22nd December 2015, 13:34 | #34801 | Link | |
22nd December 2015, 16:21 | #34804 | Link | |
for the record...with the HDR feature now working I think the image at 400 nits looks great!. Thank you for your efforts. |
22nd December 2015, 16:24 | #34805 | Link |
sending 4:4:4 and getting 4:4:4 are two totally different things.
samsung is well know for the 60 hz limitation and for the broken 23p limitation for the not that expense screens too. but if they fix it fine by me and about time after how many years? |
22nd December 2015, 21:38 | #34806 | Link | ||
Visual Novel Dev.
Thanks for all the help! I do not observe the noise in every anime I watch, but in some there is some noise, and it becomes visible, and kind of distracts me, because I enter a thinking mode where I ask myself if it could not be repaired. Then I think that it was the original design that had the noise in there. About the bit depth of the material, it is either 8 or 10 bit, where my monitor, LG Display LP173WF4-SPF1 is 10 bit (I think I remember reading this in a review (?) ). It is totally true that some anime do not show even the least amount of noise with error diffuse 2, but Fate series seem to have quite a big amount of noise in some scenes (why?). Thanks for all the help!
22nd December 2015, 22:15 | #34807 | Link |
they simply add noise because they wanted to let a scene looks noisy.
and are you sure it is a LP173WF4-SPF1 ? that would mean it is a 700 CR 6 bit AH IPS panel (first 6 bit IPS i have ever heard of) http://www.panelook.com/LP173WF4-SPF...ter_21056.html you are maybe able to reduce the noise by setting the bit deep to 6 in madVR and you may avoid double dithering but maybe not. edit: and yeah a 6 bit panel can look a lot more noisy in dark scene than a 8 bit panel. |
22nd December 2015, 22:29 | #34808 | Link |
So what is the correct setting option should i put? native bit depth 6 or 8?
a i can see difference with better quality at 8 but maybe i´m wrong what FRC doe?
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500 Windows 8.1 Pro x64 |
22nd December 2015, 22:30 | #34809 | Link | |
Same for DX11, no image changes, just another software path that may or may not work better. Have you tried Windowed Oveay? (Requires both FSE and DX11 disabled).
madVR options explained |
22nd December 2015, 22:34 | #34810 | Link | ||
i have only one screen with FRC and it does a poor job with it. Last edited by huhn; 23rd December 2015 at 09:20. |
22nd December 2015, 22:35 | #34811 | Link | |
FRC flickers the pixel color between different 6-bit values in order to look like an 8-bit color the panel cannot display. This is not the cause of the noise you see (that is in the source) but it can make it more visible.
22nd December 2015, 23:06 | #34812 | Link | |
23rd December 2015, 00:49 | #34813 | Link | ||
So what is my best option for watching movies with MadVR? I know the UN50JU6500 does have 24p judder but I dont notice it. Should I play all files at 60hz while passing 4:4:4 without MadVR changing the refresh rates, or do I let MadVR choose the proper refresh rate and dealing with not passing 4:4:4? Again this is all in 1080p. My main concern about it not passing 4:4:4 at 23hz is that I am calibrating my screen and creating a 3D LUT for MadVR, so Im trying to decide what best screen mode to create it with. Either not passing 4:4:4 at 23hz and have full control of my color and white balance, or passing 4:4:4 at 60hz in PC mode but having little control over fine tuning the screen. Im just trying to get the best overall experience with what I can work with. |
23rd December 2015, 01:51 | #34814 | Link | |
if you didn't notice the judder issue at 23p than you shouldn't notice it at 60 hz because it is the same so you could disable smooth motion but i would get crazy without it. |
23rd December 2015, 06:56 | #34816 | Link |
Only you can judge. What looks better to you?
23rd December 2015, 09:46 | #34817 | Link |
Can someone give me a heads up on how filepath is used? Can it be used to cover all files under that directory and all sub directories? Also does it work with network shares? If not I'd like to have support for those.
If (filepath = "c:\users\admin\desktop") "profile" |
23rd December 2015, 10:21 | #34818 | Link | |
filePath, fileName, fileExt e.g. "c:\movie.mkv", "movie.mkv", "mkv", _wildcards_ supported so use if (filepath = "c:\users\admin\desktop\*.*") "profile" |
23rd December 2015, 11:06 | #34820 | Link |
i test both network and local paths - all working fine.
p.s. \*.* - shall not be the spaces between backslash and asterisk (and before backslash too) p.p.s. and no success with non ascii symbols in path! - to madshi Last edited by SweetLow; 23rd December 2015 at 11:23. |
