6th November 2009, 03:54 | #5861 | Link |
Well, after successfully reencoding angels and demons blu-ray to a 22.46 gb target size a few days ago, under windows 7 64 bit I can not get the program to use ffdshow with the drag me to hell UK bluray with the same settings and target size.
It keeps trying to load ffms2.dll apparantly because it cant find ffdshow. Ffdshow does not show up in the background. Yet, it had no problems loading ffdshow with angels and demons. And it still doesn't as I just tried reencoding angels and demons again. I did encode drag me to hell letting it use ffms2.dll, it completed, but the audio/video sync was horribly out of whack, while angels and demons was perfect. I've tried various settings with sharks win 7 codec pack with no luck, all the similiar mpeg/mkv file types play correctly with ffdshow. Here is the log, I aborted it myself this time: [21:37:56] BD Rebuilder v0.31.01 (beta) - Source: DRAG_ME_TO_HELL - Input BD size: 45.67 GB - Approximate total content: [03:55:52.096] - Target BD size: 22.46 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [21:37:56] PHASE ONE, Encoding - [21:37:56] Extracting A/V streams [VID_00078] - [21:38:01] Reencoding: VID_00078 (1 of 19) - Switching to FFMS2.DLL for decoding. [21:39:16]PHASE ONE aborted by user request |
6th November 2009, 04:13 | #5862 | Link |
The more posts I read about the adventures of Windows 7, the more content I become with XP.
I know jdobbs has reported no problems, at least yet, with his upgrade, but there sure seems to be plenty that do not have this experience. I continue to have no problems with my setup, so for this computer that does my BD backups, it will stay as is!! |
6th November 2009, 04:15 | #5863 | Link |
Yah, it's hit or miss, never had any problems recently in vista. I'm sure it has to do with codec settings, which has been complicated by the fact that windows 7 wants its own taking over, but I don't think it will be too hard to fix. I'm just not smart enough to know how.
6th November 2009, 04:27 | #5864 | Link |
@jdobbs
Can we always use the latest x264 from http://www.x264.nl/ or do we need to wait until BD Rebuilder is updated? Just one final question, I am getting very familiar with all the settings now except "Color Boost 10%". What is your intention with this? What benefit will it bring to the final burn and how much does it slow the encode down to? Thanks |
6th November 2009, 04:35 | #5865 | Link |
Personally... I think most of the problems associated with BD-Rebuilder, regardless of OS, can be found right on the PC that is having the problems. Some people with their 20 different sets of codecs, pre-processing, post-processing, tweaks to the command line, downloaded movies, etc., etc., probably account for at least 90% of the issues falsely reported as bugs along with the obligatory... "It couldn't be anything I did!" There's a big difference between a bug and a "I screwed up" which we don't seem to se much of..
@Capsbackup... I'm with you on using XP on my dedicated BD-Rebuilder PC for now, only because it works flawlessly. For everything else, Win 7 is the way to go. |
6th November 2009, 07:41 | #5866 | Link |
dings!
Video jerky and Audio out of sync
the last version i have been trying was 1809 and that version worked flawless (movie only to dvd5). Yesterday i tried the new version 0.31.01 and the output (movie only, strict avhcd) is not useable on a ps3. Audio is out of sync about 1 minute at the second chapter and the video played a litte jerky as if there were the pulldown flags missing in the stream. The audio goes further out of sync the further the movie goes on... The movie was BSG_THE_PLAN. There were no errors in the log. I'm using XP Professional. So i wanted to try the old Version again and it said: this beta is expiered. Thanks for that great programm anyway. Hope this problem can be resolved. MvB |
6th November 2009, 14:50 | #5869 | Link | |
6th November 2009, 14:54 | #5871 | Link | |
This program is a beta and right now exists for only one reason: bug testing. It doesn't do any good for anyone to debug a version that is 9 months old and 37 revisions ago (yep, I counted 'em)... you are expressing exactly why I put the expiration in. Some details might help if you'd like to see it fixed. Region, type of audio, type of video, maybe posting the INF and/or INI files, the log, the AVS file of the out-of-sync audio, or maybe the .meta file? I like to thing I'm good -- but I can't fix things by putting my hands on a monitor and shouting "HEAL!". But thanks for your great bug report anyway. Last edited by jdobbs; 6th November 2009 at 15:08. |
6th November 2009, 15:06 | #5872 | Link | |
6th November 2009, 16:07 | #5873 | Link | |
6th November 2009, 17:06 | #5874 | Link | |
Windows 7 / XP 64 Bit Error...
Thank you very much for your app, it is very helpful. For days now I am trying to get this to work on Windows XP 64-bit and Windows 7 64-bit. I tried to convert various Blu-Rays. Sadly, I always get this error message: Quote:
I installed the progran the same way each time. I only changed the x264.exe file on the 64-bit systems as I should. Is there a solution to this problem? Thank you in advance. Regards, kassette (analog) Last edited by Kassette1; 6th November 2009 at 17:13. |
6th November 2009, 17:39 | #5875 | Link | |
6th November 2009, 18:22 | #5876 | Link | |
- Index the .m2ts with DGAVCIndexNV - Extract audio and sups with eac3to (extracts the tracks one by one), and convert audio to ac3 448. - encode video with x264 - mux video and audio with tsmuxer (timeshift=0) No idea what was key to the success: DGindex or eac3to. (Just to exclude any previous mistake I did everything again with BD-RB, but again it was out of sync). |
6th November 2009, 18:24 | #5877 | Link | |
I wish there was a single place that clearly says exactly what needs to be set (and why) in order for Windows 7 to use the FFDSHOW codecs. I can build the changes in -- but I don't want to just make them on faith without knowing what the consequences are. There are too many people doing that already, like Microsoft, for instance, when they made the Directshow changes for this release! Last edited by jdobbs; 6th November 2009 at 18:32. |
6th November 2009, 19:23 | #5880 | Link | ||
Programmer (or just 教务长)
64bit version of x264 requires 64bit version of avisynth - otherwise it won't work. So either keep x264 (32bit) with standard 32bit AviSynth or don't treat it as a problem. I did a lot of tests last week and despite all the efforts I wasn't able to make 64bit x264 to work with some 'patched' 64bit avisynth dlls or whatever. The same .avs script passed to 32bit x264 works perfectly but not with 64bit x264. |
