13th January 2020, 17:18 | #29141 | Link | |
13th January 2020, 17:25 | #29142 | Link |
Hi there,
Is there a possibility of re-encoding a UHD MKV to Blu-ray disc (by example a BD-25 disc) and keeping the HD audio intact. For now i only see the option to import MKV file and then it reencodes the audio to 640 bits. Kind Regards, Mask0rz Last edited by mask0rz; 13th January 2020 at 17:28. |
13th January 2020, 17:49 | #29143 | Link |
Yesterday I made several test with this 64bit version of tsmuxer:
https://bintray.com/justdan96/tsMuxe...01-10-45#files I remuxed all m2ts-files from BD-Rebuilder manually with this version and 2 DV discs are playing fine on my Sony X800M2, but when I replaced the tsmuxer4k.exe with above version in BD-Rebuilder, DV isn't working. Today I want testing jdobbs new tsmuxer version. |
13th January 2020, 18:29 | #29144 | Link | |
I just did a test directly with the disk directly, same problem, is this file you want? #Created by BD Rebuilder - v0.61.01 DirectshowSource("G:\BDMV\STREAM\00000.m2ts", fps=23.976, framecount=198868, audio=false) LoadPlugin("C:\Users\Sebastien\Desktop\Videos\BD_Rebuilder\tools\autocrop.dll") Autocrop(mode=0, hMultOf=4) ConvertToYV12().AssumeFPS(24000,1001) Last edited by thekiller; 13th January 2020 at 18:37. |
13th January 2020, 23:17 | #29145 | Link |
DV isn't working with Jdobbs last tsmuxer.exe version. I have a backup of the workfiles folder.
Manually remuxing of the m2ts-files are working on following DV-discs: Cold Pursuit Gladiator The secret life of pets 2 Mary queen of Scotland Actually I only tested these DV-discs. Last edited by Michi; 13th January 2020 at 23:22. |
13th January 2020, 23:33 | #29146 | Link | |
Elit Amans
//LD |
13th January 2020, 23:51 | #29147 | Link | |
13th January 2020, 23:56 | #29149 | Link | |
Did you try using the the version I linked in the post above? Can you post the META file that is used by BD-RB and the one used when you do it manually so I can see the difference? If you are using the GUI, just cut and paste from the area in the GUI. I hope I'm understanding you correctly? Last edited by jdobbs; 14th January 2020 at 00:01. |
14th January 2020, 02:02 | #29151 | Link | |
This may help me put a finger on the problem. Thanks. Last edited by jdobbs; 14th January 2020 at 02:12. |
14th January 2020, 02:08 | #29152 | Link | |
14th January 2020, 13:47 | #29156 | Link | ||
14th January 2020, 16:09 | #29158 | Link | |||
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray-v3 --vbr --auto-chapters=5 --vbv-len=500 --start-time=27000000 V_MPEGH/ISO/HEVC, "Q:\4K\WORKFILES\VID_00008.AVS.hevc", fps=24, insertSEI, contSPS V_MPEGH/ISO/HEVC, "Q:\4K\WORKFILES\00008.track_4117.hevc", fps=24, secondary, contSPS A_AC3, "Q:\4K\WORKFILES\00008.track_4356.AC3", lang=deu S_HDMV/PGS, "Q:\4K\WORKFILES\00008.track_4771.sup",lang=deu Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 V_MPEGH/ISO/HEVC, "Q:\4K\COLD_PURSUIT\BDMV\STREAM\00008.m2ts", track=6912 V_MPEGH/ISO/HEVC, "Q:\4K\COLD_PURSUIT\BDMV\STREAM\00008.m2ts", fps=24, ar=As source, track=4113 A_AC3, "Q:\4K\COLD_PURSUIT\BDMV\STREAM\00008.m2ts", track=4352, lang=deu S_HDMV/PGS, "Q:\4K\COLD_PURSUIT\BDMV\STREAM\00008.m2ts", fps=24, track=4608, lang=deu |
14th January 2020, 17:23 | #29159 | Link | |
In BD-RB you used "Q:\4K\WORKFILES\VID_00008.AVS.hevc" In the manual remux you used "Q:\4K\COLD_PURSUIT\BDMV\STREAM\00008.m2ts" Am I missing something? |
