24th September 2017, 09:55 | #221 | Link |
There does appear to be a slight shift. After lots of testing it appears there is a minor bug in the MScaleVect function that's causing it. It's not related to block size or anything else. I'll report it in the MVTools2 thread.
http://forum.doom9.net/showpost.php?...&postcount=399 This same bug is probably why it doesn't work very well with MFlowFPS either. Last edited by burfadel; 24th September 2017 at 10:10. |
28th September 2017, 12:03 | #222 | Link |
The other day Pinterf sent me a test version of MVTools2 which basically fixed the image shift issue. It was an error in one of the algorithms that was there since day one. There was still a very slight shift or difference in some motion between fully using Mscalevect and using base code, I'm not sure whether that could be resolved though. In terms of how mClean is set up though, basically the new version fixes the issue as I don't use it on radius 1. I guess if that additional error was improved upon I could add a fast option that runs it for radius 1 as well and maybe use Mdegrain3 instead of Mdegrain4 for that mode.
4th October 2017, 07:53 | #224 | Link |
Run "AVSMeter -avsinfo -log". Post the created log file (avsinfo_x86.log).
Groucho's Avisynth Stuff |
4th October 2017, 09:18 | #225 | Link |
Removing DCTFilter_avx2.dll from the plugins folder has solved exactly this problem for me.
4th October 2017, 10:50 | #226 | Link | ||
Unfortunately after removing avx2.dll, I got this error showed up Quote:
Edit : SOLVED I used old DCTFilter dll by mistake... Thanks for helping me Last edited by cap5lock; 4th October 2017 at 15:25. |
11th October 2017, 02:35 | #227 | Link |
Soul Architect
Original / mClean 1.7 / mClean 1.8
Here the result is excellent with v1.8 Here, there is still too much color shifts. On 288p content, however, I still get best results with v1.3c; v1.7 and v1.8 add distortion and amplify artifacts. Is there a specific reason for this? Perhaps SD and HD content require different settings.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 11th October 2017 at 02:42. |
11th October 2017, 05:00 | #228 | Link |
Possibly. There is a bug in MVtools2 that affects 1.8. PinterF has fixed this and it will be in the next MVtools2 release. I was waiting on this before a new mClean. I did spend quite a while working on another 'feature' that works great in some specific scenarios in making it better (ideal even), but in other scenarios it was worse. For the remainder of situation it made no difference. Since it was scene dependent it's usefulness isn't really there. There is completely different way I could potentially do it that could have most of the benefits without the downsides, I'll have to do testing.
11th October 2017, 06:57 | #229 | Link |
Soul Architect
Yes I have Pinterf's fixed version, that's fine.
MDegrain4 gives good quality on HD grain (small pixels). However, on SD content with gross pixels and artifacts, it's distorting stuff. Perhaps you'll find a method that works for both HD and SD. If not, perhaps you can have a version for HD and a version for SD. Then color distortion is the other concern -- entirely separate issue. |
29th October 2017, 00:25 | #231 | Link |
Updated first post with v1.9. I had to shuffle around the description etc as the first post exceeded the allowed post size limit. MysteryX, If the very low resolution handling (such as the 288P example you gave) is still a little iffy I can add handling for this, but I didn't want to add it with v1.9 if it appears unnecessary.
29th October 2017, 11:07 | #232 | Link |
I think than your line:
blkSize = Default (blkSize, defH>480 ? 12 : defH>1200 ? 16 : defH >=2600 ? 32 : 8) # Horizontal block size for MDegrain4 is still wrong in v1.9, blkSize 16 or 32 are never used, only 12 for defH>480 or 8 for defH<=480 Must be: blkSize = Default (blkSize, defH >=2600 ? 32 : defH>1200 ? 16 : defH>480 ? 12 : 8) # Horizontal block size for MDegrain4 EDIT: Also the sc parameter: sc = defH>480 ? 2 : defH>1200 ? 4 : defH >=2600 ? 8 : 1 must be: sc = defH >=2600 ? 8 : defH>1200 ? 4 : defH>480 ? 2 : 1
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 29th October 2017 at 11:21. |
29th October 2017, 11:34 | #233 | Link |
Oops, I've made that correction now . On a separate note, something that I was going to include requires the use of scriptclip, but I can not get it working within the script. If I run it outside the script it works fine.
Are you familiar with using scriptclip? I asked MysteryX, I can forward you the message I sent him on here if you are. |
29th October 2017, 12:02 | #234 | Link |
Just post your Scriptclip requirement here, let everyone see it.
Perhaps you keep getting mixed up with masktools RPN [EDIT: multi-ganged] '?:' ternary conditional, I think it works a bit back-to-front and weird compared with everyone else's [EDIT: multi-ganged] version ternary conditional.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th October 2017 at 12:10. |
29th October 2017, 12:21 | #235 | Link |
For scriptclip, it would be something like:
combined = deband ? CombinePlanes(clean, chroma?filt_chroma:c, planes="YUV", source_planes="YUV", pixel_type=pixeltype(filt_chroma)) : nop() combined = deband ? ScriptClip(" coloryuv(combined, gain_y=LumaDifference(c, clean), chroma?gain_u=ChromaUDifference(c, filt_chroma):0, chroma?gain_v=ChromaVDifference(c, filt_chroma):0) ") : nop () filt_chroma = deband ? mt_adddiff (combined, TemporalSoften(mt_makediff(combined, f3kdb (combined, preset=chroma?"high":"luma", range=17, \ grainY=33, grainC=chroma?35:0)), 1, 255, chroma?255:0, scenechange=255, mode=2)) : filt_chroma clean = deband ? ExtractY (filt_chroma) : clean Code:
c=last mClean() filt_chroma=last ScriptClip("coloryuv(filt_chroma, gain_y=LumaDifference(c, filt_chroma), gain_u=ChromaUDifference(c, filt_chroma), gain_v=ChromaVDifference(c, filt_chroma))") |
29th October 2017, 16:22 | #236 | Link |
# How it is S= " \ coloryuv(combined, \ gain_y = LumaDifference(c,clean), \ chroma ? gain_u=ChromaUDifference(c,filt_chroma) : 0, # EDIT: kind of surprised these 2 lines work at all \ chroma ? gain_v=ChromaVDifference(c,filt_chroma) : 0 # EDIT: Assuming that they do \ )" # more like how it should be, # but, when not @ main script level, combined, c, clean. chroma, filt_chroma, are not in scope (unless globals). # Maybe below more as intended (but args still not in scope) S= " \ coloryuv(combined, \ gain_y = LumaDifference(c,clean), \ gain_u = (chroma) ? ChromaUDifference(c,filt_chroma) : 0, \ gain_v = (chroma) ? ChromaVDifference(c,filt_chroma) : 0 \ )" combined = deband ? ScriptClip(S) : nop # This is horrible, [EDIT: perhaps nop should be combined] # TEST Colorbars.killaudio # Assign to Last a=invert # inverted Last a=false ? blankclip : NOP return a # If true then returns blankclip else Error, "The script return value was not a clip (is an int, 0)" EDIT: Also, take care with ScriptClip, requires a source arg, if not supplied then is implied to be Last (should it be c or combined or what, inside Scriptclip that source arg will become Last).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th October 2017 at 17:30. |
29th October 2017, 17:46 | #237 | Link |
Soul Architect
Note that if you use ScriptClip, you can't use MT anymore -- which renders it useless for practical use in many cases.
Perhaps you'd need a custom filter for this one? Plus you might do a better job if you decide how it's being done in the details. Also perhaps other complex command chains would be better achieved as custom filters. |
31st October 2017, 11:20 | #239 | Link |
Acid fr0g
I tried a very silly mClean() in my script, just to give it a try, and the result is:
[2017-10-31][11:15:02] Simple x264 Launcher (Build #1118), built 2017-10-04 [2017-10-31][11:15:02] [2017-10-31][11:15:02] Job started at 2017-10-31, 11:15:02. [2017-10-31][11:15:02] [2017-10-31][11:15:02] Source file : E:\in\1_30 Eden Lake\eden_mclean.avs [2017-10-31][11:15:02] Output file : E:\in\1_30 Eden Lake\eden_mclean.mkv [2017-10-31][11:15:02] [2017-10-31][11:15:02] --- SYSTEMINFO --- [2017-10-31][11:15:02] [2017-10-31][11:15:02] Binary Path : D:\eseguibili\media\x264 launcher [2017-10-31][11:15:02] Avisynth : Yes [2017-10-31][11:15:02] VapourSynth : No [2017-10-31][11:15:02] [2017-10-31][11:15:02] --- SETTINGS --- [2017-10-31][11:15:02] [2017-10-31][11:15:02] Encoder : x264 (AVC/H.264), 64-Bit (x64), 8-Bit [2017-10-31][11:15:02] Source : Avisynth (avs) [2017-10-31][11:15:02] RC Mode : CRF [2017-10-31][11:15:02] Preset : slow [2017-10-31][11:15:02] Tuning : <None> [2017-10-31][11:15:02] Profile : High [2017-10-31][11:15:02] Custom : --level 4.1 --keyint 240 --vbv-bufsize 78125 --vbv-maxrate 62500 --aq-mode 2 --sar 1:1 [2017-10-31][11:15:02] [2017-10-31][11:15:02] --- CHECK VERSION --- [2017-10-31][11:15:02] [2017-10-31][11:15:02] Detect video encoder version: [2017-10-31][11:15:02] [2017-10-31][11:15:02] Creating process: [2017-10-31][11:15:02] "D:\eseguibili\media\x264 launcher\toolset\x64\x264_8bit_x64.exe" --version [2017-10-31][11:15:02] [2017-10-31][11:15:02] x264 0.152.2851kMod ba24899 [2017-10-31][11:15:02] (libswscale 4.7.101) [2017-10-31][11:15:02] (libavformat 57.75.100) [2017-10-31][11:15:02] (ffmpegsource 2.23.0.0) [2017-10-31][11:15:02] built by Komisar on Jul 2 2017, gcc: 4.9.2 (multilib.generic.Komisar) [2017-10-31][11:15:02] x264 configuration: --bit-depth=8 --chroma-format=all [2017-10-31][11:15:02] libx264 configuration: --bit-depth=8 --chroma-format=all [2017-10-31][11:15:02] x264 license: GPL version 2 or later [2017-10-31][11:15:02] libswscale/libavformat/ffmpegsource license: GPL version 2 or later [2017-10-31][11:15:02] [2017-10-31][11:15:02] Detect video source version: [2017-10-31][11:15:02] [2017-10-31][11:15:02] Creating process: [2017-10-31][11:15:02] "D:\eseguibili\media\x264 launcher\toolset\x64\avs2yuv_x64.exe" [2017-10-31][11:15:02] [2017-10-31][11:15:02] Avs2YUV 0.24bm5 [2017-10-31][11:15:02] [2017-10-31][11:15:02] > x264 revision: 2851 (core #152) - with custom patches! [2017-10-31][11:15:02] > Avs2YUV version: 0.24.5 [2017-10-31][11:15:02] [2017-10-31][11:15:02] --- GET SOURCE INFO --- [2017-10-31][11:15:02] [2017-10-31][11:15:02] Creating process: [2017-10-31][11:15:02] "D:\eseguibili\media\x264 launcher\toolset\x64\avs2yuv_x64.exe" -frames 1 "E:\in\1_30 Eden Lake\eden_mclean.avs" NUL [2017-10-31][11:15:02] [2017-10-31][11:15:03] error: MAnalyse: Block sizes must be 8 or more for divide mode [2017-10-31][11:15:03] (D:/Programmi/Media/AviSynth+/plugins64/mClean-1.9�burfadel.avsi, line 109) [2017-10-31][11:15:03] (E:\in\1_30 Eden Lake\eden_mclean.avs, line 13) [2017-10-31][11:15:03] [2017-10-31][11:15:03] PROCESS EXITED WITH ERROR CODE: 1
@turment on Telegram |
31st October 2017, 12:40 | #240 | Link |
Are you using the latest versions of all the plugins, for example MVTools2 (pfmod)? https://github.com/pinterf/mvtools/releases/
cleaning, denoise, denoiser, mclean |
