Old 16th July 2015, 11:23   #801  |  Link
Siso
Soul Seeker
Siso's Avatar
Originally Posted by foxyshadis View Post
That's always been part of the SSA specs. Set the alignment field to 1 for left-justified. Unless you mean fully-justified, where width is always the same; that's not a part of the specs.
My idea was: the subtitles to be centered , but the alignment of the sentences etc. to be left aligned (paragraph).
Siso is online now   Reply With Quote
Old 16th July 2015, 14:48   #802  |  Link
octal9
octal9's Avatar
Originally Posted by Magik Mark View Post
Can somebody help with this:
I have no problem in playing xysubtitle as along as its embedded. External ones wont just load. I'm using madvr, mpcbe & reclock. All latest versions.
try switching xysubfilter to "always load" in the loading section of xysubfilter's options - this helped my as i was having problems of subs not always loading. (i'm using the same setup as you)
octal9 is offline   Reply With Quote
Old 16th July 2015, 22:55   #803  |  Link
jriker1
I'm going nuts with this and trying to understand what I'm doing wrong. Using aegisub to format my ass file. I center it bottom middle and then raise things up like 40 pixels or whatever. Looks good in the editor. Apply it to all subtitles. When I run it thru avisynth its always puts the subs at the very bottom of the video. Doesn't xy-vsfilter honor settings in ass files?
JR
jriker1 is offline   Reply With Quote
Old 17th July 2015, 10:28   #804  |  Link
can you share an example?
avisynth script and the ass.
and don't forget to add the fonts to the system fonts.
Old 17th July 2015, 16:20   #805  |  Link
jriker1
Sure thing. Funny part is, even though I chop off 20 pixels of black bars on the top and bottom of the video after the subs are burned in, still goes to the bottom. Either some overscan on my Panasonic Plasma or something else is going on. Figure if I don't change the video width but reduce the height it would show more on the screen vertically not less. Anway, guessing as I'm using Arial adding fonts won't be an issue but here you go:
AVS file is very simple:
avisource("district.avi")
TextSub("district_Subtitles.ass")
ass file looks like this. Unless you want all 211 subs cut it after a few:
[Script Info]
; Script generated by Aegisub 3.2.2
; http://www.aegisub.org/
Title: Untitled
ScriptType: v4.00+
PlayDepth: 0
YCbCr Matrix: TV.601
PlayResX: 1920
PlayResY: 1080
[Aegisub Project Garbage]
Last Style Storage: Default
Audio File: district.M2TS
Video File: district.M2TS
Video AR Mode: 4
Video AR Value: 1.777778
Video Zoom Percent: 0.500000
Scroll Position: 78
Active Line: 83
Video Position: 48024
[V4+ Styles]
Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding
Style: Riker,Arial,60,&H00FFFFFF,&H0300FFFF,&H00000000,&H02000000,-1,0,0,0,100,100,0,0,1,2,2,2,0,0,100,1
[Events]
Format: Layer, Start, End, Style, Name, MarginL, MarginR, MarginV, Effect, Text
Dialogue: 0,0:04:55.25,0:04:57.59,Riker,,0,0,0,,I think they must fix that \Nand they must go.
Dialogue: 0,0:04:57.75,0:05:00.21,Riker,,0,0,0,,A virus, a selective virus.
Dialogue: 0,0:05:00.96,0:05:02.05,Riker,,0,0,0,,Release it near the water.
Dialogue: 0,0:05:02.26,0:05:05.34,Riker,,0,0,0,,They must just go. I don't know where,\Nbut they must just go!
Note the 100 on the MarginV was 60 last time. Trying to crank it up a bit and see if it still shows on the bottom.
JR
Old 18th July 2015, 00:32   #806  |  Link
can you please first check if the possion on of the subs is correct when the file is played on your PC?
Old 7th August 2015, 17:14   #807  |  Link
amayra
Quality Checker
amayra's Avatar
XySubFilter Test 3.1.0.741
how about this you no release it XySubFilter Test 3.1.0.741
I love Doom9
Old 21st August 2015, 11:10   #808  |  Link
Tornado15550
With Google Code going read-only on the 25th of this month, will you be transitioning the project to Github or some other repository?
Tornado15550 is offline   Reply With Quote
Old 22nd August 2015, 15:56   #809  |  Link
amayra
Quality Checker
amayra's Avatar
this is the official repository :
https://github.com/Cyberbeing/xy-VSFilter
I love Doom9
Old 10th September 2015, 01:33   #810  |  Link
iakoboss7
iakoboss7's Avatar
hello, are you gonna release a new beta version with the latest changes after the previous one?
iakoboss7 is offline   Reply With Quote
Old 13th September 2015, 15:23   #811  |  Link
ashlar42
Pardon my ignorance but could somebody explain to me the high resolution rendering of xySubFilter as opposed to what xyVSFilter does? I am using xyVSFilter in order to have subs rendered on black bars in Kodi (DSPlayer version) while using madVR, I set "Renderer layout option" to 1920x1080 and I see text based subs (ie. SRT) rendered at native res. What am I missing?
Old 13th September 2015, 19:56   #812  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
If you're watching 1080p video on 1080p screen then subs will be rendered at native resolution (except chroma, which will be 4:2:0 as video). However when video resolution is lower than screen resolution (i.e. DVD), then, when using xyVSFilter you'll get subs rendered at low resolution which will look bad.
Renderer layout option only affects styles scaling. E.g. if you choose font size of 50 pixels - then it will be 60 pixels on 1920x1080 video, but 40 on 1280x720. For unstyled subs (SRT) using this option is a good idea (hope it will become default for them in future), except when videos have different aspect ratio. But with styled subtitles (ASS) it could have unpleasant effects.
Old 4th October 2015, 12:14   #813  |  Link
ashlar42
Are developers still working on xySubFilter? madshi would apparently be ready to work on black bars rendering for subs but there doesn't seem to be anyone working on xySubFilter
Old 4th October 2015, 20:06   #814  |  Link
madshi
There ever only was one dev, and from the looks of it, he might be gone. I've emailed him. If he doesn't show up, maybe I can hack something in to work around the missing features. No promises, though.
Old 5th October 2015, 10:50   #815  |  Link
ashlar42
Much appreciation flowing in your direction, madshi, even with no promises.
And by the way, if this project has been abandoned by its dev... am I right in understanding that there currently is not another actively developed subs filter?
Old 5th October 2015, 12:05   #816  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
There's also a libass, but it's one of the reasons why people are LOLing at VLC. Like the last time I used it it either corruped entire video or crashed because typesetting was too heavy.
Old 5th October 2015, 13:35   #817  |  Link
ashlar42
Yeah... well, at least, all this being open source, one can always hope that somebody capable enough will keep the candle lit.
Old 11th October 2015, 20:49   #818  |  Link
madshi
New build uploaded by cyberbeing (see first post in this thread) - thanks!
Old 11th October 2015, 22:38   #819  |  Link
steakhutzeee
steakhutzeee's Avatar
I'm using XySubfilter 3.1.0.705 (git caded62), what's last version? 3.1.0.744 (git 50985e9)?
steakhutzeee is offline   Reply With Quote
Old 14th October 2015, 11:27   #820  |  Link
Matching_Mole
Is it a key shortcut to load external sub files with XySubFilter as we can with MPC-HC (CTRL+L)? And if not, could this be implemented?
I use it all the time in MPC-HC to add subtitles to my Blu-ray on the fly (because they dont have one in my language, or because the muxed one are too large and too present on the screen). Now that madVr is able to use black border with XySubFilter, this is last piece that is missing for me to definitively outperform the internal sub rendrer of MPC.
Matching_Mole is offline   Reply With Quote
