13th November 2017, 03:36 | #5741 | Link |
OK thanks for the answer on the sar.
Attached is the log. The box to demux video stream was not checked, but the files were still created. If it's not occurred in general testing then I wonder if it's because MeGUI isn't installed in the normal default location? It looks like it's been installed in the same folder on my system since back at version 2624. |
13th November 2017, 12:12 | #5742 | Link |
Problems with update 2774 and audio
Yesterday version 2774 was installed on top of an existing 2715 version on Windows 10. Result: problems of audio. The audio is messed and a clicking noise (like a gun is shooting) is produced in the audio. What want I to do with Megui? I have m2ts-files and I want to convert them to mp4-files (h264-video en aac-audio). I do this with an avs-file like this: LoadPlugin("C:\programs\megui\tools\avs\plugins\DirectShowSource.dll") LoadPlugin("C:\programs\megui\tools\avisynth_plugin\TDeint.dll") DirectShowSource("D:\roland\Videos\can\m2ts\04-08-17\20170804141228.m2ts",fps=25.000) TDeint() #Deinterlaces the clip #Crop(4,0,-4,0) #Crops video to get rid of black bars Spline36Resize(640,360) #Resize the clip ConvertToYV12() The audio in the original file is: Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format settings, Endianness : Big Codec ID : 129 Duration : 2 min 16 s Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Compression mode : Lossy Stream size : 7.28 MiB (3%) Service kind : Complete Main I want this audio tranfered to :LC-AAC format Before the last update I did this several years, without problems!! The last year I use the QAAC-encoder. Testing with several options of the audio-dialog shows that the problem is with the "Downmix multichannel to Stereo"-option is. When I download the version 2774 from the official site and I run this version, the QAAC-encoder is not anymore present. Is this normal or a bug? So my question is now: how to encode the audio to format lc-aac if QAAC-package is not present? |
13th November 2017, 12:23 | #5743 | Link | |||
The others PGC's can have copyright message, credits, extras, etc. than must be eliminated from original VOB's using pgcdemux: Quote:
13th November 2017, 12:43 | #5744 | Link |
@laurentje:
QAAC is only a command line interface tool to the Apple CoreAudio encoder. To use it, you need to have either QuickTime or iTunes installed, or at least unpack the required DLL's from their installer (preferably from iTunes 64-bit), using the "makeportable" batch provided by the QAAC author. Furthermore, to use QAAC, you have to enable it in the "Settings" dialog in the "External Program Configuration" tab. |
13th November 2017, 13:05 | #5746 | Link | |
The correct way is extract the AC3 file (Tools -> HD Streams Extractor) and recode it to aac-lc (using LWLibavAudioSource or NicAudio) The QAAC package (and NeroAacEnc than can be equivalent for aac-lc) must be enabled (Options -> Settings -> External Program Configuration) and maybe manually download the first time or update. Check if you have already, from your previous MeGUI version: ...\megui\tools\qaac\QTfiles... ...\megui\tools\eac3to\neroAacEnc.exe
13th November 2017, 14:34 | #5747 | Link |
@laurentje: In any case a full log of the encoding (including versions header) is required for proper support - currently we can only guess that you have used DirectShowSource also for the audio encoding, which architecture you are using (32/64bit), ...
@All: If not noticed already I have released yesterday a new "stable" build 2774. |
13th November 2017, 17:06 | #5748 | Link |
@Zathor:
No problem for the log list but the audio is terrible. And the system is Windows 10, which is 64bit. The log is here. The result video is here. In the beginning of the clip you hear clicks like gunshots... which are not in the original clip. Last edited by laurentje; 13th November 2017 at 17:10. |
13th November 2017, 17:31 | #5749 | Link |
@tebasuna51
1) audio encoding AAC Well, this was quite simple: in the Settings, 3rd tab 'External Program Contifuration', activate checkbox QAAC. Then the program shall ask for update, etc... 2) The splitting task via the tool is an extra step in the workflow, too much... A better solution is to put the name of the mts-file directly in the input field of the audio file. (the standard beheviour is that Megui put the same name here als the viedofilename) |
13th November 2017, 17:52 | #5750 | Link |
What is in this script?
Import("C:\tmp\video\can\m2ts_raw\can_dag01_raw2.avs") |
13th November 2017, 18:53 | #5751 | Link |
@Zathor
Here is the avs: LoadPlugin("C:\programs\megui\tools\avs\plugins\DirectShowSource.dll") LoadPlugin("C:\programs\megui\tools\avisynth_plugin\TDeint.dll") DirectShowSource("D:\roland\Videos\can\m2ts\04-08-17\20170804141228.m2ts",fps=25.000) TDeint() #Deinterlaces the clip #Crop(4,0,-4,0) #Crops video to get rid of black bars Spline36Resize(640,360) #Resize the clip ConvertToYV12() For the Oneclick-solution: I'll see, but I want also resize the frames at the same time. Thanks for your suggestion. |
13th November 2017, 20:45 | #5752 | Link |
And again, the "Groundhog Day" of AviSynth in general, and MeGUI specifically: How old is the guide which recommends DirectShowSource over the File Indexer? We don't, rather the opposite.
13th November 2017, 22:21 | #5753 | Link | |
Regarding your audio issues - I cannot support DirectShowSource. Either use the old MeGUI version if that works for you (change should only be the AVS+ version used) or switch to file indexer / OneClick. |
15th November 2017, 10:11 | #5754 | Link |
Hi Zathor.
Is there any chance of an option to disable the disabling of the "Improve AVS opening" setting when MeGUI thinks it's crashed or there's been a preview error or a light shower within 30 miles while previewing a video? I ask, because when you're fiddling with scripts and experimenting with plugins etc it's inevitable you'll do something to hurt MeGUI's feelings, and I swear I must go back into Options at least 354 times per day to re-enable "Improve AVS opening". Under what sort of circumstance would disabling that option allow MeGUI to open a script it otherwise couldn't open? Thank you! PS. When you open a source, MeGUI always sets the Input DAR in the script creator, but if it's not a standard DAR and you change the Input DAR yourself, you can't change it back to what it was. An InputDAR "scratchpad" maybe? Otherwise you have to reload the source and start again or create a custom Input DAR, which will force you to delete any currently saved custom DAR's when you want to eventually remove it (which is annoying because MeGUI still uses the old ITU PARs rather than the mpeg4 PARs). PPS I've noticed MeGUI is fairly attached to choosing an ITU or generic Input DAR if the source is of a DVD-type resolution. For instance if you open an MKV at 720x576 with something close to 4:3 written to the container/video stream, MeGUI will ignore it and choose ITU or generic instead. When the aspect ratio differs enough from a standard generic or ITU PAR, MeGUI starts to pay attention, but to my way of thinking it should always do so. PPPS. Is there any chance one day MeGUI could display the resizing resolution in the script creator? Somewhere near the aspect error area maybe? So if you set 640x480 as the resizing for example, MeGUI would tell you it's 4:3. While 640x480 is fairly obvious, often it's not. I'm sure I had something else to complain about, but I seem to have forgotten what it was. Thanks for the continued work. It's appreciated. PPPPS. I remembered. Do you think the option to add a pre-recording job to the queue gets much use? I ask, because I use it, but mainly to encode to a lossless output, and then I re-encode that, but usually after manually creating a new script and adding more filtering etc. Theretofore, I always have to delete the other jobs MeGUI adds to the queue, but it's the only way to losslessly encode with huffYUV. I assume the original purpose of the "pre-rendering" option was to automatically encode to an intermediate file while running slow filtering and MeGUI would then busy itself running a 2 pass encode, which is why I asked how much use it's likely to get these days. I was wondering if it'd be more useful now if it simply ran a lossless encode and let the user do the rest. I'm done now. Last edited by hello_hello; 15th November 2017 at 12:05. |
16th November 2017, 19:52 | #5755 | Link | |
Log file is here. Tried several files with same result (crashing...) Crashed at job3: Creating LSMASH index.... |
16th November 2017, 20:15 | #5756 | Link | ||||||
Ideally you raise for the changes feature requests on sourceforge. Likely it will not be faster, but your points are also no points I can implement / change right now. So it may happen that it will be burried here which I want to avoid. Btw great to have you here! Quote:
As a workaround you can try to change the priorities in the oneclick profile so that ffms will be used as primary indexer. Sorry for the trouble... |
18th November 2017, 00:49 | #5757 | Link | ||||||
I don't use the old ITU pixel aspect ratios because they were never exactly correct to begin with (MeGUI is the only current GUI I know of that still uses them). The mpeg4 aspect ratios are simpler and easier to work with, they match the SARs in the x264 encoder configuration, they generally make it easier to crop to exactly 16:9 or 4:3, and they apply to both PAL and NTSC. I was just having a little whine about MeGUI removing the custom MPEG4 DAR's every time I create a temporary InputDAR and then delete it. Here's two. NTSC & PAL.zip (6MB) I started with an NTSC DVD (using an Input DAR of 15:11), cropped 2 pixels from each side and resized back to 720x480. I then encoded it again, resizing to 720x576. The script itself: Quote:
It only applies when the resolution is exactly 720x480 or 720x576 and I haven't tried to work out how far the DAR needs to be from 4:3 or 16:9 before MeGUI starts using it, but there's obviously a point at which it does. Quote:
Did you ever read my request for adding filtering to each trim you add with the AVS Cutter? I'm longing for the day.... The idea was to be able to include filtering with each Trim so not only could the AVS Cutter do basic cutting, you could use it as an editor of sorts. Like so: Trim(0,100).ThisFilter().ThatFilter() MeGUI's preview is already open and ready to preview the changes, all that's required is a way to enter them and life would be joyous once again... Quote:
Thanks Last edited by hello_hello; 18th November 2017 at 17:46. |
19th November 2017, 03:25 | #5758 | Link | |
Regards Edit: Looks like ability to change priority of indexer has been implemented in One-Click under the 'Other' tab. Last edited by raymondjpg; 19th November 2017 at 05:07. |
19th November 2017, 10:04 | #5759 | Link |
An issue with xvid_encraw has just been discussed in the German doom9/Gleitz board. It turned out that xvid_encraw (in contrast to other encoders) only accepts an avisynth.dll located in a directory where a registry value of the AviSynth installation points at, but not from its base directory or %PATH%.
Recompiling an enhanced xvid_encraw (after adding such code) would require Visual Studio. I can't offer this service. Any other volunteers? — Until that, MeGUI may have to temporarily manipulate this registry value (and "temporarily" means, there may be a risk of getting permanent in case it crashes before it restores the original value). |
19th November 2017, 13:56 | #5760 | Link | |
xvid_encraw (and I presume similar tools that use the VfW API) will work just fine with these registry entries present: Code:
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\AVIFile\Extensions\avs] @="{E6D6B700-124D-11D4-86F3-DB80AFD98778}" [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}] @="AviSynth" [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E6D6B700-124D-11D4-86F3-DB80AFD98778}\InProcServer32] @="avisynth.dll" "ThreadingModel"="Apartment"
Groucho's Avisynth Stuff Last edited by Groucho2004; 19th November 2017 at 14:03. |
