31st October 2019, 19:46 | #1903 | Link | |
31st October 2019, 19:53 | #1904 | Link | |
I get nervous about actually tuning bitstream features based on ML, because we still lack in well subjectively-correlated metrics. VMAF is the least bad ever, but is SDR only. and the whole question of how individual frame metrics get aggregated into good metrics for interframe encoding remains barely examined. A mean of individual frame values isn't that useful for a clip that is more than a few second of a single shot. We've seen that AV1 shows better VMAF to MOS ratios than other codecs, which could be a result of this sort of curve fitting to one metric. It's generally true that the more a metric gets used, the lower its subjective correlation becomes, as encoders get increasingly tuned to the metric instead of to subjective ratings. |
31st October 2019, 21:21 | #1905 | Link | |
Though Google at least have been knocking on this particular door for at least a few years now, I figure they would not still be at it if they thought it could not be harnessed in a standardised way for a codec bitstream. Just to be clear, my own level of understanding of all of this is fairly amateur compared to experts on here - I mostly have an avid interest in codecs and more recently ML too (due to various ML optimisations in CG rendering and production fields). Last edited by soresu; 31st October 2019 at 21:23. |
1st November 2019, 19:59 | #1906 | Link |
Found an interesting slide deck called"Adaptive Optimal Linear Estimators for Enhanced Motion Compensated Prediction".
It goes over several things, though I'm not sure if they are alternative solutions or potentially additive improvements. Assuming they are additive, it discusses at least an average 11.5% BD rate improvement over baseline (presumably AV1 is the baseline). Link here. Last edited by soresu; 1st November 2019 at 20:01. |
2nd November 2019, 11:00 | #1907 | Link | |
It seems that single threaded performance has increased for SSSE3 but AVX2 over SSSE3 is very tiny. Still, both SSSE3 and AVX2 in single threaded mode are ~30 something % faster for 0.5.1 vs 0.2.1 BUT as I have already stated in my results, the CPU utilization during real-world multi-threaded decoding, eats ALL of the single threaded performance in case of Dua Lipa clip and most of the single threaded gain for the other clips for both SSSE3 and AVX2 versions. In other words, for the real-world multi-threaded decoding the absolute sum of gain and loss between 0.2.1 vs 0.5.1 is dead zero for Dua Lipa and so small for the other clips. Sorry, but I can't call this situation as progress after seven months, if overall multi-threaded decoding performance gain is zero.
2nd November 2019, 11:49 | #1908 | Link | |
Where can I can I find those executables of 0.2.1 and 0.5.1 versions to run them on my systems ? I have used the LAV filters versions posted above.
2nd November 2019, 12:02 | #1909 | Link | |
I think you have to test it again with at least 8 threads in order to use hyperthreading and all of your CPU's processing power.
2nd November 2019, 15:06 | #1911 | Link | |
It has also min/avg/max value, even for CPU usage. Just leave it to finish.
2nd November 2019, 16:06 | #1913 | Link |
Ok, you have to go to LAV filters settings and choose SW decoding.
It seems to me that you are using HW decoding.
2nd November 2019, 16:59 | #1915 | Link |
Latest DXVA Checker v4.2.1 and Connect to Renderer selected ?
Also, when you select the AV1 file, does LAV say unsupported inside DXVA Checker ?
3rd November 2019, 07:26 | #1917 | Link | |
I am maddo saientisto!
http://forum.doom9.org/showthread.ph...74#post1889274 http://forum.doom9.org/showthread.ph...89#post1889289 There isn't a DXVA Checker report yet, afternoon spent trying to make it work notwithstanding, but as I said, CPU utilization goes between 70% and 90% with the two sequences used. |
3rd November 2019, 08:21 | #1918 | Link |
Some older versions of dxva checker shows CPU usage. But i did short test and the results of dxch was around 88% utilization while system monitor was showing 100%. Maybe thats why authors of the program turned off the feature temporarily, because of inconsistent results?
3rd November 2019, 08:50 | #1919 | Link |
I'd love to keep arguing, but I have to agree that won't make the board any favor, so let's let bygones be bygones.
I have already removed all sorts of config files, fresh installations, even reboots etc. Have you run your own benches on this (4.2.1) version, or on an older one? If the latter happens to be the case, what exact version, so I can download it from the VideoHelp archive? I don't get what you mean by "no internal commands". They are cmdline applications, just use the same cmdlines I used. I was inside an MSYS shell just so that I could use the "time" command, but I suppose PowerShell on Win10 has got something similar. Word of advice, they only digest pure IVF files, so at least the Dua Lipa video will have to be freed of its container using "ffmpeg -i Dua_Lipa.mp4 -c:v copy Dua_Lipa.ivf" |
3rd November 2019, 09:45 | #1920 | Link |
I'm not a developer, so environments like MSYS , Visual Studio etc are not frequently installed on my system.
I have compiled a few apps from time to time, even my own code decades ago (!) but I'm not going to do it now setting up MSYS. I'll give PowerShell a try of course, as I use it from time to time for my job (although I still do a lot using cmd) But that IVF thing is another obstacle. Regarding DXVA Checker I used v4.2.1 which of course has everything, as I told you before. Min/avg/max for FPS and CPU utilization. Your main problem is that you see things like Video Engine and GPU utilization and you shouldn't. You need a cleaner OS. Tomorrow I'll try setting LAV to single-thread mode and run the same tests with Skylake at work. If nobody here in this forum can confirm or reject my multi-thread results using so familiar tools like LAV filters and DXVA Checker, I'll try to reproduce yours single-thread results. P.S DXVA Checker is a sophisticated and accurate tool and the CPU utilization refers to itself only, as a process, not general CPU utilization during its running.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all Last edited by NikosD; 3rd November 2019 at 09:49. |
