Old 13th June 2008, 16:52   #101  |  Link
Ranguvar
Ranguvar's Avatar
Originally Posted by Razorholt View Post
Are you using Trellis 2 ?
Why? Does it help, or hurt PsyRDO?
Ranguvar is offline   Reply With Quote
Old 13th June 2008, 17:00   #102  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
Originally Posted by Dark Shikari View Post
Trellis 1 probably is not the best idea with this because that means the quantization that x264 chooses is not the quantization that psy RDO looked at in mode decision. Therefore, unless its demonstrated that this isn't a real issue, deadzones or trellis 2 are probably a better idea.
Trellis 2 is not a bad thing at all with psy RD; the problem before was that it encouraged blurring because RD would often prefer blurrier modes, and trellis would generate blurrier modes. But now, RD prefers *less* blurry modes.
Trellis 2 sharpen the picture. What settings you had? Trellis 1 or were you using deadzones?
Razorholt is offline   Reply With Quote
Old 13th June 2008, 20:26   #103  |  Link
gav1577
gav1577's Avatar
I find low deadzones usually inter 6 intra 6 work great for me
gav1577 is offline   Reply With Quote
Old 13th June 2008, 21:23   #104  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Yes I am using Trellis 2, and SubME 7, when I can afford the speed hit.
I did Princess Mononoke the other day, a nice high quality soft-telecined DVD9 source.
I did a very light script with light fft3dgpu(sigma=1), Toon() and gradfun2db(1.8). Then I encoded into Psy-RDO'd CRF19 with Multi-Hex SubME 7, Trellis 2, 16 refs, all the usual bells and whistles. It came out to 1.2 GB. That's really impressive to me
Muxing the original english and japanese 5.1ch AC3s, plus an english SRT netted a file size of just under 2gb. 9gb -> 2gb with utterly transparent quality (I actually preferred my version due to the denoise / warpsharp / line darkening / dithering). Now THAT's impressive.
Heck, the encoding only took a few hours. I think I was getting ~15fps on my Q6600 @ 3 GHz
~MiSfit
These are all my personal statements, not those of my employer :)
Old 13th June 2008, 21:38   #105  |  Link
TheRyuu
warpsharpened
Trellis 2 generally provides the best result of the different possible options you can use. I consider using trellis 2 to just be 'smarter' then using deadzones with it which does make sense.
I think people need to break out of the mentality that trellis is bad for keeping grain when isn't anymore with psy RDO. (no idea of anyone has this mentality to begin with... just making comments)
TheRyuu is offline   Reply With Quote
Old 13th June 2008, 23:57   #106  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Question: I see a lot of people talking about "using deadzones"
Aren't deazones always there? If you don't set them explicitly, they will simply default to "deadzone=21,11", right?
Old 14th June 2008, 00:04   #107  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
"Using deadzones" means not using trellis.
Old 14th June 2008, 00:08   #108  |  Link
LoRd_MuldeR
Software Developer
I see. thx.
Old 14th June 2008, 00:27   #109  |  Link
MasterNobody
Probably deadzones are used even with trellis=2 because trellis is used only for luma plane compression, and not used for chroma planes.
/* no trellis; it doesn't seem to help chroma noticeably */
MasterNobody is offline   Reply With Quote
Old 14th June 2008, 00:47   #110  |  Link
Dark Shikari
x264 developer
This is correct.
Also note that deadzones are used for RDO when trellis=1, and even in trellis=2, deadzones are used for B-frames unless b-rdo is enabled. Finally, even if RDO is on all frametypes, deadzones are still used for fast P-skip decision.
Old 15th June 2008, 23:54   #111  |  Link
gav1577
gav1577's Avatar
Are there any advantages in using trelis 2 over low deadzones Qualitywise with bitrates up to and above 4000kbps ?
Old 16th June 2008, 05:02   #112  |  Link
TheRyuu
warpsharpened
In my opinion, using trellis 2 will always provide a better looking result then using deadzones simply because it is smarter then deadzones. More so at lower bitrates, but I've seen it seems to consistantly look better any a number of bitrates I have tried.
Although you should always do the testing and decide for yourself as I am no expert on the matter.
Old 16th June 2008, 09:21   #113  |  Link
bokonon
This is correct.
Would a combination of --trellis 2 and low deadzones (6, 4) work favorably? OR would it work better with default deadzones (21, 11)
bokonon is offline   Reply With Quote
Old 16th June 2008, 13:44   #114  |  Link
Irakli
Irakli's Avatar
No, modify deadzones if and only if trellis is off. So, either use trellis 2 with default deadzones or modify deadzones if trellis is off.
Irakli is offline   Reply With Quote
Old 16th June 2008, 15:34   #115  |  Link
gav1577
gav1577's Avatar
Thanks for the reply will try some clips trellis 2 and see if there is any increase in quality the only thing about trellis 2 is i find it slows things down quite a bit
Old 17th June 2008, 18:54   #116  |  Link
Dark Shikari
x264 developer
Here's an encode of part of the original clip that inspired psy RDO in the first place. The flashing lights, the flat but gradient-filled background areas--all of them contrive to make encoding a nightmare for x264.
Old 17th June 2008, 20:18   #117  |  Link
yesgrey
I want to try this patch. I am thinking in using Megui with the DXVA-HD-HQ profile with trellis 2 and subme 7. The bitrate used will be 16000 or 22000 kbps. Will it be worth it? or due to the high bitrate the effect will be negligible... even using trellis 2 and subme 7 the encoded file will be DXVA compatible?
For using this is enough substituting the x264.exe by the patched one in megui directory, right?
yesgrey is offline   Reply With Quote
Old 17th June 2008, 21:08   #118  |  Link
Blue_MiSfit
Yep All you have to do is enable Sub ME >=6, and use MeGUI's preferences to select the patched .exe.
At that bitrate, subme7 will likely be totally unnecessary (guessing). It boosts the effectiveness of Psy-RDO, but is a lot slower as well.
You might try plain old FGO too, instead of Psy-RDO.
Just out of curiousity, why target a specific bitrate? CRF mode is wonderful
~MiSfit
Old 17th June 2008, 23:22   #119  |  Link
yesgrey
Because I want a specific target file size to put in dvds.
Old 20th June 2008, 16:02   #120  |  Link
bkman
Hi Dark Shikari,
A couple of observations from testing the psyRDO.
1.) It works noticeably better if employed in the first pass also.
2.) The picture seems to degrade much quicker between I-frames, making for a much more noticeable transition on a mid-scene keyframe.
Any ideas?
bkman is offline   Reply With Quote
psy-rd, psyrdo
