A/V streams [VID_00094] - [20:22:22] Reencoding: VID_00094 (2 of 48) - [20:22:22] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 76 frames - Bitrate: 10,977 Kbs - [20:22:22] Reencoding: VID_00094, Pass 1 of 2 - [20:22:25] Reencoding: VID_00094, Pass 2 of 2 - [20:22:31] Video Encode complete - [20:22:31] Reencoding audio tracks (if req'd) - [20:22:31] Multiplexing M2TS - [20:22:32] Extracting A/V streams [VID_00095] - [20:22:33] Reencoding: VID_00095 (3 of 48) - [20:22:33] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 161 frames - Bitrate: 11,165 Kbs - [20:22:33] Reencoding: VID_00095, Pass 1 of 2 - [20:22:40] Reencoding: VID_00095, Pass 2 of 2 - [20:22:53] Video Encode complete - [20:22:53] Reencoding audio tracks (if req'd) - [20:22:53] Multiplexing M2TS - [20:22:54] Extracting A/V streams [VID_00121] - [20:22:55] Reencoding: VID_00121 (4 of 48) - [20:22:55] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 11,512 Kbs - [20:22:55] Reencoding: VID_00121, Pass 1 of 2 - [20:23:03] Reencoding: VID_00121, Pass 2 of 2 - [20:23:22] Video Encode complete - [20:23:22] Reencoding audio tracks (if req'd) - [20:23:22] Multiplexing M2TS - [20:23:22] Extracting A/V streams [VID_00122] - [20:23:33] Reencoding: VID_00122 (5 of 48) - [20:23:33] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,824 frames - Bitrate: 16,402 Kbs - [20:23:33] Reencoding: VID_00122, Pass 1 of 2 - [20:25:14] Reencoding: VID_00122, Pass 2 of 2 - [20:30:26] Video Encode complete - [20:30:26] Reencoding audio tracks (if req'd) - [20:30:26] Multiplexing M2TS - [20:30:30] Extracting A/V streams [VID_00123] - [20:30:31] Reencoding: VID_00123 (6 of 48) - [20:30:31] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 10,834 Kbs - [20:30:31] Reencoding: VID_00123, Pass 1 of 2 - [20:30:38] Reencoding: VID_00123, Pass 2 of 2 - [20:31:04] Video Encode complete - [20:31:04] Reencoding audio tracks (if req'd) - [20:31:04] Multiplexing M2TS - [20:31:05] Extracting A/V streams [VID_00124] - [20:31:26] Reencoding: VID_00124 (7 of 48) - [20:31:26] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 3,674 frames - Bitrate: 17,009 Kbs - [20:31:26] Reencoding: VID_00124, Pass 1 of 2 - [20:34:14] Reencoding: VID_00124, Pass 2 of 2 - [20:43:25] Video Encode complete - [20:43:25] Reencoding audio tracks (if req'd) - [20:43:25] Multiplexing M2TS - [20:43:32] Extracting A/V streams [VID_00125] - [20:43:33] Reencoding: VID_00125 (8 of 48) - [20:43:33] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 168 frames - Bitrate: 10,822 Kbs - [20:43:33] Reencoding: VID_00125, Pass 1 of 2 - [20:43:41] Reencoding: VID_00125, Pass 2 of 2 - [20:44:03] Video Encode complete - [20:44:03] Reencoding audio tracks (if req'd) - [20:44:03] Multiplexing M2TS - [20:44:03] Extracting A/V streams [VID_00126] - [20:44:16] Reencoding: VID_00126 (9 of 48) - [20:44:16] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 2,136 frames - Bitrate: 17,123 Kbs - [20:44:16] Reencoding: VID_00126, Pass 1 of 2 - [20:46:02] Reencoding: VID_00126, Pass 2 of 2 - [20:51:29] Video Encode complete - [20:51:29] Reencoding audio tracks (if req'd) - [20:51:29] Multiplexing M2TS - [20:51:33] Extracting A/V streams [VID_00127] - [20:51:44] Reencoding: VID_00127 (10 of 48) - [20:51:44] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,728 frames - Bitrate: 17,597 Kbs - [20:51:44] Reencoding: VID_00127, Pass 1 of 2 - [20:53:05] Reencoding: VID_00127, Pass 2 of 2 - [20:58:18] Video Encode complete - [20:58:18] Reencoding audio tracks (if req'd) - [20:58:18] Multiplexing M2TS - [20:58:22] Extracting A/V streams [VID_00129] - [20:58:43] Reencoding: VID_00129 (11 of 48) - [20:58:43] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 3,648 frames - Bitrate: 15,982 Kbs - [20:58:43] Reencoding: VID_00129, Pass 1 of 2 - [21:01:39] Reencoding: VID_00129, Pass 2 of 2 - [21:10:50] Video Encode complete - [21:10:50] Reencoding audio tracks (if req'd) - [21:10:50] Multiplexing M2TS - [21:10:57] Extracting A/V streams [VID_00130] - [21:11:04] Reencoding: VID_00130 (12 of 48) - [21:11:04] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,224 frames - Bitrate: 15,074 Kbs - [21:11:04] Reencoding: VID_00130, Pass 1 of 2 - [21:12:02] Reencoding: VID_00130, Pass 2 of 2 - [21:15:03] Video Encode complete - [21:15:03] Reencoding audio tracks (if req'd) - [21:15:03] Multiplexing M2TS - [21:15:05] Extracting A/V streams [VID_00131] - [21:15:19] Reencoding: VID_00131 (13 of 48) - [21:15:19] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 2,232 frames - Bitrate: 15,636 Kbs - [21:15:19] Reencoding: VID_00131, Pass 1 of 2 - [21:17:00] Reencoding: VID_00131, Pass 2 of 2 - [21:23:16] Video Encode complete - [21:23:16] Reencoding audio tracks (if req'd) - [21:23:16] Multiplexing M2TS - [21:23:20] Extracting A/V streams [VID_00132] - [21:23:34] Reencoding: VID_00132 (14 of 48) - [21:23:34] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 2,304 frames - Bitrate: 16,492 Kbs - [21:23:34] Reencoding: VID_00132, Pass 1 of 2 - [21:25:37] Reencoding: VID_00132, Pass 2 of 2 - [21:32:43] Video Encode complete - [21:32:43] Reencoding audio tracks (if req'd) - [21:32:43] Multiplexing M2TS - [21:32:48] Extracting A/V streams [VID_00133] - [21:33:02] Reencoding: VID_00133 (15 of 48) - [21:33:02] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 2,448 frames - Bitrate: 16,828 Kbs - [21:33:02] Reencoding: VID_00133, Pass 1 of 2 - [21:35:38] Reencoding: VID_00133, Pass 2 of 2 - [21:43:40] Video Encode complete - [21:43:40] Reencoding audio tracks (if req'd) - [21:43:40] Multiplexing M2TS - [21:43:45] Extracting A/V streams [VID_00134] - [21:43:50] Reencoding: VID_00134 (16 of 48) - [21:43:50] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 768 frames - Bitrate: 16,932 Kbs - [21:43:50] Reencoding: VID_00134, Pass 1 of 2 - [21:44:30] Reencoding: VID_00134, Pass 2 of 2 - [21:47:11] Video Encode complete - [21:47:11] Reencoding audio tracks (if req'd) - [21:47:11] Multiplexing M2TS - [21:47:12] Extracting A/V streams [VID_00137] - [21:47:57] Reencoding: VID_00137 (17 of 48) - [21:47:57] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 11,156 frames - Bitrate: 11,572 Kbs - [21:47:57] Reencoding: VID_00137, Pass 1 of 2 - [21:58:38] Reencoding: VID_00137, Pass 2 of 2 - [22:29:02] Video Encode complete - [22:29:02] Reencoding audio tracks (if req'd) - [22:29:02] Multiplexing M2TS - [22:29:29] Extracting A/V streams [VID_00138] - [22:30:12] Reencoding: VID_00138 (18 of 48) - [22:30:12] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 5,146 frames - Bitrate: 18,112 Kbs - [22:30:12] Reencoding: VID_00138, Pass 1 of 2 - [22:34:37] Reencoding: VID_00138, Pass 2 of 2 - [22:50:12] Video Encode complete - [22:50:12] Reencoding audio tracks (if req'd) - [22:50:12] Multiplexing M2TS - [22:50:33] Extracting A/V streams [VID_00139] - [22:51:20] Reencoding: VID_00139 (19 of 48) - [22:51:20] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 12,574 frames - Bitrate: 11,110 Kbs - [22:51:20] Reencoding: VID_00139, Pass 1 of 2 - [23:01:26] Reencoding: VID_00139, Pass 2 of 2 - [23:28:37] Video Encode complete - [23:28:37] Reencoding audio tracks (if req'd) - [23:28:37] Multiplexing M2TS - [23:29:02] Extracting A/V streams [VID_00207] - [23:29:08] Reencoding: VID_00207 (20 of 48) - [23:29:08] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,537 frames - Bitrate: 10,937 Kbs - [23:29:08] Reencoding: VID_00207, Pass 1 of 2 - [23:30:35] Reencoding: VID_00207, Pass 2 of 2 - [23:33:55] Video Encode complete - [23:33:55] Reencoding audio tracks (if req'd) - [23:33:55] Multiplexing M2TS - [23:33:58] Extracting A/V streams [VID_00211] - [23:33:59] Reencoding: VID_00211 (21 of 48) - [23:33:59] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 77 frames - Bitrate: 11,356 Kbs - [23:33:59] Reencoding: VID_00211, Pass 1 of 2 - [23:34:03] Reencoding: VID_00211, Pass 2 of 2 - [23:34:13] Video Encode complete - [23:34:13] Reencoding audio tracks (if req'd) - [23:34:13] Multiplexing M2TS - [23:34:13] Extracting A/V streams [VID_00214] - [23:34:14] Reencoding: VID_00214 (22 of 48) - [23:34:14] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 73 frames - Bitrate: 11,761 Kbs - [23:34:14] Reencoding: VID_00214, Pass 1 of 2 - [23:34:18] Reencoding: VID_00214, Pass 2 of 2 - [23:34:27] Video Encode complete - [23:34:27] Reencoding audio tracks (if req'd) - [23:34:27] Multiplexing M2TS - [23:34:28] Extracting A/V streams [VID_00217] - [23:34:29] Reencoding: VID_00217 (23 of 48) - [23:34:29] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 73 frames - Bitrate: 11,599 Kbs - [23:34:29] Reencoding: VID_00217, Pass 1 of 2 - [23:34:33] Reencoding: VID_00217, Pass 2 of 2 - [23:34:42] Video Encode complete - [23:34:42] Reencoding audio tracks (if req'd) - [23:34:42] Multiplexing M2TS - [23:34:43] Extracting A/V streams [VID_00220] - [23:34:43] Reencoding: VID_00220 (24 of 48) - [23:34:43] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 72 frames - Bitrate: 11,234 Kbs - [23:34:43] Reencoding: VID_00220, Pass 1 of 2 - [23:34:47] Reencoding: VID_00220, Pass 2 of 2 - [23:34:57] Video Encode complete - [23:34:57] Reencoding audio tracks (if req'd) - [23:34:57] Multiplexing M2TS - [23:34:57] Extracting A/V streams [VID_00223] - [23:34:58] Reencoding: VID_00223 (25 of 48) - [23:34:58] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 73 frames - Bitrate: 11,580 Kbs - [23:34:58] Reencoding: VID_00223, Pass 1 of 2 - [23:35:02] Reencoding: VID_00223, Pass 2 of 2 - [23:35:11] Video Encode complete - [23:35:11] Reencoding audio tracks (if req'd) - [23:35:11] Multiplexing M2TS - [23:35:12] Extracting A/V streams [VID_00226] - [23:35:13] Reencoding: VID_00226 (26 of 48) - [23:35:13] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 73 frames - Bitrate: 11,409 Kbs - [23:35:13] Reencoding: VID_00226, Pass 1 of 2 - [23:35:17] Reencoding: VID_00226, Pass 2 of 2 - [23:35:26] Video Encode complete - [23:35:26] Reencoding audio tracks (if req'd) - [23:35:26] Multiplexing M2TS - [23:35:27] Extracting A/V streams [VID_00229] - [23:35:27] Reencoding: VID_00229 (27 of 48) - [23:35:27] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 73 frames - Bitrate: 11,485 Kbs - [23:35:27] Reencoding: VID_00229, Pass 1 of 2 - [23:35:32] Reencoding: VID_00229, Pass 2 of 2 - [23:35:41] Video Encode complete - [23:35:41] Reencoding audio tracks (if req'd) - [23:35:41] Multiplexing M2TS - [23:35:42] Extracting A/V streams [VID_00232] - [23:35:42] Reencoding: VID_00232 (28 of 48) - [23:35:42] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 73 frames - Bitrate: 11,561 Kbs - [23:35:42] Reencoding: VID_00232, Pass 1 of 2 - [23:35:46] Reencoding: VID_00232, Pass 2 of 2 - [23:35:56] Video Encode complete - [23:35:56] Reencoding audio tracks (if req'd) - [23:35:56] Multiplexing M2TS - [23:35:56] Extracting A/V streams [VID_00235] - [23:35:57] Reencoding: VID_00235 (29 of 48) - [23:35:57] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 73 frames - Bitrate: 11,656 Kbs - [23:35:57] Reencoding: VID_00235, Pass 1 of 2 - [23:36:01] Reencoding: VID_00235, Pass 2 of 2 - [23:36:10] Video Encode complete - [23:36:10] Reencoding audio tracks (if req'd) - [23:36:10] Multiplexing M2TS Last edited by jdobbs; 8th April 2010 at 00:49. |
