30th December 2009, 14:22 | #6421 | Link | |
here the sample http://www.mediafire.com/?zzjyiijczdm |
30th December 2009, 18:19 | #6422 | Link |
I just updated to the following:
Avisynth_258 ffdshow_rev3171_20091224_xxl MatroskaSplitter_1.9.355.21 mkvtoolnix-unicode-3.0.0 previously had: Avisynth_257 ffdshow_rev3119_20091027_clsid MatroskaSplitter_1.9.42.1 mkvtoolnix-unicode-2.9.9 (I have mkvtoolnix installed separately on my hdd, I didn't modify the one in the subfolder of ripbot) and now ripbot seems to hang up on gathering information or extracting frame. AVS2AVI.exe seems to be what's hanging up. anyone else have the same trouble? I'm tryin to determine which update caused the issue. edit: it's the ffdshow, went back to 3119 and everything works fine again Last edited by pacaveli211; 30th December 2009 at 18:33. |
30th December 2009, 20:40 | #6423 | Link |
Anyway to have ripbot just "bake in" some forced subtitles without re-encoding the video again? I forgot to do it the first time, so I now I have an already RB encoded vid that's missing important forced subs.. I'd like to get em burned in there without encoding the vid twice and losing quality.. Or will I have to start over? Thx
30th December 2009, 23:05 | #6424 | Link |
@pacaveli211
1) Do not use latest Haali Media Splitter because it does not see VC-1 streams in .m2ts container 2) for now do not use FFDshow newer than r3164!
30th December 2009, 23:16 | #6425 | Link |
thnx for the reply Atak.
anything else wrong with the new Haali? I hardly ever have anything in vc1, and even if so it'd probably be in a wmv, not an m2ts however I'm hoping the added x64 support might help encoding and such |
31st December 2009, 00:01 | #6426 | Link | |
31st December 2009, 01:08 | #6428 | Link |
it works ok in my 1.15.0 version.
31st December 2009, 01:36 | #6430 | Link |
it worked in 1.14.6 as well
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 31st December 2009 at 01:44. |
31st December 2009, 03:20 | #6431 | Link | |
HD-Fan
EDIT: I install MS .NET 3.5 like you recommended to another user who had this issue but it didn't fix it? More info: OS: Windows XP SP2 32-Bit RAM: 1GB DDR2 RAM
RipBot264 - Simple and easy to use GUI -> iPOD . iPhone . AppleTV . PSP . PS3 . XBOX360 . BluRay by Atak_Snajpera Last edited by MKVCrazy; 31st December 2009 at 03:31. |
31st December 2009, 09:04 | #6432 | Link |
Atak. I'm trying to rip tv episodes from a bluray, but for some reason, when I try to demux the first playlist in the list, ArcSoft reports an error and the demux fails. This is only happening with the first item in the list, the rest of the episodes demux fine and is happening on multiple discs. I'm not sure if it's the commands Ripbot is sending that are causing the issue or what. But its strange that its only happening on the first item all the time. It seems to fail right at the end before it says "Gathering Information."
For a temporary fix, is there a different way to demux and then convert to flac? I'm not really that experienced so I'm not sure how to do it manually. Edit: I demuxed the playlist manually with tsmuxer and put the .dts file into ripbot. When I did, it said "extracting DTS core." I assume this means I only have 5.1 audio now and no flac? Hopefully you can find out why arcsoft only fails with the first item in every list. thanks. Last edited by gohamstergo; 31st December 2009 at 23:20. |
31st December 2009, 11:06 | #6433 | Link |
HD-Fan
I installed .NET Framework 2.0 (now MeGUI works) and the encode started and also finished but it showed the BePipe error at the beginning. I also don't see the output file too. The speed was like 103 fps! Something is wrong?
EDIT: Nevermind. I kept on retrying with new files after installing .NET Framework 2.0. So in case someone else was looking for a solution to this problem, all the changes I've done since this error shows up were (in order): install .NET Framework 3.5 (didn't work when I only install this) install .NET Framework 2.0 and it worked after the two installs above. PS: I am converting at 124 fps !!! nice.
RipBot264 - Simple and easy to use GUI -> iPOD . iPhone . AppleTV . PSP . PS3 . XBOX360 . BluRay by Atak_Snajpera Last edited by MKVCrazy; 31st December 2009 at 11:29. |
31st December 2009, 12:16 | #6434 | Link |
Yes, I had... but I'm not using any codec pack, and I can't understand, why RipBot suddenly started to show these error messages, then they dissapeared, and now, again, I can't rip anything, only see MPC trying to open getinfo.avs
Tried to uninstall Avisynth, ffdshow, Matroska and install again - nothing changed... List of installed programs is here: http://img19.imageshack.us/img19/250/listay.png OS - Windows7beta (64bit). Maybe someone could tell any suggestions what problem could be here and how it can be solved? Update. Interesting. Moved extracted RipBot folder with subfolders to another drive, to base folder (it was on desktop before) - started to work again. Interesting, very interesting... Last edited by liudnux; 31st December 2009 at 20:39. |
31st December 2009, 18:01 | #6437 | Link | |
or actually play the file |
1st January 2010, 14:26 | #6439 | Link |
@Atak_Snajpera
Another nice feature easy to do.. is when you click on Properties (ex : setting the build in subs). it will reprocess script probably (Gaterring informations).. that's why it take some time before this window close . Can you just don't do this step is the user enter a second time in the Properties Window without modifing anything. |
1st January 2010, 15:23 | #6440 | Link |
What if user changes something manually in script? GUI must be always synchronized with script. Just in case.
