20th June 2020, 22:35 | #29483 | Link |
Is there enough hard drive space available? It passes the rendering process and aborted during the multiplexing. Seems storage related...?
21st June 2020, 02:54 | #29484 | Link | ||
Update: My System has become slow as I've done many tests with BD-RB with this file and some others that didn't Import well. Where Sync was lost after the 2nd "chapter" which is where commercials were cut from. By slow, which I've not encountered before, I mean..slow responses to Shut down, or Icon clicks. Even Right click on Quick Launch to get the menu for Task Manager. Without so many tests with BD-RB (TsMuxeR) my System is pretty quick in response. Which means a memory leak somewhere in the Processing of video. Yesterday I thought it odd, late night when I noticed it at first. Other than that, anything from you about the video, results?
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 21st June 2020 at 03:11. |
21st June 2020, 17:15 | #29485 | Link |
Does anyone here know how or if you can do 2 pass encoding with NVENCC? I've looked at it and FFMPEG, and I like it better (more control and faster). But I can't seem to see a way to do 2 pass encoding with it.
[Added] By the way -- I am really impressed with the speed and quality of the NVIDIA GTX-1660's encoding. All I can say is "Wow". [Added] Never mind. I did some reading and realize now that true 2 pass isn't an option in NVENC. It has it's own "2-pass" methodology that uses a lookahead scheme. Last edited by jdobbs; 21st June 2020 at 18:08. |
21st June 2020, 17:23 | #29486 | Link |
Hello. Thank you so much for replying to me again.
Yes. I can make BDs with only TMPGEnc Authoring Works. But when the video is fully rendered, it's not smooth. Of course, it's not always jerky, it depends on player. I'd like to make BDs which I can watch on any player. |
21st June 2020, 17:51 | #29488 | Link | |
You didn't include storage space free, so I wondered.
21st June 2020, 18:26 | #29489 | Link | |
You can do 2-pass in a few popular encoding programs, but the .stats file that is created is blank. The only way I've found to actually get a true 2-Pass is to run the first pass on the CPU, save the stats file and then use that during a second pass using NVENC which is a cumbersome process. Every other way I've encountered is no different than a 1-pass encode. mayby have the option of first pass cpu, or both passes gpu, even with first pass cpu i guess the total time verses all cpu will be less Last edited by Mike-uk; 21st June 2020 at 18:52. |
21st June 2020, 18:40 | #29490 | Link | |
Edit: ooops - these modes may apply for AVC only. Don't know if similar exist for HEVC. Last edited by Sharc; 21st June 2020 at 19:34. |
21st June 2020, 20:53 | #29491 | Link | |
I'm now going to see if it will do a nice IVTC via the way I normally do it, i.e., using x264 to recode with AVIsynth tools to do the IVTC work.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 21st June 2020 at 21:01. |
22nd June 2020, 01:23 | #29492 | Link |
Well, you are not going to like the results I achieved. The IVTC recode came out great. No audio issues either. The video was smooth. That means that IVTC can be accomplished. How to get BDRB to accomplish it is another story.
My steps were to use VideoReDo to separate the audio and video. x264 was used to recode the video, fed the video stream via AVISynth tools that did the IVTC. mkvmerge was then used to put the new video and audio back together, |
22nd June 2020, 02:05 | #29493 | Link |
Why would I not like that? I'm cool with separating the streams with my VideoReDo. You've left away what tools you used to do the IVTC.
23rd June 2020, 05:44 | #29495 | Link |
I completely spaced the abilities of MeGUI. It's doing a great job of reencoding the 720p 59.94 to 23.976 (zero frames left, and totally smooth playback and IN sync). Once I found that Analysis has some memory leaks, and made a copy of the AVS script I've been able to paste it..and use it skipping the Analysis..and zero memory problems (I thought using TIVTC.dll was the problem?). Which was causing my system to become very slow (Full RAM).
On another note, I'm attempting to use the script (MeGUI), though slightly modified, for BD-RB..and so far, it's not going well for final product BUT...is now rendering every time). For now, though, I'm able to finish my encodes of these episodes with the help of MKMERGE GUI..and should be able to make a sweet BD with BD-RB. Aaahhhh... Haha. I appreciate the look-see, MrVideo. That Cygwin looks interesting. I'll look into this more with BD-RB..perhaps a bug..still and not only with TsMuxeR?
24th June 2020, 09:12 | #29497 | Link | |
I just renamed the file, link should be working now. |
24th June 2020, 10:16 | #29498 | Link | |
2: So, just fix the config file and restart apache. |
