23rd November 2015, 12:42 | #13721 | Link | |
Maybe the original DTS was wrong encoded or the original CD was dirty when ripped to wav, I don't think than the DTSParser was the culprit. Try to clean the CD and rerip the track.
25th November 2015, 17:10 | #13722 | Link | |
Life's clearer in 4K UHD
As a side note. Here's an interesting thing. If you encode the dts.wav file to flac. And then the flac file back to wav. The dts stream is still completely intact... Cheers
3rd December 2015, 09:03 | #13723 | Link | |
I wanted to get an 11:08.192 clip from a 1:52:59.136 AC3 from the 1:39:36.770 mark and after much trial and error I stumbled upon the combination of "-edit=1:50:44.939,-5976770ms" and "-5976770ms" to do so. With "-edit=1:50:44.939,-5976770ms" alone, the AC3 would decode up to 1:50:44.939. With "-5976770ms" alone, it would do so from 1:39:36.770 to the end, 1:52:59.136. Now is there a particular reason why trimming a track requires two options, in different formats no less?
eac3to %%a.ac3 %%~na.wav -edit=1:50:44.939,-5976770ms -5976770ms -full -no2ndpass Code:
-ms-in=5976770 -ms-out=6644939 Quote:
3rd December 2015, 09:30 | #13724 | Link | |
3rd December 2015, 16:32 | #13725 | Link |
1,260Kbps (using compression level 6)...
7th December 2015, 19:27 | #13726 | Link |
Madshi, could you please update dcadec in eac3to? The XXL not lossless warning seems to have been removed and as of November 27th it has reached version 0.1
7th December 2015, 20:10 | #13727 | Link |
The warning going away is just cosmetic though, so don't worry too much about it.
8th December 2015, 18:46 | #13730 | Link |
does it matter whether I compile and use the x64 or win32 one?
9th December 2015, 23:51 | #13732 | Link |
compared to a HDD, would running eac3to with 2 SSDs in raid mode 0 speed up remuxing blu-rays quite a lot? (reading and writing from the disk)
11th December 2015, 14:18 | #13733 | Link | |
I succeeded in building the libdcadec.dll but the .dll is painfully slow in decoding my dts steams. The libdcadec.dll that came with eac3to took about 2 minutes to decode the dts. With my own build it took about 9 minutes to decode the same dts. Are there any options in visual studio to set that influence the performance of the created libdcadec.dll? |
12th December 2015, 06:33 | #13737 | Link |
madshi, do you have any intention of including speedup/slowdown functionality for chapters? As far as I can see there are no chapter programs that let you speedup via CLI, so speeding up multiple files is a big hassle... since it is just a simple calculation, it should not be that hard to implement (I guess)... though I know chapter editing is not really eac3to's purpose, so I get it if you don't implement it...
on another matter, I'm gonna dig up a question I asked almost 2 years ago: Are you going to replace libaften with libav for ac3 encoding in the foreseeable future? last time I asked, you said you haven't gotten around to it... since libav is the best choice for ac3 encoding (apart from the official dolby pro encoder, which I guess can't be implemented in eac3to :P) it would be nice to have it directly in eac3to and not have to pipe it to ffmpeg every time... Last edited by Q-the-STORM; 12th December 2015 at 06:35. |
12th December 2015, 12:31 | #13738 | Link | |
- Load the .txt (Chapters OGM) or .xml chapters in UsEac3to. Also text subs .srt, .ssa or .ass are supported. - Ignore the eac3to message: "The format of the source file could not be detected. <ERROR>" - Click in the 'Auxiliary tools' -> 'SRT/.../TXT' - Select your desired conversion and 'Convert'
12th December 2015, 13:08 | #13739 | Link |
this seems to work for single files only... There are already a few programs out there that do that, I need it to convert multiple files at once, which is only possible if the either the GUI is able to read and convert multiple source files, or if there is a CLI, where I can use a for loop in cmd to process all files in one go...
12th December 2015, 14:29 | #13740 | Link |
I can add a option to process all files with the same extension in a folder.
Wait to a new version in UsEac3to thread. EDIT: done
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 12th December 2015 at 17:22. Reason: Add info |
eac3to |
