3rd March 2009, 22:08 | #4401 | Link |
anime DVD nut
I just grabbed the newest version of RipBot and ffdshow, but I'm still having a strange issue.
I have some fansubbed HD anime .mkv files that I have been reencoding for streaming to various devices in my house. Most of the files convert just fine, but I've run into a couple where the audio doesn't come through. If I double-click the original .mkv file and open it in Media Player, everything is peachy. Audio and video both work just fine. If I open the exact same .mkv file in RipBot, everything seems okay (audio and video tracks both demuxed, listed and selectable), but I get no audio in the preview, and output files have no audio either. I'm really scratching my head on this one... |
3rd March 2009, 23:20 | #4402 | Link |
send me sample and i will investigate . 50 mb should be ok. Use www.mediafire.com
3rd March 2009, 23:54 | #4403 | Link | |
anime DVD nut
3rd March 2009, 23:58 | #4404 | Link |
dgsplit
4th March 2009, 03:11 | #4406 | Link |
Hi
I just installed ripbot on a quad core along with ffdshowMT 1.I am going from blu-ray to ipod resolution and am getting 65 fps, is this low ( i thought before it was over 100) 2.when i open task manager avs2yuv.exe is using 65% and x264_x64.exe is only using 25%. is this normal 3.one final question, i tried doing saw 3 blu-ray which is mpeg2 and it doesn't show ffdshow by the clock and the video is all screwed up when finished,i checked libavcodec is selected in ffdshow config under mpeg2 thanks |
4th March 2009, 03:20 | #4407 | Link |
н∂-ƒαиαтι¢
^ reinstall ffdshow: http://www.xvidvideo.ru/content/category/1/4/5/
but this time reset settings. also where did u get the mt build? Last edited by ~bT~; 4th March 2009 at 03:23. |
4th March 2009, 14:36 | #4409 | Link |
Veni, vidi, vici
Larger Blu-ray settings
I've used this program to convert many .mkv files into AVCHD discs that play on my PS3, what I wondering is if the blu-ray option could be expanded, say a value in the fixed size dropdown of about 23gb ( I know I can type this in manually, so that isn't very important) but what I'm more interested in is if support for LPCM audio could be added, so it didn't downconvert it to AC3?
I've authored a few blu-rays myself, but the process is much much more complex than the very easy process this program has given me to make AVCHD discs. In any event great work, I love the program. |
5th March 2009, 01:32 | #4412 | Link | |
What settings are you using for audio in Handbrake? Thanks.. Geoff |
5th March 2009, 01:36 | #4413 | Link | |
reinstalled with the link you provided and still all the same I got the mt build from the link in ripbot after i reset the settings what is supposed to be selected under h264/AVC in ffdshow settings |
5th March 2009, 02:06 | #4414 | Link |
I only do HD DVD or Blu Ray to DVD/BD 25. Everytime I have used a version 1.13 or later, I get out of sync audio. I think I remember that cut is used for the audio? When I use 1.12 I have always used off for the audio and has been in sync everytime (20+ now). Am I missing something?
I am going to try to save a encode by muxing the original audio from the disc to try and get in sync. I still have all the temp files from the last job if any particular file is wanted. Also, every disc I have done does not ff/rw (even with that jdobs fixclpi). If the disc is not processed by ripbot, and just muxed with TsMuxer then ff/rw is fine (under 23GB already). Last edited by nwg; 5th March 2009 at 02:09. |
5th March 2009, 07:36 | #4417 | Link | |
I think track 1 has to be aac for iTunes to recognise it. My Apple TV is connected to my amp via hdmi and the ac3 track is just passed through to the amp by the ATV. Last edited by topsham; 5th March 2009 at 08:01. Reason: Added extra info. |
5th March 2009, 12:58 | #4418 | Link |
Update on my syncing dilema. I found the audio on the original had no delay required so why the problem? The audio is about a second in front even with the AC3 track extracted from the original TrueHD.
Is there anyway I can put a manual delay in TsMuxer if I can work out the required amount. The BD is The Dark Knight |
5th March 2009, 21:38 | #4419 | Link | |
5th March 2009, 22:27 | #4420 | Link | |
