17th September 2010, 10:18 | #8501 | Link | |
Soneca
I already did as you advised, the file is corrupted can not play, see the photo below Media Info Quote:
17th September 2010, 13:54 | #8503 | Link |
@muhadi
you will have to slightly modify default ipod profile. Reduce level from 3.0 to 1.3 Code:
AVC(H.264/AVC) Media file format: MP4, "Memory Stick" video format File extension: .mp4, .m4v Profile: Baseline Profile Level: up to 1.3 Bit rate: up to 768 kbps Frame rate: up to 30 fps Resolution: up to QVGA (320 x 240) https://www.sonystyle.com.hk/ss/prod...wz_x1060_e.jsp @vaporizer uninstall that codec pack and install only required apps by ripbot264
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th September 2010 at 13:56. |
17th September 2010, 16:16 | #8504 | Link |
Error Encoding Only One BD Disc
Thank you for this very useful program, as well as the time you spend here answering questions.
I have read all of the posts for 2010. I cannot find a definitive answer to a problem I am having. I have one BD disc I cannot transfer to the hard drive. I am using AnyDVD HD version 6.6.8.3 to read the disc. Then RipBot264 version 1.16.1 to transfer it to a file. At the encoding stage I receive this error: “DirectShowSource: couldn't open file D:\temp\RipBot264temp\job1\video.mkv: The system cannot find the file specified. (D:\temp\RipBot264temp\job1\getinfo.avs, line 2)” The error message is correct. There is no such file in that directory. I do not have any other codecs installed. I have removed and reloaded all files ripbot264 uses. I have even reloaded the operating system. The mkvinfo.txt file says: “Error: The source file 'D:\temp\RipBot264temp\job1\video.mkv' could not be opened successfully, or retrieving its size by seeking to the end did not work.” The demuxlog.txt says: “eac3to v3.18 command line: "C:\Program Files (x86)\RipBot264v1.16.1\Tools\eac3to\eac3to.exe" "E:\" 1) 2: "D:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "D:\temp\RipBot264temp\job1\audio_English.dtsma.wav" -down16 7: "D:\temp\RipBot264temp\job1\7_subtitles_Undetermined_1080.sup" 8: "D:\temp\RipBot264temp\job1\8_subtitles_English_1080.sup" 9: "D:\temp\RipBot264temp\job1\9_subtitles_Spanish_1080.sup" 10: "D:\temp\RipBot264temp\job1\10_subtitles_Chinese_1080.sup" 11: "D:\temp\RipBot264temp\job1\11_subtitles_Korean_1080.sup" 12: "D:\temp\RipBot264temp\job1\12_subtitles_English_1080.sup" 13: "D:\temp\RipBot264temp\job1\13_subtitles_French_1080.sup" 1: "D:\temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="D:\temp\RipBot264temp\job1\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 1 video track, 4 audio tracks, 7 subtitle tracks, 2:12:11, 24p /1.001 1: Chapters, 28 chapters 2: MPEG2, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz (core: DTS, 5.1 channels, 24 bits, 768kbps, 48khz) 4: AC3, English, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 5: AC3, English, 2.0 channels, 224kbps, 48khz, dialnorm: -27dB 6: AC3, French, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 7: Subtitle (SRT) 8: Subtitle (PGS), English 9: Subtitle (PGS), Spanish 10: Subtitle (PGS), Chinese 11: Subtitle (PGS), Korean 12: Subtitle (PGS), English 13: Subtitle (PGS), French This subtitle conversion is not supported. <ERROR>” All other DVDs and BDs are transferred without error. |
17th September 2010, 16:56 | #8505 | Link |
chipps:
I suggested this as I read elsewhere it fixed the issue for someone. you might want to change your mpeg2 codec. there's also a work-around here http://forum.doom9.org/showpost.php?...postcount=8465 this is more likely what's causing your issue though http://forum.doom9.org/showpost.php?...postcount=8470 consider trying the same thing he did and see if it fixes it |
17th September 2010, 17:42 | #8506 | Link | |
leaving out the 'codec pack discussion': so the solution is to uninstall / not install directvobsub, as it is the problematic component here, right? maybe put a check of 'known problematic components' into the script which checks for haali, ffdshow etc. ? yes i know this list could never be complete and up-to-date, and so on. just a thought. |
17th September 2010, 17:47 | #8507 | Link |
Thanks. I tried the old version of AnyDVD HD. That did not help.
I do not see where I change from VC-1. Here is the log from ripbot: D:\>"C:\Program Files (x86)\RipBot264v1.16.1\tools\bepipe\bepipe.exe" --script "import(^D:\temp\RipBot264temp\job1\job1.avs^)" | "C:\Program Files (x86)\RipBot264v1.16.1\Tools\enc_aacPlus\enc_aacPlus.exe" - "D:\temp\RipBot264temp\audio.aac" --lc --br 131072 --mpeg4aac *************************************** BePipe by dimzon *************************************** Script used: # BEGIN import("D:\temp\RipBot264temp\job1\job1.avs") # END Scanning for Audio Stream... Found Audio Stream Channels=2, BitsPerSample=16, SampleRate=48000Hz Writing Header... Writing Data... 0% Done! ******************************************************************** * AACPlus v2 Encoder (using Winamp enc_aacplus.dll and nscrt.dll) * Coding Technologies encoder 8.0.3 * Build Oct 10 2009, 16:03:17 ******************************************************************** Input file: - Output file: D:\temp\RipBot264temp\audio.aac SampleRate: 48000 ChannelCount: 2 BitsPerSample: 16 Bitrate: 131072 ChannelMode: Stereo Engine: LC-AAC Tune For Speech: No PNS: No MP4 Output: No Encoding... Finalizing... Done D:\>"C:\Program Files (x86)\RipBot264v1.16.1\tools\avs2yuv\pipebuf.exe" "C:\Program Files (x86)\RipBot264v1.16.1\tools\avs2yuv\avs2yuv.exe" "D:\temp\RipBot264temp\job1\job1.avs" - : "C:\Program Files (x86)\RipBot264v1.16.1\tools\x264\x264_x64.exe" --crf 18 --stats "D:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 96 --frames 174329 --sar 889:1000 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --vbv-maxrate 20000 --stdin y4m --output "D:\temp\RipBot264temp\video.264" - : 2 y4m [info]: 720x480p 889:1000 @ 24000/1001 fps (cfr) x264 [info]: using SAR=889/1000 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [info]: profile High, level 4.0 D:\temp\RipBot264temp\job1\job1.avs: 720x480, 24000/1001 fps, 174329 frames x264 [info]: frame I:2211 Avg QP:13.93 size: 43985 x264 [info]: frame P:57936 Avg QP:16.91 size: 17643 x264 [info]: frame B:114182 Avg QP:22.40 size: 4023 x264 [info]: consecutive B-frames: 2.1% 20.3% 24.3% 53.4% x264 [info]: mb I I16..4: 21.0% 71.7% 7.3% x264 [info]: mb P I16..4: 3.1% 7.7% 0.7% P16..4: 28.8% 15.5% 7.5% 0.9% 0.9% skip:34.8% x264 [info]: mb B I16..4: 0.1% 0.6% 0.1% B16..8: 26.1% 5.8% 1.8% direct: 3.8% skip:61.6% L0:33.1% L1:39.1% BI:27.8% x264 [info]: 8x8 transform intra:69.3% inter:72.2% x264 [info]: coded y,uvDC,uvAC intra: 64.4% 84.4% 70.5% inter: 22.6% 22.1% 6.6% x264 [info]: i16 v,h,dc,p: 69% 25% 4% 2% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 19% 32% 4% 5% 5% 6% 5% 7% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 27% 12% 5% 9% 8% 9% 6% 8% x264 [info]: i8c dc,h,v,p: 57% 21% 14% 8% x264 [info]: Weighted P-Frames: Y:5.7% x264 [info]: ref P L0: 60.5% 16.5% 14.3% 8.2% 0.4% x264 [info]: ref B L0: 88.1% 11.9% x264 [info]: kb/s:1737.04 encoded 174329 frames, 89.17 fps, 1737.04 kb/s D:\>"C:\Program Files (x86)\RipBot264v1.16.1\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\Ken\Desktop\VTS_01_1.mkv" --title "VTS_01_1" --default-duration 0:24000/1001fps -d 0 -A -S "D:\temp\RipBot264temp\video.264" --language 0:und --aac-is-sbr 0:0 -a 0 -D -S "D:\temp\RipBot264temp\audio.aac" --chapters "D:\temp\RipBot264temp\job1\chapters.txt" mkvmerge v4.0.0 ('The Stars were mine') built on Jun 6 2010 16:18:42 'D:\temp\RipBot264temp\video.264': Using the AVC/h.264 ES demultiplexer. 'D:\temp\RipBot264temp\audio.aac': Using the AAC demultiplexer. 'D:\temp\RipBot264temp\video.264' track 0: Using the MPEG-4 part 10 ES video output module. 'D:\temp\RipBot264temp\audio.aac' track 0: Using the AAC output module. The file 'C:\Users\Ken\Desktop\VTS_01_1.mkv' has been opened for writing. 'D:\temp\RipBot264temp\video.264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 720/540. The cue entries (the index) are being written... Muxing took 22 seconds. ------------------------- Elapsed Time: 00h:35m:47s |
17th September 2010, 18:33 | #8508 | Link |
the codec settings are within the FFDshow config options. and your issue is with an mpeg2, that's why I was sayin try changing that. the vc-1 codec shouldn't be relevant (since it's mpeg2, not vc-1)
also make sure you're choosing the right video track (sometimes blurays have secondary video tracks for commentary / behind the scenes kinda stuff), I say this because I see information in your log about standard def video...which you shouldn't have since you're encoding a bluray if none of this is helpful like I said in that other post you can always just demux/remux yourself or wait for Atak to answer |
17th September 2010, 18:57 | #8509 | Link |
Thanks for the advice. This is a Blu-ray disc. I have transferred seven other Blu-ray discs without any problem using this same method so I assume it is something about just this disc. I just cannot figure out what it is so far.
18th September 2010, 10:50 | #8511 | Link | |
@Chipps
2) Do not demux ALL SUBTITLES. Select only one language @vaporizer you don't need directvobsub because ffdshow already can do the same! Trust me all codec packs are useless. Haali Media Splitter + ffdshow is all you need for conversion/playback!
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 18th September 2010 at 10:56. |
19th September 2010, 07:40 | #8513 | Link |
Hey guys I'm having a strange problem I hope one of you guys can help me out with..
I use DVBViewer to watch tv on my pc and all was fine but after running the newest ripbot I found that the video in DVBViewer goes blurry and the framerate appears to be lower. If i reinstall K-Lite codec pack then the issue is fixed, but as soon as I run Ripbot again the output in DVBViewer again becomes blurry. Anyone got any idea what ripbot is changing to make this happen? Thanks in advance! |
19th September 2010, 13:58 | #8514 | Link | |
I love your application regardless, was only suggesting it because I thought it would be a nice improvement for almost all users. Last edited by futurex; 19th September 2010 at 14:02. |
21st September 2010, 22:13 | #8515 | Link |
Thank you for this program! It came across my way while I was looking to convert mkv files with an uncompatible audio format to stream to my LG TV,or H264 files to mkv again for my TV.However,I am wondering is there is a batch function to the program that I am missing?I have 150 small files to convert and would like to do it with your program,but adding them one by one seems too painful... Thanks. Last edited by kiwi32; 21st September 2010 at 22:14. Reason: typo |
22nd September 2010, 05:42 | #8516 | Link |
I have a DVD - Das Boot - that defaults to German. It has an English version of the dialog. I can play it from the DVD using Windows Media Player. However, I cannot see where I select the English version in Ripbot264. Select Streams would seem to be the place, but it does not appear. What step am I missing?
22nd September 2010, 08:48 | #8517 | Link |
Has anyone tried Ripbot with Bluray 3D yet?
I've been using Ripbot for quite some time with regular Bluray movies and so far it has worked great to build my NAS home theater library. Now I want to start putting money into the Bluray 3D movies and was wondering if anyone has tried one and the feedback of how it went?
22nd September 2010, 09:56 | #8518 | Link |
@Chipps
22nd September 2010, 12:46 | #8519 | Link |
I have a problem that was discussed a couple of posts before. First the proceeding: I added the subtitles to the job, thereby converting from .sup to .sub. Then I assigned a language to the subtitles and started the conversion. Result: Selectable subtitles embedded in a mkv container are selectable in VLC Player, but are actually not displayed. For other mkvs (not created with ripbot) it works - so it's no VLC issue. Is this problem a known issue with the current version of RipBot? Thanks in advance |
22nd September 2010, 14:15 | #8520 | Link |
use MPC-HC
