7th July 2013, 03:46 | #17601 | Link | |
7th July 2013, 16:24 | #17603 | Link | |
right? http://forum.doom9.org/showthread.ph...90#post1635190 Last edited by lauguru; 7th July 2013 at 17:32. |
7th July 2013, 18:48 | #17606 | Link |
Players are a lot different. Decoders, like FFDShow, and X264/LAVF require near flawless data. If you have a bad rip, these utilities will discover it. A bad press, scratched disc, or an improperly decrypted disc, or finicky optical drive can cause issues.
8th July 2013, 01:47 | #17607 | Link | |
[Edit] Hmm... guess I should have read the next message before answering. So... what omegaman7 said! Last edited by jdobbs; 8th July 2013 at 01:50. |
8th July 2013, 02:17 | #17608 | Link | |
8th July 2013, 02:33 | #17609 | Link | |
8th July 2013, 02:35 | #17610 | Link |
@Capsbackup
I looked at what happens when 01288.m2ts of "A Good Day to Die Hard" is being processed. It isn't hanging on the encode, BD-RB has gotten itself into a forever loop looking for playlist interrelationships. I'll look at it tomorrow and get a fix into the next release. |
8th July 2013, 15:23 | #17611 | Link | |
Thanks for your persistence finding and solving this "partial" user inflicted problem. (I will set MIN_M2TS_SIZE=100 for BD-25 backups) |
8th July 2013, 18:40 | #17612 | Link | |
I've fixed the issue for the next release (I'll probably post it later today or tomorrow depending on testing). With that one you should be able to set MIN_M2TS_SIZE=0 with no problems. Thanks for the heads-up on this bug. |
8th July 2013, 18:47 | #17613 | Link | |
9th July 2013, 07:18 | #17614 | Link |
Picture-in-Picture no sound !
Ok, so I backed up
" Green Lantern Extended Cut " Blu-Ray to a 25GB disc and I had encoded it using the parameter DTSX_ENABLE=1 I noticed in BD-Rebuilder the secondary picture sound file was now automatically selected, whereas is was not selectable before adding the above parameter. I was certain this would have worked flawlessly but when I played the disc, still no PiP sound. I am playing off the burned BD-25 disc on my PC using (tested in) both PowerDVD 9 PowerDVD 10 <--- This is the latest I have. Sorry. On integrated 7.1 HD Suround Sound, (yes ! all speakers turned on by the way). Made sure that in the on screen disply I enabled both PiP Video and PiP Audio to English ( the only track ). but still no PiP sound. Only the main movie sound is playing. (turned off the main movie sound for testing too. No luck). Note: PiP Video and Audio is working correctly on my system off of Original Blu-Ray discs. Last edited by Samson777; 9th July 2013 at 07:21. |
9th July 2013, 11:16 | #17615 | Link |
That is a known issue and for the moment unsolveable. For some reason pdvd doesn't like the way bdrb mixes the pip video back in. I have the same issue. Pdvd is a nogo on the backup but on the standalone it works just fine.
9th July 2013, 23:39 | #17619 | Link | |
I have also failed to be able to play the Blu-Ray rips from BD-Rebuilder directly off of the Hard Drive. Has anyone found the solution to these? |
9th July 2013, 23:51 | #17620 | Link | |
