Old 30th August 2011, 17:39   #661  |  Link
Sirber
retired developer
Sirber's Avatar
for vorbis I use quality (-2 to 10 iirc). I display bitrate (equivalent) in the GUI.
Detritus Software
Sirber is offline   Reply With Quote
Old 31st August 2011, 20:02   #662  |  Link
Sirber
retired developer
Sirber's Avatar
Working on DS Backup (VB#), it took me 30 minutes having the GUI multi-threaded... thinking of moving bencos to VB#...
Detritus Software
Old 10th September 2011, 02:51   #663  |  Link
clone83
clone83's Avatar
Hi Sirber, are you able to add a feature to bencos to add no subs to the encode? and enable .ass and .ssa in to the subs as well?
cheers
clone83 is offline   Reply With Quote
Old 10th September 2011, 03:17   #664  |  Link
Sirber
retired developer
Sirber's Avatar
cheers
bencos doesn't look around the source file for subs.
This could be done but I'm thinking of moving on another project.
Detritus Software
Old 10th September 2011, 03:21   #665  |  Link
MajorX
any update??
MajorX is offline   Reply With Quote
Old 10th September 2011, 03:25   #666  |  Link
Sirber
retired developer
Sirber's Avatar
no.....
Detritus Software
Old 10th September 2011, 14:54   #667  |  Link
clone83
clone83's Avatar
what project are u moving on to...?
Old 10th September 2011, 15:19   #668  |  Link
Sirber
retired developer
Sirber's Avatar
I'm currently working on a backup too, and after that I might rewrite bencos in vb.net (RealAnime 7 ). I'm a bit bored of freepascal...
I recently learned how to do threading (in .net) and it's almost a joy
Detritus Software
Old 23rd September 2011, 14:48   #669  |  Link
Tushkan
Planned new version BENCOS work without installation (portable version)?
Tushkan is offline   Reply With Quote
Old 23rd September 2011, 14:50   #670  |  Link
Sirber
retired developer
Sirber's Avatar
Yeah. Temp files goes to "%temp%\bencos" while encoding.
[edit]
Extract the content of the installer exe with 7zip and run in.
Detritus Software
Old 23rd September 2011, 14:59   #671  |  Link
Tushkan
I want to be able to choose the audio track to encode.
Whether this will be implemented?
Old 23rd September 2011, 15:04   #672  |  Link
Sirber
retired developer
Sirber's Avatar
You can choose one by language. Doesn't work otherwise.
You can always make a feature request, but I'm not actively working on bencos...
Detritus Software
Old 21st October 2011, 04:44   #673  |  Link
nanyatimz
high 10 profile? it's product is still in 8bit.. why? does this feature work?
nanyatimz is offline   Reply With Quote
Old 31st December 2011, 21:13   #674  |  Link
Sirber
retired developer
Sirber's Avatar
I have no clue. BENCOS only set flags on the encoder (ffmpeg/x264).
Detritus Software
Old 31st December 2011, 21:14   #675  |  Link
Sirber
retired developer
Sirber's Avatar
Todo for 2012!
http://www.detritus.qc.ca/cms/?p=223
Can't wait to clean bencos's code, it's a big one-file mess
Detritus Software
Old 5th January 2012, 02:15   #676  |  Link
Sirber
retired developer
Sirber's Avatar
http://www.detritus.qc.ca/cms/?p=230
Detritus Software
Old 23rd February 2012, 12:05   #677  |  Link
alzou
waiting RA7 release...
alzou is offline   Reply With Quote
Old 23rd February 2012, 14:05   #678  |  Link
Sirber
retired developer
Sirber's Avatar
might be a long wait
I'm learning C++ and wxWidgets, still not sure if it's going anywhere
Detritus Software
Old 23rd February 2012, 16:44   #679  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
My suggestion: Go for Qt rather than wxWidgets
Old 23rd February 2012, 16:53   #680  |  Link
Sirber
retired developer
Sirber's Avatar
I had a quick look at it, with it's QML lanquage. Not sure I like it..
Detritus Software
aac, bencos, gui, webm, x264
