13th April 2015, 17:18 | #13482 | Link |
Let me guess. You have mkv with DTS-MA and you want ripbot to automatically demux DTS-core during demuxing phase?
@ShogoXT It turns out that video has to be added to function as well according to this Code:
MFlow (clip source, clip super, clip vectors, float "time", int "mode", bool "fields", int "thSCD1", int "thSCD2", bool "isse", bool "planar") Code:
#Denoise LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\fft3dgpu\FFT3Dgpu.dll") LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\mvtools2\mvtools2.dll") LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\flash3kyuu_deband\flash3kyuu_deband.dll") super = MSuper(video) backward_vectors = MAnalyse(super, isb = true) forward_vectors = MAnalyse(super, isb = false) forward_compensation = MFlow(video,super, forward_vectors, thSCD1=500) backward_compensation = MFlow(video,super, backward_vectors, thSCD1=500) video=interleave(forward_compensation, last, backward_compensation) SetMTmode(6) video=FFT3Dgpu(video,precision=2).f3kdb SetMTmode(2) video=selectevery(video,3,1)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th April 2015 at 17:23. |
13th April 2015, 19:27 | #13485 | Link |
Is there any free DTS encoder? BTW. Why do you need DTS 1.5 mbps instead of AC3 640 kbps?
13th April 2015, 20:16 | #13487 | Link |
Tsmuxer is now a DTS encoder? Interesting...
13th April 2015, 22:19 | #13489 | Link | |
eac3to requires a external encoder: Code:
Encoding DTS <768kbps> with Surcode... Surcode DTS Encoder doesn't seem to be installed. |
13th April 2015, 23:05 | #13490 | Link | |
Im at season 6 now, and now a new problem has popped up on the sources. As before they play fine on MPC-HC, but now when put into Ripbot, there are sound out of sync issues. Source here I can manually go by ear and fix it with your set audio delay setting, but im wondering if I missed something else that would allow ripbot to take care of the audio sync automatically. Thanks again! EDIT: I tried to put in that script, now "avs2avi.exe has stopped working" comes up. Guess I was pushing my luck. EDIT2: Tried closer to the original script like this: Code:
#Denoise LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\fft3dgpu\FFT3Dgpu.dll") LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\mvtools2\mvtools2.dll") LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\flash3kyuu_deband\flash3kyuu_deband.dll") MPEG2Source("D:\Temp\RipBot264temp\job3\job3.d2v") super = MSuper() backward_vectors = MAnalyse(super, isb = true) forward_vectors = MAnalyse(super, isb = false) forward_compensation = MFlow(super, forward_vectors, thSCD1=500) backward_compensation = MFlow(super, backward_vectors, thSCD1=500) interleave(forward_compensation, last, backward_compensation) SetMTmode(6) video=FFT3Dgpu(video,sigma=1.5,mode=1,sharpen=0.2,precision=2).f3kdb SetMTmode(2) selectevery(3,1) Last edited by ShogoXT; 14th April 2015 at 03:46. |
14th April 2015, 17:01 | #13491 | Link |
Try without FFT3Dgpu. Use CPU version. Instead of encoding and waiting for avs2yuv to crash you can use AVSMeter to check avs processing stability.
15th April 2015, 08:09 | #13492 | Link | |
#Denoise LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\fft3d\FFT3Dfilter.dll") LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\mvtools2\mvtools2.dll") LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\flash3kyuu_deband\flash3kyuu_deband.dll") MPEG2Source("D:\Temp\RipBot264temp\job3\job3.d2v") super = MSuper() backward_vectors = MAnalyse(super, isb = true) forward_vectors = MAnalyse(super, isb = false) forward_compensation = MFlow(super, forward_vectors, thSCD1=500) backward_compensation = MFlow(super, backward_vectors, thSCD1=500) interleave(forward_compensation, last, backward_compensation) SetMTmode(6) video=FFT3Dfilter(video,sigma=1.5,sharpen=0.2).f3kdb SetMTmode(2) selectevery(3,1) Last edited by ShogoXT; 15th April 2015 at 08:11. |
15th April 2015, 14:31 | #13493 | Link |
Last attempt
#Denoise LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\fft3dgpu\FFT3Dgpu.dll") LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\mvtools2\mvtools2.dll") LoadPlugin("C:\Ripbot264\Tools\AviSynth plugins\flash3kyuu_deband\flash3kyuu_deband.dll") super = MSuper(video) backward_vectors = MAnalyse(super, isb = true) forward_vectors = MAnalyse(super, isb = false) forward_compensation = MFlow(video,super, forward_vectors, thSCD1=500) backward_compensation = MFlow(video,super, backward_vectors, thSCD1=500) video=interleave(forward_compensation,backward_compensation) SetMTmode(6) video=FFT3Dgpu(video,precision=2).f3kdb SetMTmode(2) video=selectevery(video,3,1)
16th April 2015, 01:21 | #13494 | Link | |
Il probably just use the settings I had before without the motion comp. I wonder why they dont have more plugin filters with motion comp already? Mdegrain didnt seem very good and filters like the dust family doesnt work with yv12 correct? Love some temporal denoisers, just a bit too much ghosting sometimes. Also I did make sure to reinstall to avisynth 2.6 RC 2, then put in the MT dll. Would Avisynth+ work better? Last edited by ShogoXT; 16th April 2015 at 01:33. |
17th April 2015, 23:51 | #13495 | Link |
RipBot UTF8
Hi! I need some help with the filenames after the encoding with RipBot. A example of that happens:
Before: 20150413 Bate Bola 1ª Edição HD Edited 10.mpg After: 20150413 Bate Bola 1¬ EdiþÒo HD Edited 10.mkv Thanks. |
18th April 2015, 12:00 | #13497 | Link |
I need help to automate the process, so that the RipBot save the name correctly with the special characters. I do about 30 daily conversions and I need to rename an average of 25 files every day.
RipBot is a great tool that made possible my hobby, and help me further and I would save time if I could find out how I can do that. I don´t know if I´m doing something wrong or it is a restriction of the software. Thanks. Last edited by emmaurilio; 18th April 2015 at 12:17. |
24th April 2015, 21:25 | #13498 | Link |
Using multiple CPUs?
Looking at building an encoding machine to take advantage of the scaling functions of Ripbot. I can get my hands on some cheap Xeon-based servers, ie. with dual Quad-core Xeons.
How well does Ripbot function on machines with more than one CPU? I know it scales pretty well with multiple cores/threads, but how about on a rig with multiple CPUs? |
24th April 2015, 21:56 | #13499 | Link |
It will work fine. All cores will be nicely saturated.
30th April 2015, 07:43 | #13500 | Link |
Demuxing Error
I keep getting the following demuxing error.....
eac3to v3.27 command line: "C:\Program Files\RipBot264 Version 1.18.1\Tools\eac3to\eac3to.exe" "D:\Videos\The Punisher Collection\PUNISHER_BD\" 1) 2: "C:\Temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "C:\Temp\RipBot264temp\job1\audio_English.core.dts" -core 5: "C:\Temp\RipBot264temp\job1\5_subtitles_English_1080.sup" 6: "C:\Temp\RipBot264temp\job1\6_subtitles_Spanish_1080.sup" 1: "C:\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="C:\Temp\RipBot264temp\job1\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks, 2 subtitle tracks, 24p /1.001 1: Chapters, 14 chapters 2: MPEG2, 1080p24 /1.001 (16:9) 3: DTS-ES, English, 6.1 channels, 1509kbps, 48kHz, dialnorm: -4dB 4: AC3 EX, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 5: Subtitle (PGS), English 6: Subtitle (PGS), Spanish Creating file "C:\Temp\RipBot264temp\job1\chapters.txt"... [a03] Extracting audio track number 3... [v02] Extracting video track number 2... [s06] Extracting subtitle track number 6... [s05] Extracting subtitle track number 5... [a03] Removing DTS dialog normalization... Any idea as to what I am doing wrong? |
