2nd April 2014, 21:36 | #19861 | Link | |
2nd April 2014, 21:39 | #19862 | Link |
no i dont thats why i said ill donate. the 3d full backup i tested tho on the 3 samsung players and ps3 is not nurse 3d . just thought you might have an idea why they do it. how much dollars was nurse it could be just a bad rip of nurse i have but just confused on the others i have done why some players play it and others just stutter or dont play
i have donated 10 dollars Last edited by rusty666; 2nd April 2014 at 21:44. |
2nd April 2014, 21:43 | #19863 | Link | |
PGS streams, for the most part, aren't big enough to even worry about. So keeping or removing those usually doesn't matter much. Occasionally, though, one will come along that is huge. Last edited by jdobbs; 2nd April 2014 at 21:51. |
2nd April 2014, 21:54 | #19864 | Link | |
I ordered "Nurse 3D" because your log shows that it is a 3D disc that isn't being recognized as 3D during encoding. I consider that to be something I need to check. There are too many variables involved in the "stuttering" report. Give me the name of a disc you've done that stutters and I'll test it. Last edited by jdobbs; 2nd April 2014 at 22:09. |
2nd April 2014, 22:04 | #19866 | Link |
I also need the contents of the INI file that was used when you did the "stuttering" disc and also "Nurse 3D". Yes, I just looked and there is a $10 donation on my server. You should have gotten an acknowledgement e-mail.
The only time there will be a SSIF folder is if you do a movie-only backup -- and then only if it is done directly to ISO. Last edited by jdobbs; 2nd April 2014 at 22:06. |
2nd April 2014, 22:05 | #19867 | Link |
thats for nurse 3d. i didnt save for the other
Options] VERSION=0.47.0.3 MODE=3 ENCODE_QUALITY=5 ONEPASS_ENCODING=0 AUTO_QUALITY=0 TARGET_SIZE=23500 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23500 [Paths] WORKING_PATH=C:\USERS\RUSTYNAIL\VIDEOS\BDREBUILDER\ SOURCE_PATH=F:\ |
2nd April 2014, 22:13 | #19870 | Link |
So re-rip it from the original disc which you have. You do have it, right? Even though it hasn't been released yet. It's right next to the Hobbit part 2 discs which you happened to have several weeks before it was released anywhere in the world.
Sheesh. There's a very good reason why pirated discs should not be discussed here. It's against the forum rules, too. |
2nd April 2014, 22:21 | #19874 | Link |
Just do me one favor. I don't want to discuss where you got your disc. But never, never, never post a bug report that isn't using an original source as its input that you personally ripped. I'm not saying yours is one of them, but those "floating around" discs may have been hacked in ways that make them useless as a source. I can't fix problems that are there before I even start.
More importantly, they are against forum rules and can get you banned. I'm not accusing you of anything... that's not my job. But enforcing forum rules is. I also don't want to be chasing snipe down rabbit holes. Last edited by jdobbs; 2nd April 2014 at 22:29. |
2nd April 2014, 22:46 | #19876 | Link |
[04/02/14] BD Rebuilder v0.47.03 (beta) [18:29:04] Source: PROMETHEUS_3D - Input BD size: 37.84 GB - Approximate total content: [02:03:46.418] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Quality: Highest (Very Slow), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:29:06] PHASE ONE, Encoding - [18:29:06] Processing: VID_00000 (1 of 1) - [18:29:06] Extracting A/V streams [VID_00000] - [18:38:12] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 178,056 frames - Bitrate: 19,175 Kbs - Using FRIMEncoder for MVC encoding - [18:38:12] Reencoding: VID_00000, Pass 1 of 1 - [19:17:32] Video Encode complete - [19:17:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - [19:17:32] Multiplexing M2TS - [19:25:33] Scanning for 3D CLPI info... [19:28:57]PHASE ONE complete [19:28:57]PHASE TWO - Rebuild Started - [19:28:57] Rebuilding BD file Structure [19:28:57] - Encode and Rebuild complete [19:28:57] JOB: PROMETHEUS_3D finished. ---------------------- I think I managed to get Quick Sync working. Still not 100% sure but judging by the speed with which this movie was completed, BD-RB must've used it. I had never completed a 3D movie back up in less than an hour before. Last edited by Yordan5; 2nd April 2014 at 22:50. |
2nd April 2014, 23:05 | #19878 | Link | |
