11th October 2020, 22:43 | #2021 | Link |
Has anyone tested a 3080 or 3090 GPU yet with HDR - SDR? I can only get MPC-BE (1.5.5.5433) with its internal filters to convert HDR properly.
If I use anything with LAV filters such as MPC-HC or kodi DSplayer I get extreme blown highlights when in Fullscreen windowed and FSE. However, it’s fine when windowed. This is with the older internal LAV and newer 0.74.1 via external. The attached pictures show the (1] excess highlights (not sure if this is the correct term) when fullscreen, (2) correction to normal when windowed, and (3) the correct conversion using MPC-BE’s internal filters. This happens with MPC-BE as well when I use LAV External with 0.74.1. However, its fine with the included internal filters. I’m using an EVGA 3080 FTW3 Ultra and this occurs with 456.38 and 456.71 drivers. I’ve also tried 8 and 10 bit, and RGB &YCbCr. Last edited by JonnyVee; 11th October 2020 at 22:54. |
11th October 2020, 22:54 | #2022 | Link | ||
In the latest drivers, the 1080 GTX gen are the last supported. Quote:
No I use my own values for the JVC rs2000. madVR has stopped working a long time ago re refresh rate optimisation here. I get no drop/repeat for more than 3 hours or more (often no drop/repeat after a while) with 442.74 + CRU, so I'm a happy camper. It's really nice to have the nVidial cPanel working normally again. Something had messed it up (I think one of the "bring 3D back" packages) and nothing could bring it back. If there is no downside, that alone was worth the upgrade to 2004. By the way, even with 442.74 I occasionally get the wrong HDR mode, but if I select HDR passthrough and then SDR pixel shader, I get the correct mode, contrary to the newest drivers that stay stuck in the wierg HDR null metadata mode.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 11th October 2020 at 23:16. |
11th October 2020, 23:21 | #2023 | Link | |
11th October 2020, 23:39 | #2024 | Link | |
Maybe we should go way back to 430.53... Unfortunately I can't easily test HDR metadata, if I could then I'd go back and try bunch of them. @JonnyVee, upload the images to an external image host and link them here.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 11th October 2020 at 23:41. |
11th October 2020, 23:41 | #2025 | Link |
Manni is correct as far as support when it comes to the Nvidia Studio Drivers. The Game Ready Drivers still offer full support all the way back to the 600-series:
"Effective April 12, 2018, Game Ready Driver upgrades, including performance enhancements, new features, and bug fixes, will be available only for desktop Kepler, Maxwell, Pascal, Volta, Turing and Ampere-series, as well as for systems utilizing mobile Maxwell, Pascal, and Turing-series GPUs for notebooks."
12th October 2020, 00:14 | #2026 | Link |
That's right I forgot he's using studio drivers. I've been using game ready lately cause I'm getting ready for Cyberpunk 2077.
12th October 2020, 00:30 | #2027 | Link |
So I just upgraded from my 1080 Ti to a 3080 and finally got around to testing MadVR. Good news, the issues with HDR on my 1080 Ti where I had to open the file twice to get HDR properly working has been resolved, although it only seems to work in fullscreen and any opening of the menu or looking at the status bar breaks it, but at least it switches really quickly. However, the card introduced really annoying micro stutters when playing at 23Hz mode (fullscreen windowed mode, in normal windowed it's fine). The stutter becomes significantly worse if you just move the mouse or start bringing up the menu. Switching to 60Hz with smooth motion does seem to mostly remove the problem, but I think it still stutters a bit. At 100Hz it's no longer noticeable to me. I believe the solution previous brought up for the 20 series for a similar problem was to set present ahead frames to 1, and this appears to have alleviated the problem. For now, this setting and watching at 60Hz instead is a good solution, but this really should not be a problem. It seems like it's always one step forward and two steps back with these things...
12th October 2020, 02:02 | #2028 | Link | |
https://imgur.com/e7S8uoQ https://imgur.com/Fucko6q https://imgur.com/pWeCDJ6 |
12th October 2020, 02:48 | #2029 | Link |
True but he has a point. Every update has that possibility to potentially break things that haven't been tested and given these changes are generally made for newer cards there's likely greater chance for breakage of functionality for older cards. Still on 1809 and 385.28 for exactly this reason, it just works.
12th October 2020, 02:59 | #2030 | Link |
Sure but the alternative point of view is that it should be a very well known quantity at this point. But I get it.
12th October 2020, 07:59 | #2031 | Link |
Really? Do you have multimonitors, e. g. TV + monitor? It didn't work here e.g. after sleep, I got blank screen on monitor if video played only on TV. This was flawless with 1607.
That's why I upgraded the driver when SamuriHL stated that 442.92 is good again.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 12th October 2020 at 08:01. |
13th October 2020, 14:28 | #2032 | Link | |
19th October 2020, 17:03 | #2033 | Link |
I think it will take some time till I get one ...
https://www.proshop.de/RTX-30series-overview And I am still open for RDNA2 |
20th October 2020, 12:40 | #2035 | Link | ||
Although I didn't have the SDR in HDR issue as before, but madvr doesn't change the metadata for sure when modifying the display peak nits (checked with the second code value on B8). So, what's next? Quote:
20th October 2020, 16:24 | #2036 | Link | |
20th October 2020, 17:27 | #2037 | Link |
I'm still recommending 456.71 which has proper metadata, good clocks, and a good audio driver. But I know not everyone agrees with that.
EDIT: FOR RTX CARDS cause who cares about GTX. LOLOLOLOL
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 20th October 2020 at 19:36. |
20th October 2020, 17:28 | #2038 | Link |
How would I know? That's what we try to find out...
20th October 2020, 19:08 | #2039 | Link |
You can’t make the same recommendation for GTX and RTX...
20th October 2020, 19:34 | #2040 | Link |
Then Klaus1189 needs to understand that and will have to split the list. Which makes maintaining it slightly more complicated. I'm not saying I disagree, just that it needs to be well understood that RTX and GTX cards should be treated as completely different.
