Old 6th June 2018, 15:34   #6221  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
MeGUI as such is more or less "portable" anyway, you just unpack it from a ZIP archive, and you should unpack it anywhere else, just not in the usual "Program Files" directories protected by the UAC. Where does it reside in your system?
I have it on a RAMDisc, F:\, with all my other audio-video programs. When I started learning about encoding it seemed like a good idea to have independent discs for the executable files (F:\), the source files (D:\), and the output files (C:\). Perhaps I was overthinking things .
Windows 7 in 64 bit is fine; if you don't use the 64 bit of MeGUI, the general version will use the 32 bit version of AviSynth (log reports "MeGUI: 2859 x86", and SEt's MT version is only available in 32 bit, so it's obvious).
Yes, I've been using SEt's () 32 bit MT version for some years, until trying to figure out AviSynth+.
BTW, "Prefetch(7)" is funny, are 7 threads the maximum for your specific script's memory consumption? And yes, Prefetch() is a function specific to AviSynth+ MT.
In the beginning I used Groucho2004's awesome AVSMeter () to test for the best MT configuration, and I found that on my quad-core system SetMTMode(3,7) gave me better results than SetMTMode(3,8). Not that I know why .
Open a script with nothing but Version() and see what it says.
It shows: AviSynth 2.60, build:Feb 20 2015 [03:16:45] 2000-2014 Ben Rudiak-Gould, et al. http://www.avisynth.org
PS Is MeGUI being a bit oddly when encoding sources indexed with Lsmash for anyone else?
For some reason, after one of the recent updates, the info displayed in the job queue takes quite a while to acknowledged an encode has started, even though the window displaying the encoding process is open and it's clearly progressing. The log queue continues to display "waiting" and appears to be frozen, because no jobs can be started until it changes from "waiting" to "processing", and a couple of time MeGUI has frozen completely "waiting" for a job to commence that's already running. It seems to only happen with Lsmash.
I've not experienced any freezing, but perhaps it takes a bit longer to proceed from "waiting" to "processing" lately. It's always taken much longer for LSmash scripts to load-begin processing than FFMS scripts on both my Win 7 64 bit systems, but I prefer it because, for whatever reason, FFMS sometimes "acts up" whereas LSmash doesn't.
LouieChuckyMerry is offline   Reply With Quote
Old 6th June 2018, 23:00   #6222  |  Link
Zathor
I do not know what is going on there. Could you please check if you do have a avisynth.dll in your MeGUI folder (in the root) when MeGUI is running and this dll is from 2018?
Old 7th June 2018, 00:07   #6223  |  Link
doomleox999
Originally Posted by Zathor View Post
OK, then I misunderstood it. You do not want to select specific streams you want to change the language of exsting streams. This is sadly not possible.
I found a way. You just have to change the default language in MeGUI settings, as simple as that.
doomleox999 is offline   Reply With Quote
Old 7th June 2018, 02:50   #6224  |  Link
LouieChuckyMerry
There's an AviSynth.dll in the root MeGUI folder and Windows Properties says the "Product name" is "AviSynth+ 0.1 (r2664, MT, i386)" and the "Date modified" is "28 March 18 15:04".
Old 7th June 2018, 04:06   #6225  |  Link
hello_hello
Sorry if that makes me feel a bit better. I suspected it was probably happening to other people, only nobody else had noticed yet.
When I tested old MeGUI versions, it seems the problem was introduced around the time the extra Avisynth info was added to the log file. That may be just co-incidence, but it took me a long time to notice too.
Maybe it's because my PC's old and it's a slow script and it's been a while since I encoded any 1080p video, but I don't recall such a large delay time between MeGUI starting encoding and realising it had started encoding. The progress window is really slow to respond to changes in encoding speed, so maybe it's related to that (I wish it was responsive enough to show you sudden changes in encoding speed instead of slow enough to show you something that probably happened 20 minutes ago).
This was what I meant though. 100 frames have been encoded and the job queue still hasn't caught up (job5 running).
I'm using an old XP compatible version of LSmash, but even so, this feels like something new.
PS. I just ran a short encode (100 frames) of the same video, only without any filtering aside from resizing in the script, and when it'd finished encoding the job queue still showed "waiting". When I tried deleting the job from the queue manually, MeGUI found a new excuse to crash.
Old 7th June 2018, 12:07   #6226  |  Link
hello_hello
Another feature request for Zathor.....
When you select an encoder preset, open the encoder configuration and then change something, upon clicking "okay" MeGUI asks if you'd like to save the changes to the preset. Not having clicked the "Update" button first, I'm usually pretty confident I don't want to save the changes to the preset, so would it be possible to add a "don't ask me again" checkbox to the message window?
The question seems rather redundant to me anyway, given there's an obvious update button for when you do want to update the preset, and 90% of the time I'd be making temporary changes to an existing preset rather than loading the defaults and starting from scratch anyway, and being asked all the time is $&#% annoying.
Old 7th June 2018, 23:32   #6227  |  Link
Zathor
OK, what is happening is that that avisynth.dll cannot be used by MeGUI. Therefore the script calls the system installed dll which is the old AviSynth from 2015.
The question therefore is why the avisynth.dll in the MeGUI folder is not autoloaded. How do you start MeGUI? With a double click on the MeGUI.exe?
Also avs+ needs the vcredist 2017 which you do not have installed. It should be copied by MeGUI but could you please try to install:
https://aka.ms/vs/15/release/vc_redist.x86.exe
Old 8th June 2018, 01:18   #6228  |  Link
VoodooFX
@Zathor
What about that error?
VoodooFX is offline   Reply With Quote
Old 8th June 2018, 10:56   #6229  |  Link
tebasuna51
tebasuna51's Avatar
Maybe MediaInfo found another subtitle corrupt here:
---[Information] Text
-[Information] ID: 7
-[Information] StreamOrder: 6
-[Information] Codec: S_TEXT/UTF8
-[Information] LanguageString: Portuguese
-[NoImage] InvalidArgument=Value of '4' is not valid for 'index'.
Try remux your mkv source with MkvToolNixGUI before, and repeat the MeGUI recode.
BeHappy, AviSynth audio transcoder, in Doom9 forums. NicAudio, BassAudio, audio decoders.
Old 8th June 2018, 14:34   #6230  |  Link
wiggaz
Hello,
I did few tests between the old version (2836) and the latest (2859), and ffmpeg is indeed slower.
We are talking about fps decimals but, since we enjoy every single increase, that's become significally important, I think.
Here's some logs:
1080p crf (first 2836 then 2859)
https://pastebin.com/iet3XFmg
576p 2pass (first 2836 then 2859)
https://pastebin.com/pMCsZuU8
What you think?
Thanks in advance
wiggaz is offline   Reply With Quote
Old 8th June 2018, 16:03   #6231  |  Link
LouieChuckyMerry
Happy Friday! I've downloaded and installed the above 2017 vcredist.
I've portable MeGUI in a folder on a RAMDisc and pinned to the Win 7 64 bit start menu. I tried double-clicking on MeGUI.exe but receive the same "No Function Prefetch" error, so it seems to still be reverting to the installed 2015 avisynth.dll.
Old 8th June 2018, 16:09   #6232  |  Link
LouieChuckyMerry
I paid extra attention when I started my most recent encode and, although it does seem a bit slower to get going, it changed from "waiting" to "processing" as it should. My system is Win 7 64 bit with 12GB RAM. How much RAM do you have? Perhaps it's simply an XP and-or RAM issue?
Old 8th June 2018, 19:27   #6233  |  Link
VoodooFX
Remuxing with MkvToolNix v23 didn't helped, only removing Portuguese subs solved error.
Old 8th June 2018, 23:04   #6234  |  Link
Zathor
Yes, here is log (after oneclick error I aborted audio job):
https://pastebin.com/gNijDJmS
btw I get same error " 4 is not valid for 'index' " when I edit x265 preset in oneclick and try to save it(clicking around presets error sometimes disappears, still I dunno why or when).
As you are able to reproduce it:
http://megui.org/megui_debug.7z
extract the content of eitehr the 32 or the 64 folder (depending on your MeGUI build), reprocude the error, close MeGUI & upload the log.
Old 9th June 2018, 18:15   #6235  |  Link
VoodooFX
Here you go:
https://pastebin.com/ixWEYDP1
Old 10th June 2018, 22:06   #6236  |  Link
Zathor
LouieChuckyMerry / hello_hello: Could you please try 2860? It should now properly detect that the included portable AviSynth is not used. Please try also if the MeGUI setting "log debug information" changes a thing (with the next restart).
Thanks, will have a look in the next days.
Old 11th June 2018, 15:20   #6237  |  Link
Statick
request:
I'd really like a way of accessing the input filename from within the OneClick encoder AVISynth script
specifically I want to access the .d2v file generated, which is always named after the input filename, and reference this in the script. something like %input_filename% would do the job, like this:
tfm(d2v="%input_filename%.d2v")
I'm sure there are other paramters that would be useful if exposed this way, but this is the only one I'm after!
Currently I have to edit the AVISynth profile for every single video I encode, which for several hundred videos is extremely long-winded and error prone
Statick is offline   Reply With Quote
Old 11th June 2018, 15:23   #6238  |  Link
hello_hello
Thanks for the effort!
Now you've made me feel bad for being the bearer of bad news.
[Warning] AviSynth Information
-[Information] AviSynth Wrapper
--[Information] Version: 1.0.2847.0
--[Information] Date: 06-05-2018
--[Information] Interface: 3
--[Information] File Version: 2.6.0.6
--[Information] File Date: 31-03-2015
--[Information] File Name: Avisynth 2.6
--[Information] File Path: c:\windows\system32\avisynth.dll
--[Information] AviSynth Version: AviSynth 2.60, build:Mar 31 2015 [16:38:54]
--[Information] AviSynth+: false
--[Information] AviSynth MT: false
--[Information] AviSynth Status: active
-[Warning] AviSynth portable
--[Information] File Version: 0.1
--[Information] File Date: 28-03-2018
--[Information] File Name: AviSynth+ 0.1 (r2664, MT, i386)
--[Information] File Path: c:\program files\megui\avisynth.dll
--[Warning] AviSynth Status: inactive - portable AviSynth build cannot be used. The loaded DLL is: c:\windows\system32\avisynth.dll
PS It makes no difference if the "log debug info" option is enabled/disabled.
Old 11th June 2018, 16:08   #6239  |  Link
is probably protected by the UAC: Windows doesn't allow manipulation of files in this directory branch without Administrator access rights.
That's why we keep recommending not to install MeGUI there, over and over ... or you would have to disable the UAC, which is a security risk.
Old 11th June 2018, 16:30   #6240  |  Link
Statick
I have "run this program as administrator" selected and it seems to solve all such problems, albeit that I have to click the "yes" prompt every time I open the program. I could be missing something though.
