23rd July 2015, 13:59 | #13362 | Link |
there hasnt been any activity in the dcadec department on github for 2 months now. can we conclude from that the development of the decoder is finished and everything is working?
24th July 2015, 05:02 | #13363 | Link | ||
The -core parameter only applies to DTS-HD, according to this: https://en.wikibooks.org/wiki/Eac3to...nd_Line_Syntax I don't use eac3to via the command line much. I tend to use the HD Streams Extractor built into MeGUI instead (or there's a standalone version here). But I tried a few extractions and checked the command line MeGUI was using. The same TrueHD+AC3 stream was selected each time. When extracting both streams as a single file with a thd+ac3 extension: "C:\Program Files\MeGUI\tools\eac3to\eac3to.exe" "E:\Video\" 1) 3:"D:\F1_T3_Audio - English.thd+ac3" -progressnumbers TrueHD only: "C:\Program Files\MeGUI\tools\eac3to\eac3to.exe" "E:\Video\" 1) 3:"D:\F1_T3_Audio - English.thd" -progressnumbers AC3 only: "C:\Program Files\MeGUI\tools\eac3to\eac3to.exe" "E:\Video\" 1) 3:"D:\F1_T3_Audio - English.ac3" -progressnumbers Or when opening the m2ts file directly, rather than let the HD Streams Extractor open the whole disc and find the appropriate mpls file, or whatever it does. "C:\Program Files\MeGUI\tools\eac3to\eac3to.exe" "E:\Video\BDMV\STREAM\00007.m2ts" 3:"D:\T3_Audio - English.ac3" -progressnumbers Quote:
Hopefully the info above will help you out. Last edited by hello_hello; 24th July 2015 at 05:18. |
25th July 2015, 11:19 | #13365 | Link |
@turab
Yes, AAC support 6.1 channel configuration, but a DTS-ES Matrix have only 5.1 discrete channels, the Back Center channel is mixed in surround channels. AFAIK AAC headers don't have any flag to inform the player about that. But I think than is not necesary, you can recode your DTS to a 5.1 AAC and, if you have a 5.1 audio speakers you can listen the Back Center like a fantom channel, if you have a 6.1 audio speakers your receiver/amplifier maybe can extract the Back Center channel for you. There are a option, not recommended, to convert a 6.1 Matrix in 6.1 discrete channels: 1) Decode 6.1 Matrix to 6 wavs with eac3to 2) Use SL and SR wavs to create a stereo wav (with Sox, WaveWizard or any audio editor like Audacity) 3) Use CenterCutGUI to create 3 channels 4) Make a 6.1 wav replacing SL/SR with the 3 new channels and encode to AAC
25th July 2015, 14:28 | #13366 | Link | |
With CenterCut I have created a center.wav and a sides.wav from the combined stereo SL-SR.wav. - Do you use the center.wav as the center back channel? - How do you create the wavs for replacing the SL and SR channel? Is this accomplished by converting the stereo center.wav to a center-left.wav and center-right.wav? greetz |
25th July 2015, 17:38 | #13368 | Link | ||
25th July 2015, 19:48 | #13369 | Link | |
26th July 2015, 00:04 | #13370 | Link |
@Mike
hello friends I'm here with a doubt ..
I have a 384kbps audio to and can convert to 640kbps It is allowed to convert audio unless kbps kbps for more ... Or it can only be converted and is allowed to convert more kbps audio for less ... thank you |
26th July 2015, 08:02 | #13373 | Link |
Terminator 2 Judgment Day Skynet Edition 1991 Blu-ray 1080p EUR VC-1 DTS-HD MA
eac3to v3.28 (arcsoft 1.1.0.0) M2TS, 2 video tracks, 9 audio tracks, 19 subtitle tracks, 2:17:19, 24p /1.001 6: DTS Master Audio, German, 7.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) [a06] Extracting audio track number 6... [a06] Decoding with ArcSoft DTS Decoder... [a06] Writing WAVs... [a06] Skipping identical DTS frames (seamless branching)... [a06] Original audio track: max 24 bits, average 16 bits, most common 16 bits. [a06] Audio overlaps for 9ms at playtime 0:18:31. <WARNING> [a06] Audio overlaps for 5ms at playtime 0:39:24. <WARNING> [a06] Audio overlaps for 8ms at playtime 0:39:42. <WARNING> [a06] Audio overlaps for 6ms at playtime 1:04:51. <WARNING> [a06] Audio overlaps for 11ms at playtime 1:07:11. <WARNING> [a06] Audio overlaps for 8ms at playtime 1:08:47. <WARNING> [a06] Audio overlaps for 7ms at playtime 1:12:08. <WARNING> [a06] Audio overlaps for 5ms at playtime 1:21:17. <WARNING> [a06] Audio overlaps for 12ms at playtime 1:34:04. <WARNING> [a06] Audio overlaps for 10ms at playtime 1:56:49. <WARNING> [a06] Audio overlaps for 11ms at playtime 2:01:59. <WARNING> [a06] Audio overlaps for 8ms at playtime 2:05:06. <WARNING> [a06] Audio overlaps for 9ms at playtime 2:11:54. <WARNING> [a06] Starting 2nd pass... [a06] Extracting audio track number 6... [a06] Decoding with ArcSoft DTS Decoder... [a06] Writing WAVs... [a06] Realizing RAW/PCM gaps... [a06] Skipping identical DTS frames (seamless branching)... [a06] Processed audio track: max 24 bits, average 16 bits, most common 16 bits. eac3to v3.29 (dcadec) M2TS, 2 video tracks, 9 audio tracks, 19 subtitle tracks, 2:17:19, 24p /1.001 6: DTS Master Audio, German, 7.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) [a06] dts, 48000, 7.1 [a06] Extracting audio track number 6... [a06] Decoding with libDcaDec DTS Decoder... [a06] Writing WAVs... [a06] The libDcaDec DTS Decoder reported the error "Bitstream navigation error" while decoding. <ERROR> Aborted at file position 16039026688. <ERROR>
32bit Vista SP2 (DX11 Platform Update), Nvidia GTX960 4GB AMP (365.19), 1. 27' FHD Benq / 2. 65' UHD HDR Sony XE93, madVR 0.92.17, LAV 0.73.1, MPC-HC 1.8.3 |
26th July 2015, 08:59 | #13374 | Link | ||
but eac3to/libav ac3 encoder has wrong bandwidth in lower Bitrates for 5.1 like 384 (14 kHz) / 448 (16 kHz) vs Studio AC3 384 (18 kHz) / 448 (20 kHz) To Save all Frequencies (no cutoff) from Source AC3 to Reencode AC3 with eac3to (libav), the min. Bitrate for 384/448 kbps is 576 kbps @ 5.1, but 640 kbps are better choise because lossy Encode from lossy Source. A Speedup for AC3 5.1 384 raise Frequencies near 20 kHz, so u need more Bitrate/Bandwidth for Reencode. ........ Better use Surcode for AC3 Encoder for lower Bitrates, or AftenGui and EncWAVtoAC3 have bandwith Option from -2 to 60 (5.1 384 kbps 18kHz = 40 / 5.1 448 kbps 20kHz = 48)
32bit Vista SP2 (DX11 Platform Update), Nvidia GTX960 4GB AMP (365.19), 1. 27' FHD Benq / 2. 65' UHD HDR Sony XE93, madVR 0.92.17, LAV 0.73.1, MPC-HC 1.8.3 Last edited by Smithy; 26th July 2015 at 09:29. |
26th July 2015, 11:01 | #13375 | Link |
To not lose quality, preferably don't recode (if the source format is supported by the target device). If you convert between different formats (e.g. multichannel AAC to AC3), you may of course use different bitrates because the codecs have different efficiency.
26th July 2015, 11:57 | #13376 | Link | |
The common parts between SL-SR are extracted to BC channel and elimitated from original SL-SR to output a new pair SL'-SR'. Only DTS-ES 6.1 discrete have info to do a better channel separation: http://www.avsforum.com/forum/90-rec...ml#post4224284
26th July 2015, 13:39 | #13378 | Link | |
2) Of course if you own a commercial certified encoder maybe the output is better than use free AC3 encoders. Thats can't be discussed here. 3) But remember than quality is not only bandwith, at same bitrate you can choice between lose bandwith or lose precission. 4) I make a test encoding a Test.waw 5.1 48 KHz with different options: Test-Aften-w40-384.ac3 (18 KHz) Test-Aften-w48-448.ac3 (20 KHz) Test-eac3to-384.ac3 (14 KHz) Test-eac3to-448.ac3 (16 KHz) Test-ffmpeg-384.ac3 (18 KHz) Test-ffmpeg-448.ac3 (20 KHz) Test-SoftEncode-384.ac3 (18 KHz, default like Studio AC3) Test-SoftEncode-448.ac3 (20 KHz, default like Studio AC3) I used spek to see bandwith, I upload the images here: https://www.sendspace.com/file/egd7tu 5) Remember than eac3to can use the external encoder Aften to override the default parameters used with eac3to: eac3to Test.wav stdout.wav | Aften -b 448 -w 48 - Test-Aften-w48-448.ac3 6) Now ffmpeg is the free AC3 recommended encoder.
26th July 2015, 13:58 | #13379 | Link | |
To obtain a full surround (plane) audio image for a listener with only two ears 5.1 speakers is more than enough. Systems with 6.1 or 7.1 speakers only want gain more money. Do you have a ear in the nape? Your ears only listen a mix SL/BC and SR/BC or SL/BL and SR/BR.
26th July 2015, 16:41 | #13380 | Link | |
Because it don't need more Bandwidth. or better use Bandwith near the Source Frequencies, maybe 18kHz = 40 or 16 kHz = 32 or whatever. Eac3to/libav use Bandwidth @ 60 (24kHz) for 5.1 AC3 640 Kbps 2) Aften looks best to the Source but SoftEncode looks Crapy !
32bit Vista SP2 (DX11 Platform Update), Nvidia GTX960 4GB AMP (365.19), 1. 27' FHD Benq / 2. 65' UHD HDR Sony XE93, madVR 0.92.17, LAV 0.73.1, MPC-HC 1.8.3 Last edited by Smithy; 26th July 2015 at 19:09. |
eac3to |
