4th January 2019, 21:22 | #241 | Link | |
SuperVirus
5th January 2019, 00:32 | #242 | Link | |
@Mosu
version 30 has a serious bug Quote:
5th January 2019, 00:36 | #243 | Link |
MKVToolNix author
Thanks for bringing it to my attention. I'll look into it tomorrow.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
5th January 2019, 03:40 | #245 | Link |
Matroska find' ich toll
Nice gif :-)
I believe you, but maybe it helps Mosu to identify to issue faster when he knows with small files seems to work. I had added editions before and after and insert a chapter to this edition. Then I used the save item from the main menu and also try the "save in...." item but the files size don't changed. |
5th January 2019, 15:01 | #246 | Link |
MKVToolNix author
I can reproduce the problem if the file was created by Handbrake. I cannot reproduce such a problem with files created by MakeMKV, ffmpeg or mkvmerge. I haven't investigated yet what the difference is with Handbrake's files. If you want to be kept up to date, follow the issue I've opened.
As a workaround you can remux with mkvmerge before editing chapters.
5th January 2019, 15:56 | #247 | Link |
MKVToolNix author
I've just committed a fix for the regression (v29 was ok; the problem was introduced during the implementation of appending chapters to open tabs for v30). I'll likely release v30.1.0 later today or tomorrow.
5th January 2019, 17:30 | #248 | Link |
MKVToolNix author
Like I've stated above, the problem's already been fixed. The determining factor wasn't Handbrake vs. mkvmerge, but whether the source file contained chapters or not.
5th January 2019, 17:39 | #249 | Link | |
MKVToolNix author
MKVToolNix v30.1.0 released
Hey,
due to an unfortunate bug in v30.0.0 that caused the GUI's chapter editor to truncate Matroska/WebM files to a few KB, I have to release v30.1.0 today. This release also implements a workaround for dragging & dropping not working on macOS with Qt 5.12 (due to a bug in Qt). Nothing has changed for package managers since v29.0.0. Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG & Linux AppImage and the source code. The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available over the course of the next couple of hours. Here are the NEWS since the previous release: Quote:
5th January 2019, 17:40 | #250 | Link | |
I tested with 30 rev 006 and work now without the bug Edit.... You were faster to post than I was |
5th January 2019, 20:39 | #251 | Link |
Anime addict
Hi Mosu, I uploaded video (at your FTP server) with issue in GUI when spanish language is set. With this problem is imposible to use the options of program. Regards.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
5th January 2019, 20:56 | #252 | Link |
MKVToolNix author
Well, your translations of some of the strings are too long. Try to make them shorter. Qt cannot wrap labels for checkboxes etc; therefore the minimum width of the right panel is however long the longest text shown in a single line.
5th January 2019, 21:09 | #253 | Link |
MKVToolNix author
BTW, your screen resolution is extremely low. As I've stated in other places, I don't support extremely low resolutions simply because I don't have the time to support every possible hardware out there. With Spanish as the language and the default font size of 9 points, the preferences dialog fits nicely into 975x535 pixels (including the title bar), which I consider to be good enough.
As with anything Open Source, if someone who cares about really low resolution wants to take this type of problem on and improve it: sure, knock yourself out! I'd welcome patches.
5th January 2019, 21:16 | #254 | Link | |
Anime addict
EDIT: If I can not see it, is really difficult to shorten the captions because horizontal scroll bar dont work properly. I uploaded other video in HD. EDIT2: If the size of the preferences window is enlarged, could not it be compensated?
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 5th January 2019 at 21:28. |
5th January 2019, 21:36 | #255 | Link |
MKVToolNix author
Uhm, if your desktop is larger than the window you've shown in the video, then just make the whole preferences window bigger.
5th January 2019, 21:41 | #256 | Link | |
Anime addict
Solved, although the resizing of that window could be automated according to the length of the content? Thanks. EDIT: The translations are what they are, it is not my fault that my language uses more characters to express something that is shorter in English.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 5th January 2019 at 21:48. |
10th January 2019, 06:22 | #258 | Link |
Resizing the GUI window seems weird. Minimum window size is 1152 x 715 - shorter than that and I lose the buttons and file entry box at the bottom.
Is there a minimum height for the mutliplexer/input/properties element? It won't shrink to less than 50% the height of the desktop. Using 30.1.0 on Windows 10/1803 64bit, 1080p desktop, and dpi is set to 100%. |
10th January 2019, 12:38 | #259 | Link | |
And would it be possible for the description on videohelp to also include that bug reports should be posted on the project's issue tracker where they are actually taken care of? |
matroska |
