14th January 2009, 23:56 | #3761 | Link | |
1st pass is main profile and 2nd pass is high profile. That is why I only get this warning in 1st pass. Code:
x264.exe --pass 1 --bitrate 7854 --stats "C:\Personal\Videos\sample.stats" --level 4 --keyint 24 --min-keyint 1 --bframes 3 --b-adapt 2 --b-pyramid --weightb --direct auto --deblock -1:-1 --subme 2 --partitions none --vbv-bufsize 30000 --vbv-maxrate 24000 --qcomp 0.5 --me dia --merange 24 --threads auto --thread-input --sar 1:1 --aud --progress --no-psnr --no-ssim --output NUL "C:\Personal\Videos\sample.avs" --mvrange 511 --aud --nal-hrd --sar 1:1 avis [info]: 1280x544 @ 23.98 fps (256 frames) x264 [info]: using SAR=1/1 x264 [warning]: VBV bitrate (24000) > level limit (20000) x264 [warning]: VBV buffer (30000) > level limit (25000) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile Main, level 4.0 Code:
x264.exe --pass 2 --bitrate 7854 --stats "C:\Personal\Videos\sample.stats" --level 4 --keyint 24 --min-keyint 1 --ref 3 --mixed-refs --no-fast-pskip --bframes 3 --b-adapt 2 --b-pyramid --weightb --direct auto --deblock -1:-1 --subme 8 --trellis 2 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --vbv-bufsize 30000 --vbv-maxrate 24000 --qcomp 0.5 --me umh --merange 24 --threads auto --thread-input --sar 1:1 --aud --progress --no-psnr --no-ssim --output "C:\Personal\Videos\sample.mp4" "C:\Personal\Videos\sample.avs" --mvrange 511 --aud --nal-hrd --sar 1:1 avis [info]: 1280x544 @ 23.98 fps (256 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile High, level 4.0 |
15th January 2009, 14:41 | #3762 | Link |
@wolfbane5
if your source is 2.40 then correct crop values will be TOP=140 , BOTTOM=140 1920 / 2.4 = 800 1080 - 800 = 280 280 / 2 = 140 AutoCrop may not work well with dark movies therefore I added Manual crop.
15th January 2009, 16:26 | #3763 | Link |
Preview: Cannot Render File
Hello,
I just recently moved from Vista Ultimate 64-bit to Windows 7 64-Bit...I also updated my copy of RipBot from 1.11.5 to 1.12.0...prior to the update, everything worked correctly but since the update, I can't see a preview in wmp classic...the encodes still work, but when I attempt to preview them, I get: Cannot render file...using 1080p files or 720p...mostly using .mkv files (occasionally .ts or .m2ts files) all w/DTS or 5.1DD audio...I'm using a i7 920 quad core cpu w/6 GB of triple channel memory, if that helps...I believe its a codec issue, just not sure how to fix it...the research I did, it was suggested to install the K-lite codec pack (which I know I don't want to do using RipBot) Please help!! I updated RipBot & went to Windows 7 w/in 48 hours of each other so I'm not sure where the problem lies...anyone else having any similiar issues?? Thanks |
15th January 2009, 17:30 | #3764 | Link | |
15th January 2009, 23:22 | #3766 | Link |
Thank you for the advice. I uninstalled Avisynth & ffdshow then re-installed them...using the newest build of Avisynth & for ffdshow, I'm trying the rev 2605, I read that it's supposed work well w/a fast cpu. I have a i7 Quad Core so I should be good w/that. After reinstalling these, I'm able to get the preview showing in WMP Classic. Now, my problem is the audio is out of sync when playing the preview. If I play the files in Nero Showtime, it plays in sync. Does anyone know what could cause this?? Thanks again for the help, it's much appreciated...
15th January 2009, 23:42 | #3767 | Link |
Try ffdshow MT
15th January 2009, 23:52 | #3768 | Link |
That's what I installed, rev 2605 20090110 xxl mt
...I was using rev 2615 20090112 clsid but read that the mt version would give increased performance (speed) when encoding...you had mentioned getting like (correct me if I'm wrong) like 80 fps, is that right? That's amazing, I'm lucky to hit the high 30s during the 1st pass...I had an AMD FX-60 before I rebuilt my main PC (mainly to speed up my encodes) & I can do 3-4 jobs @ 1080p w/either DTS or AC3 (8150MB) in the time it would take me to do 1 on my older rig...if you have any suggestions what I can do to increase the speed, please let me know...thanks for all your hard work, Atak!! |
16th January 2009, 00:26 | #3769 | Link | |
80 fps in PLAYBACK not in encoding. I was just testing decoding performance in ffdshow mt!!!
16th January 2009, 00:52 | #3770 | Link | |
I have an i7 920 Quad Core (not overclocked), 6 GB Triple Channel Corsair Dominator 1600 memory, my OS on a SAS Fujitsu 73.5 GB drive (storage drives are a 500 Gb & 1 TB SATA) w/GTX 260 Nvidia video card... |
16th January 2009, 00:59 | #3771 | Link |
I have Q6600@3ghz and I'm very happy. Movie is always ready when I wake up in the morning
17th January 2009, 00:44 | #3775 | Link |
eac3to is set to always extract dts core from DTS-HD. Just leave Copy Stream opion.
17th January 2009, 03:55 | #3776 | Link |
I just tried Ripbot264 version 1.12.0 on Window 7. It told me I needed to install Splitter and ffdshow which I did. But when I add a video it does not index, it just sits there. No errors, it just does not index or return. The filename does not show up in the Video text box and no entry is in the status bar.
I did have the old version running on WinXP. UPDATE==================================== I went into Ripbot264.ini and changed the DefaultOutputPath and StoreTempFilesin to point to locations that I knew Win7 could read and write to and then it started working properly. Just in case others have the same problem. Last edited by weaver4; 17th January 2009 at 05:38. |
17th January 2009, 08:17 | #3777 | Link |
How do you use the downloaded file?
What is missing from the first posting is what you do with the file after it has been downloaded.
There must be others like me who have never run across whatever was used the "compress" this executable. Simple instructions would be nice. BTW, Google searching came up empty (at least there was nothing in the list that indicted that it was instructions). EDIT: Found it. It would still be nice to reference that 7zip is used to compress the file. Never heard of it before. Last edited by MrVideo; 17th January 2009 at 08:36. Reason: updated info |
