Old 10th August 2010, 03:18   #41  |  Link
roozhou
New build 24750 available.
1) Fixed a bug in bitstream parser. Now streams with seq_scaling_matrix are supported.
2) Added new option to h264_changesps: remove aud
roozhou is offline   Reply With Quote
Old 10th August 2010, 13:57   #42  |  Link
0028606
I have been trying to compile this on Mac OS X 10.6 for the last coulpe of hours but it keeps give errors. If someone could please explain the process as I'm at a loss I would be very grateful
Check Out All My Tutorials
http://instantitunes.wordpress.com/
0028606 is offline   Reply With Quote
Old 10th August 2010, 14:11   #43  |  Link
roozhou
What error did you get?
Plz apply my latest patch before you start.
Old 10th August 2010, 14:19   #44  |  Link
0028606
Yes I have applied patch with -
Cd ffmpeg
Patch p1 < ffmpeg_svn_r24573.patch
is this the correct way to do it?
When apply the patch I get FAIL for imx_dump_header_bsf.c
ffmpeg john$ patch -p1 < ffmpeg_svn_r24573.patch
missing header for unified diff at line 5 of patch
(Stripping trailing CRs from patch.)
can't find file to patch at input line 5
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|Index: ffmpeg.c
|--- ffmpeg.c	(revision 24573)
|+++ ffmpeg.c	(working copy)
File to patch: /Developer/ffmpeg/ffmpeg.c
patching file /Developer/ffmpeg/ffmpeg.c
can't find file to patch at input line 155
|Index: libavcodec/aac_adtstoasc_bsf.c
|--- libavcodec/aac_adtstoasc_bsf.c	(revision 24573)
|+++ libavcodec/aac_adtstoasc_bsf.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/aac_adtstoasc_bsf.c
patching file /Developer/ffmpeg/libavcodec/aac_adtstoasc_bsf.c
can't find file to patch at input line 177
|Index: libavcodec/allcodecs.c
|--- libavcodec/allcodecs.c	(revision 24573)
|+++ libavcodec/allcodecs.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/allcodecs.c
patching file /Developer/ffmpeg/libavcodec/allcodecs.c
can't find file to patch at input line 206
|Index: libavcodec/avcodec.h
|--- libavcodec/avcodec.h	(revision 24573)
|+++ libavcodec/avcodec.h	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/avcodec.h
patching file /Developer/ffmpeg/libavcodec/avcodec.h
Hunk #8 succeeded at 3903 (offset -1 lines).
can't find file to patch at input line 285
|Index: libavcodec/bitstream_filter.c
|--- libavcodec/bitstream_filter.c	(revision 24573)
|+++ libavcodec/bitstream_filter.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/bitstream_filter.c
patching file /Developer/ffmpeg/libavcodec/bitstream_filter.c
patching file h264_changesps_bsf.c
can't find file to patch at input line 890
|Index: libavcodec/h264_mp4toannexb_bsf.c
|--- libavcodec/h264_mp4toannexb_bsf.c	(revision 24573)
|+++ libavcodec/h264_mp4toannexb_bsf.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/h264_mp4toannexb_bsf.c
patching file /Developer/ffmpeg/libavcodec/h264_mp4toannexb_bsf.c
can't find file to patch at input line 986
|Index: libavcodec/h264_ps.c
|--- libavcodec/h264_ps.c	(revision 24573)
|+++ libavcodec/h264_ps.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/h264_ps.c
patching file /Developer/ffmpeg/libavcodec/h264_ps.c
Hunk #1 succeeded at 37 (offset 1 line).
can't find file to patch at input line 999
|Index: libavcodec/imx_dump_header_bsf.c
|--- libavcodec/imx_dump_header_bsf.c	(revision 24573)
|+++ libavcodec/imx_dump_header_bsf.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/imx_dump_header_bsf.c
patching file /Developer/ffmpeg/libavcodec/imx_dump_header_bsf.c
patching file Makefile
Hunk #1 FAILED at 285.
Hunk #2 FAILED at 595.
2 out of 2 hunks FAILED -- saving rejects to file Makefile.rej
can't find file to patch at input line 1032
|Index: libavcodec/mjpega_dump_header_bsf.c
|--- libavcodec/mjpega_dump_header_bsf.c	(revision 24573)
|+++ libavcodec/mjpega_dump_header_bsf.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/mjpega_dump_header_bsf.c
patching file /Developer/ffmpeg/libavcodec/mjpega_dump_header_bsf.c
can't find file to patch at input line 1045
|Index: libavcodec/mp3_header_compress_bsf.c
|--- libavcodec/mp3_header_compress_bsf.c	(revision 24573)
|+++ libavcodec/mp3_header_compress_bsf.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/mp3_header_compress_bsf.c
patching file /Developer/ffmpeg/libavcodec/mp3_header_compress_bsf.c
can't find file to patch at input line 1058
|Index: libavcodec/mp3_header_decompress_bsf.c
|--- libavcodec/mp3_header_decompress_bsf.c	(revision 24573)
|+++ libavcodec/mp3_header_decompress_bsf.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/mp3_header_decompress_bsf.c
patching file /Developer/ffmpeg/libavcodec/mp3_header_decompress_bsf.c
can't find file to patch at input line 1071
|Index: libavcodec/noise_bsf.c
|--- libavcodec/noise_bsf.c	(revision 24573)
|+++ libavcodec/noise_bsf.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/noise_bsf.c
patching file /Developer/ffmpeg/libavcodec/noise_bsf.c
can't find file to patch at input line 1084
|Index: libavcodec/options.c
|--- libavcodec/options.c	(revision 24573)
|+++ libavcodec/options.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/options.c
patching file /Developer/ffmpeg/libavcodec/options.c
patching file r10kdec.c
can't find file to patch at input line 1254
|Index: libavcodec/r210dec.c
|--- libavcodec/r210dec.c	(revision 24573)
|+++ libavcodec/r210dec.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/r210dec.c
patching file /Developer/ffmpeg/libavcodec/r210dec.c
can't find file to patch at input line 1298
|Index: libavcodec/remove_extradata_bsf.c
|--- libavcodec/remove_extradata_bsf.c	(revision 24573)
|+++ libavcodec/remove_extradata_bsf.c	(working copy)
File to patch: /Developer/ffmpeg/libavcodec/remove_extradata_bsf.c
patching file /Developer/ffmpeg/libavcodec/remove_extradata_bsf.c
can't find file to patch at input line 1314
|Index: libavformat/assenc.c
|--- libavformat/assenc.c	(revision 24573)
|+++ libavformat/assenc.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/assenc.c
patching file /Developer/ffmpeg/libavformat/assenc.c
can't find file to patch at input line 1330
|Index: libavformat/avienc.c
|--- libavformat/avienc.c	(revision 24573)
|+++ libavformat/avienc.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/avienc.c
patching file /Developer/ffmpeg/libavformat/avienc.c
can't find file to patch at input line 1534
|Index: libavformat/flvenc.c
|--- libavformat/flvenc.c	(revision 24573)
|+++ libavformat/flvenc.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/flvenc.c
patching file /Developer/ffmpeg/libavformat/flvenc.c
can't find file to patch at input line 1577
|Index: libavformat/isom.c
|--- libavformat/isom.c	(revision 24573)
|+++ libavformat/isom.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/isom.c
patching file /Developer/ffmpeg/libavformat/isom.c
can't find file to patch at input line 1589
|Index: libavformat/matroskadec.c
|--- libavformat/matroskadec.c	(revision 24573)
|+++ libavformat/matroskadec.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/matroskadec.c
patching file /Developer/ffmpeg/libavformat/matroskadec.c
can't find file to patch at input line 1666
|Index: libavformat/matroskaenc.c
|--- libavformat/matroskaenc.c	(revision 24573)
|+++ libavformat/matroskaenc.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/matroskaenc.c
patching file /Developer/ffmpeg/libavformat/matroskaenc.c
can't find file to patch at input line 1715
|Index: libavformat/mov.c
|--- libavformat/mov.c	(revision 24573)
|+++ libavformat/mov.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/mov.c
patching file /Developer/ffmpeg/libavformat/mov.c
can't find file to patch at input line 1736
|Index: libavformat/movenc.c
|--- libavformat/movenc.c	(revision 24573)
|+++ libavformat/movenc.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/movenc.c
patching file /Developer/ffmpeg/libavformat/movenc.c
can't find file to patch at input line 1782
|Index: libavformat/raw.c
|--- libavformat/raw.c	(revision 24573)
|+++ libavformat/raw.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/raw.c
patching file /Developer/ffmpeg/libavformat/raw.c
can't find file to patch at input line 1849
|Index: libavformat/riff.c
|--- libavformat/riff.c	(revision 24573)
|+++ libavformat/riff.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/riff.c
patching file /Developer/ffmpeg/libavformat/riff.c
can't find file to patch at input line 1894
|Index: libavformat/rmdec.c
|--- libavformat/rmdec.c	(revision 24573)
|+++ libavformat/rmdec.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/rmdec.c
patching file /Developer/ffmpeg/libavformat/rmdec.c
can't find file to patch at input line 1906
|Index: libavformat/utils.c
|--- libavformat/utils.c	(revision 24573)
|+++ libavformat/utils.c	(working copy)
File to patch: /Developer/ffmpeg/libavformat/utils.c
patching file /Developer/ffmpeg/libavformat/utils.c
This is the Error I can't get past
CC	libavcore/utils.o
LD	libavcore/libavcore.0.dylib
ld: warning: -read_only_relocs cannot be used with x86_64
LD	libavcodec/libavcodec.52.dylib
Undefined symbols:
  "_r10k_decoder", referenced from:
      _avcodec_register_all in allcodecs.o
  "_h264_changesps_bsf", referenced from:
ld: symbol(s) not found
collect2: ld returned 1 exit status
make: *** [libavcodec/libavcodec.52.dylib] Error 1
Old 10th August 2010, 14:36   #45  |  Link
J_Darnley
J_Darnley's Avatar
Cd ffmpeg
No, you don't need to strip any levels from the paths (-p0)
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 10th August 2010, 14:37   #46  |  Link
roozhou
I have uploaded the new patch (ffmpeg_svn_r24750.patch). Update to svn 24750 and apply the patch.
P.S. why did you use "p1"?
Old 10th August 2010, 14:46   #47  |  Link
0028606
I do not see 24750 on the svn linked
The answer to that one is short,
No idea why....
EDIT.....
I see it on the SVN now thank you
Old 10th August 2010, 19:24   #48  |  Link
b66pak
b66pak's Avatar
@roozhou thanks a lot...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note...
Visit The Land Of Dracula (Romania - EU)!
b66pak is offline   Reply With Quote
Old 15th August 2010, 23:03   #49  |  Link
J_Darnley
J_Darnley's Avatar
Hey all, I wanted to use this tool today so I decided to build it. It wouldn't apply on top of my other patches, and it wouldn't build on a clean source. So I decided to cut out the functional bits. You can get them here: http://users.telenet.be/darnley/ffmpeg/
These are from git format-patch and the ones from this thread start at 3. Not all the code is there yet
Old 16th August 2010, 08:07   #50  |  Link
roozhou
@J_Darnley
The first version of ffmpeg_svn_r24750.patch contains debug code in h264_changesps_bsf.c. It will dump extra data to files before and after modification. Please check out the latest version from svn or just remove two fopen-fwrite-fclose sections in h264_changesps_filter function.
Old 14th September 2010, 18:25   #51  |  Link
iwod
I just refer to my post here http://forum.doom9.org/showthread.ph...94#post1442894
I know it may not be your tools problem. ( More likely itunes problem ), but any guess as to why only one of the file could be transferred to iPhone while others can not.
It is very frustrating.
P.S - You ffmpeg build is simply AWESOME!!!
iwod is offline   Reply With Quote
Old 14th September 2010, 18:56   #52  |  Link
b66pak
b66pak's Avatar
run this line on the source file that after conversion don't work on iPhone:
ffmpeg -i my_file.mkv
and post the output log here...
_
Old 14th September 2010, 19:35   #53  |  Link
iwod
Well i manage to use MKVmerge to extract the Raw Stream and Audio, and then use MP4box to mux it back.
And it works perfectly fine using this method, with all my files.
So here is the log
FFmpeg version SVN-r24750, Copyright (c) 2000-2010 the FFmpeg developers
built on Aug 10 2010 00:58:46 with gcc 4.4.4
configuration:
libavutil 50.23. 0 / 50.23. 0
libavcore 0. 3. 0 / 0. 3. 0
libavcodec 52.84. 3 / 52.84. 3
libavformat 52.78. 1 / 52.78. 1
libavdevice 52. 2. 1 / 52. 2. 1
libswscale 0.11. 0 / 0.11. 0
[matroska,webm @ 00c69c30] max_analyze_duration reached
[matroska,webm @ 00c69c30] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 49.98 (269908
51/540000) -> 500.00 (500/1)
Input #0, matroska,webm, from 'Ch33.mkv':
Duration: 00:49:59.17, start: 0.000000, bitrate: N/A
Stream #0.0(eng): Video: h264, yuv420p, 848x480, PAR 213:212 DAR 71:40, 24.9
9 fps, 500 tbr, 1k tbn, 49.98 tbc
Stream #0.1: Audio: aac, 48000 Hz, stereo, s16
Stream #0.2(chi): Subtitle: [0][0][0][0] / 0x0000
Metadata:
title : Traditional Chinese
At least one output file must be specified
Old 14th September 2010, 20:05   #54  |  Link
b66pak
b66pak's Avatar
this will do the job:
ffmpeg -y -i Ch33.mkv -vbsf h264_changesps=fps=25000:1000 -vcodec copy -acodec copy -sn Ch33.mp4
_
Old 8th October 2010, 19:28   #55  |  Link
kla960
I have h.264 videos with mp3 audio as vfr in an avi container. But I need it as h.264 video with ac3 audio as cfr in a mkv or ts container.
Is it possible to add the ac3 codec to the patched ffmpeg version???
kla960 is offline   Reply With Quote
Old 8th October 2010, 21:13   #56  |  Link
J_Darnley
J_Darnley's Avatar
Yes, if you apply the patches (my patches at least) then compile as normal you can use any features of ffmpeg that would normally be present.
Old 19th December 2010, 14:06   #57  |  Link
0028606
can some please provide some advice i'm trying to build this on mac os x 10.6 with ffmpeg 0.6 source
I applied j_darnley patch
I keep getting this error -
CC	libavcodec/h261.o
CC	libavcodec/h261_parser.o
CC	libavcodec/h261dec.o
CC	libavcodec/h261enc.o
CC	libavcodec/h263.o
CC	libavcodec/h263_parser.o
CC	libavcodec/h263dec.o
CC	libavcodec/h264.o
libavcodec/h264.c: In function ‘fill_filter_caches’:
libavcodec/h264.c:2309: warning: initialization from incompatible pointer type
libavcodec/h264.c:2386: warning: initialization from incompatible pointer type
libavcodec/h264.c:2401: warning: initialization from incompatible pointer type
libavcodec/h264.c: At top level:
libavcodec/h264.h:1256: warning: ‘decode_mb_skip’ defined but not used
CC	libavcodec/h264_cabac.o
CC	libavcodec/h264_cavlc.o
libavcodec/h264_cavlc.c: In function ‘decode_residual’:
libavcodec/h264_cavlc.c:411: warning: suggest parentheses around comparison in operand of &
make: *** No rule to make target `libavcodec/h264_changesps_bsf.o', needed by `libavcodec/libavcodec.a'.  Stop.
does anyone know where I'm going wrong
Old 20th December 2010, 16:31   #58  |  Link
roozhou
New build 25887 is available.
Old 23rd December 2010, 22:35   #59  |  Link
MGSteve
Suppose a Win32 binary is out of the question? I don't compile stuff on my PC
MGSteve is offline   Reply With Quote
Old 24th December 2010, 02:32   #60  |  Link
7ekno
Nor follow links too well ... first post, the red writing under the SVN version is a direct link to the Win32 binary from SourgeForge
Tek
