View Poll Results: The prescribed method in this article is... | |||
The worst possible way to do it... | 2 | 66.67% | |
More difficult than it has to be... | 1 | 33.33% | |
Intended in the guides for the abolute n00b cuz even THEY would get it... | 0 | 0% | |
Or a start, but needs improvement. | 0 | 0% | |
Multiple Choice Poll. Voters: 3. You may not vote on this poll |
28th June 2008, 22:41 | #21 | Link |
I think I have this...
I think I have a solution, however, I've noticed that when using VirtualDubMod I get the following error message on the video I'm trying to convert...
MPEG: Anachronistic or discontinuous timestamp found in video stream 0 at byte position 73..., from .... to ..... This may indicate an improper join. I haven't joined anything so I'm not sure what this means... Could using DVD Shrink to convert the full movie into a single vob be causing this problem? |
28th June 2008, 23:06 | #22 | Link | |
@nitricpyro
You're multitude of problems regarding "Becoming Jane", including your stated difficulty using MPEGMediator, convinced me to purchase the R1 version and "see for myself": Quote:
The end result was a perfectly synchronized DivX-compressed video with no "extra frames" at either the beginning or the end... BTW - You stated that you ripped this Title using DVD Decrypter and DVD Shrink. In fact, as I speculated earlier, this Miramax release contains copy protection that neither of those programs can process. Therefore, would you please be good enough to explain this anomaly? Last edited by setarip_old; 28th June 2008 at 23:15. |
29th June 2008, 00:38 | #23 | Link | |
I've literally tried each of the following methods... DVDFab 5 - DVD Shrink - MPEG Mediator - DivX (out of sync audio but it has to be "DivX-Audio" for any codec Minute up front, 2 hours in back) DVDFab 5 - MPEG Mediator (again, has to be DivX-Audio and still has out of sync audio) RipIt4Me - DVD Shrink - MPEG Mediator - DivX (out of sync etc. ) RipIt4Me - MPEG Mediator - (Out of sync, extra time, jumpy video) I've even tried.... DVDFab 5 - DVD Shrink - VirtualDubMod - DivX - (out of sync) DVDFab 5 - DVD Shrink - Gordion Knot (all all it's jazz) - (out of sync) DVDFab 5 - Gordion Knot - DivX (out of sync) RipIt4Me - DVD Shrink etc. etc. etc. With Mediator it just seems to think there is a ton of extra data! I don't know why! Argh! This is why I'm so frustrated, things that should be working seem to not be. This seems to happen to about %30 of the videos I work on. Half the time I have to start the rip over because of an I/O error or something, or for some reason despite the settings I choosen the programs want to give me a 400 or so MB file when I'm looking for 4000 k or 4.3 Gb. Perhaps I should just format the computer and start over... I do have tons and tons of programs on here as well as tons and tons of codecs. I even got a video started today that seems to be More delayed at the beginning than it is in the middle or the end. Not progressive, like slowing adding up, just like somewhere it suddenly goes from 5600ms delay to 4250ms delay. Let me know if I can send you any logs, or whatnot, I've gotta have something wrong because I'm doing it right. Let me know. However, you brought up a question, if I rip with a program that can handle the copy protection (ie. RipIt4Me or DVDFab 5) and then run it through a program that can't handle it, like DVD Shrink, will it "not get past the protection?". Am I undoing the bypass by running it through DVD Shrink? And why is it ALWAYS perfectly synced when I just play it through DVD Shrink? Last edited by nitricpyro; 29th June 2008 at 21:46. Reason: Corrected name of program |
29th June 2008, 03:45 | #24 | Link | ||
BTW - The correct name of the program is MPEG Mediator (v.1.5) |
30th June 2008, 00:23 | #25 | Link | |
Also though, RipIt4Me doesn't have the option to rip to a single vob for use with VirtualDubMod neither does DVDFab 5. MPEG Mediator and Gordian Knot can handle multiple files but when I've got an episodic dvd I can't rip "Movie Only" and get everything I need. Without DVD Shrink I don't know how to find which files go with which episodes if I rip the "Full-DVD" or an ISO. Could you explain how I would go about this without using Shrink? |
30th June 2008, 00:48 | #26 | Link |
I've provided you with a valid (and personally tested) concept of ripping the "Becoming Jane" Region 1 DVD with RipIt4Me and converting to DivX-compressed .AVI using MPEG Mediator (v.1.5).
You are now seeking information regarding other situations. Perhaps, another poster will provide it... Last edited by setarip_old; 30th June 2008 at 01:02. |
30th June 2008, 04:49 | #27 | Link | |
Very True
I am in the process of reinstalling everything now on my other machine. When I get done I will try again with your method and either search or create another post inquiring how to get the other stuff off the disk (extras etc.) without using DVD Shrink. I'm actually having this problem with approximately 60 of my movies, some newer, some very old which is why my questions are not revolving around "Becoming Jane" explicitly. You're success however makes me almost positive it's simply a problem with my system not the methods I've tried. Will post later. |
30th June 2008, 06:59 | #28 | Link | ||
1st July 2008, 03:56 | #30 | Link |
Update
So here is the verdict...
I have reinstalled everything (that belongs on my computer NOT everything I have for ripping etc.) In terms of video encoding.... Doing a clean install of only, RipIt4Me (which includes DVD Decrypter and FixVTS) DVDFab 5 and MPEG Mediator 1.5 and then the DivX 6 codec. I was able to produce a poor quality DivX encoded video of "Becoming Jane." SOME of my problems were coming from other programs or installed codecs that were interfering with the processes of MPEG Mediator 1.5. Now let me explain... the video was indeed perfectly in sync. I'm impressed. However, Mediator doesn't do a very good job of producing the Superior Quality DivX encoded films that i'm looking for. The inability of the program to do multi-passes, the "Joggy" pictures stream, and the lack of features leaves a bit to be desired. I don't like MPEG Mediator, I'm looking for something better. You might recall that I originally got the movie to work, albeit with 1:42 blank at the beginning, and 2 hours blank at the end, but the part in the middle was "joggy" when playing (and trust me not because of my system, My Media center PC is a bit old, but this machine that I'm testing this stuff on is a Core2 Quad with 2 Gigs Ram (for work).) which can only mean Mediator encoded poorly. Now as for my other questions posted. I'm here looking to learn, not simply to figure out a single issue and then sit idle waiting for another issue to arise. This entire week I've been working on numerous movies, with numerous issues. Perhaps 20 different encodings in the past 4 days alone from movies ranging from 1982 to 2007 with different issues than this specific film. I'm trying to understand the whole process, the ability of these programs as well as the underlying principles, current copy protection schemes, the "masters" methods etc. I ask specific questions for specific reasons, I'm looking for specific answers. ... Pulldown Flags... thats the stuff I'm looking for. |
1st July 2008, 04:04 | #31 | Link | |
2) Now you know that you've properly cleaned up your system Therefore, why don't you now once again try using AutoGK? BTW - I see you've now used a different DivX codec with MPEG Mediator (v.1.5). You might want to try the previously used "Fast Motion" codec set to 1500Kbps or so... Last edited by setarip_old; 1st July 2008 at 04:10. |
1st July 2008, 04:26 | #32 | Link | |
In other words, i'm looking to learn to fish, not to be fed. By the way, MPEG Mediator totally botches "The Water Horse", (even after the clean install) the sound starts correct but is completely off by the end. This is why I've been trying DVDFab 5 - VirtualDubMod and have posted respective questions in other posts. |
1st July 2008, 20:31 | #33 | Link |
Problem Solved
After running a few encodes last night I have discovered that my original problem was the way in which I used (or didn't use) the Pulldown Flags for the audio.
Typically I have been using the prescribed method found on the ripping tab in Gordian Knot... I.E. "...If "Framerate" is 29.970 (NTSC) and "Video Type" is FILM at a percentage higher or equal to 95% check "ForceFilm" in "Field Operation", otherwise make sure it is NOT checked... ... Thanx to Jackei for the best decoder available!" On some films where the audio delay is not reported correctly (I.E. Becoming Jane, The Water Horse, and others I haven't checked) ignoring this warning and selecting "Honor Pulldown Flags" worked like a charm. |
1st July 2008, 21:42 | #34 | Link | |
Actually, running Honor Pulldown Flags versus Force Film does not change the duration of the audio or video streams and so cannot change audio sync. However, choosing Ignore Pulldown Flags *can* affect the audio sync, and that is why you have to be very careful when using VirtualDubMod to decode MPEG2.
2nd July 2008, 02:50 | #35 | Link |
Okay, I'm confused again, when I originally ran the encode I used the "Forced Film" option in the version of DGIndex 1.4.3 that comes with the Gordian Knot "pack" and the video was out of sync with the audio. When I use Honor Pulldown Flags it is in sync. What is the difference between these that would (perhaps in this instance only) change the sync of the completed DivX? Is it the version of DGIndex (1.4.3) I was using?
audio issues, divx, dvdshrink, sync, vstrip |
