#1 | Link |
Clueless User
Need help fixing dot crawl and rainbowing
Hi there!
I'm working on a script for the anime ''Yu-Gi-Oh: Duel Monsters''. The NTSC source DVDs contain lots of dot crawling and rainbowing issues that I'd like to eliminate. I've got an encoded sample by someone called DarkDream, which looks superb compared to the original DVDs. I'm using his encodes as a ''goal'' for my own encodes, in terms of quality. And yes, I already asked DarkDream about the script he used. No reply yet and I'm likely not going to get one. :P - Samples - DarkDream (15mb): https://mega.nz/#!lMUzhQDB!Fql8JVwll...JaEiHx0VyZKoEk DVD source sample (45mb): https://mega.nz/#!lA8lRDQS!4MtZwHQ9n...40TpzTumGw602U This is my script so far: Code:
checkmate(thr=20, max=1, tthr2=0).checkmate(thr=10, max=1, tthr2=0) Bifrost(interlaced=true) tfm(order=-1).tdecimate(mode=1,hybrid=0) Crop(22, 6, -4, -4) Spline36Resize(640, 480) Santiag() #Optional Deen("c3d",0,3,2) FastLineDarkenMOD(strength=40) LimitedSharpenFaster(ss_x=2.0, ss_y=2.0, strength=30, overshoot=0, undershoot=0, soft=0, edgemode=0) I figured calling the checkmate filter twice would help out but I'm most likely wrong. Seems to cause more artifacts to appear. Thanks in advance! Last edited by Scyrous; 17th December 2016 at 17:51. Reason: Fixed links |
#2 | Link |
Try Tcomb. There's a guide on how to find the settings in the wiki. Go low, it does artifact.
Also, this doesn't need sharpening, and line darkening is cancer. I'd use smdegrain(prefilter=0, thSAD=70) to clean up the noise. And a light high bit depth debanding never hurts. Gradfun3 is a staple for me. |
#3 | Link | |
Clueless User
Edit: TComb is useless to me since it only works on dot crawl / rainbowing that was introduced after the telecining process. In my source it's done prior. SMDegrain results in hideous gray artifacts all over the frames.. @real.finder DDcomb won't even load... Says there is no such function (even though I pasted the script in my plugin folder as always). Last edited by Scyrous; 17th December 2016 at 23:27. |
#4 | Link |
See My Avisynth Stuff |
anime, darkdream, dot crawl, rainbow, yu-gi-oh: duel monsters |
