9th July 2010, 23:39 | #121 | Link |
Here is the script I am tring to load in meguie x64.I followed and installed meguie has I was told to.It seems the error it on line 43 which in veedub654 it lodas fine n i can see the script run.
loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\DGDecode.dll") loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\EEDI2.dll") loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\TDeint.dll") loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\tivtc.dll") loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\ColorMatrix.dll") loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\degrainmedian.dll") loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\aWarpSharp.dll") loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\VSFilter.dll") loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\decomb.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\UnDot.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\gradfun2db.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\hqdn3d.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\MaskTools.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\MT.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\MvTools2.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\FFT3DFilter.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\RemoveGrain64.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\Repair64.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\masktools-v2.0a41\mt_masktools-26-x64.dll") LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\masktools-v2.0a41\mt_masktools-25-x64.dll") import("C:\Program Files (x86)\AviSynth 2.5\plugins64\masktools-v2.0a41\masktools\LimitedSharpenFaster.avsi") Import("C:\Program Files (x86)\AviSynth 2.5\plugins64\avsi\insertsign.avs") d2vp = "j:\acx\cg\epi14\ep14.d2v" mpeg2source(d2vp,idct=7) srce=last interp=srce.separatefields().eedi2(field=-2) deinte=srce.tdeint(mode=2,edeint=interp) srce.tfm(d2v=d2vp,clip2=deinte,pp=4,flags=4) tdecimate(mode=0) colormatrix(d2v=d2vp) crop(4,4,-4,-4) LanczosResize(720,480) DeGrainMedian(limitY=5,limitUV=5,mode=3) LimitedSharpenFaster() Tweak(sat=1.13,cont=1.13,bright=-5) gradfun2db(1.2) sign1 = AVISource("j:\acx\saintdeath_blood_tag_upper_left.avi") insertsign(last, sign1, 10)
15th July 2010, 17:25 | #124 | Link | ||||
Just another User
Hi Folks,
15th July 2010, 17:51 | #125 | Link |
Mr. Sandman
AFAIK there are 64bit libs...
however, launch windows update and update your system. a personal advice... drop XP64 and get Win7-64
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 15th July 2010 at 18:12. |
15th July 2010, 22:58 | #126 | Link |
Fighting spam with a fish
I second this advice. There seems to be much more support for x64 being built into Windows 7 now.
Plus, with the sudden burst of tools being developed for the x64 platform, now is as good a time to upgrade as any. |
16th July 2010, 19:09 | #127 | Link |
Just another User
Thanks for the reply. I hope'd that I did not need to go for Win7 (not that much space on my System SSD )
Where can I find these MeGUIx64 libs?!! Here http://megui.org/auto/ the only one I find are the regular 32 bit! (http://megui.org/auto/megui-libs_0_3_5.zip) |
16th July 2010, 19:20 | #128 | Link | |
16th July 2010, 23:05 | #129 | Link |
Just another User
Thank you Zathor. Just one last question about this problem: is it possible (allthoug it is recommended to upgrade to Win7) to run MeGUIx64 on WinXp Pro x64? Then How (See previous post which lists installed VC++ Redistribuables)...
17th July 2010, 15:13 | #133 | Link |
Mr. Sandman
for the sake of mind sanity... win7 is lighter than vista... there is NO reason on this planet to buy Vista (the biggest MS Epic Fail (tm) after Windows ME...)
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! |
18th July 2010, 13:02 | #134 | Link | ||
edit KB971644 probably helped too edit2 everytime iuse ffms2.dll in an avs, megui just keeps grabbing more and more memory until crashes. i was able to rapidly open many(20+) instances of the same avs in mpc-hc without any problems besides the obvious performance hit and also tried running a bunch(20+) of x264 encodes at the commandline at the same time and also do not have a problem. ive confirmed this in both 7 and vista. it's easy to see, just "enqueue" the same job repeatedly and watch the ram. Last edited by quantum5uicid3; 23rd August 2010 at 13:07. |
20th July 2010, 00:48 | #135 | Link |
HD Encod3r
Hii there... I am using Win 7 Ultimate x64. I am planning to encode some HD stuff (The source is BluRay.)
I've downloaded a meGUI x64 and avisynth x64 (avisynth64_intel_3-17-10) according to the guide given above. İnstalled codecs on my system are: ffdshow_rev3507_20100707_clsid_x64.exe + MatroskaSplitter.exe. I've set H264 to ffmpeg-mt, and VC1 to libavcodec as video decoder. Sooo... I've just described that my MegUI x64 working perfectly with AVC Codec based m2ts files. Decoding, Encoding everything is fine. But, when I try to use a VC1 based m2ts files you can see what's going on: Btw, MPC x64 works fine with both of them (AVC and VC1 Movie....) Sorry If I'am hijacking your thread, but I was looking too much, and there is no satisfying answers.... Every suggestions are wellcome.... Cheerz |
20th July 2010, 01:02 | #136 | Link |
Mr. Sandman
the problem could be FFDShow VC-1 decoder (MPC has its own).
if that it's the case try another FFDShow revision. if it still doesnt work Index the m2ts with DGIndexNV (license required) or FFMS.
20th July 2010, 07:54 | #137 | Link |
HD Encod3r
Thank you very much.
My graphic card is HD5850 Ati Radeon. Previous, when I was googling this problem, I saw that DGIndexNV was developed for Nvidia Cards. I'll try with FFMS. Thank you Sharktooth. Hope that your health is well Cheerz. |
21st July 2010, 16:28 | #138 | Link |
Mr. Sandman
yes, dgindexnv requires an nvidia card.
however, you can get a second video card just for dgindexnv. check the supported cards list. there are some of them really cheap and even if they have a 16x PCIe connector they can be installed in a 4x slot too. (my health seems to be ok at the moment, thanks).
22nd July 2010, 15:48 | #139 | Link | |
One thing I'm not sure about is the VS2010 runtime - can someone point me to *exactly* what I should download for this?? Thanks |
22nd July 2010, 16:56 | #140 | Link |
Mr. Sandman
