Old 17th June 2016, 10:44   #21  |  Link
yup
pinterf!
I am testing Your MVTools under Avisynth+ 64 bit and find strange behaviour during using QTGMC, when try dct=5 I see wrong motion estimation, other dct 1,2,3, 4 work normally.
yup.
yup is offline   Reply With Quote
Old 17th June 2016, 13:17   #22  |  Link
GMJCZP
GMJCZP's Avatar
Originally Posted by GMJCZP View Post
Without AvsMeter, I noted that this build is more slow that Fizick and cretindesalpes versions. It's weird.
What happened with that?
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 17th June 2016, 13:55   #23  |  Link
pinterf
Could not reproduce, for me, it was faster in a qtgmc process. But I don't know what kind of script you are using.
What numbers (fps) did you see without and with avsmeter on the different mvtools versions?
pinterf is offline   Reply With Quote
Old 17th June 2016, 14:13   #24  |  Link
pinterf
Originally Posted by yup View Post
pinterf!
yup.
Is it only the x64 version or 32 bit, too?
If both versions share the problem, unfortunately it must be in the deepness of the original code, would be very hard for me to dig into it.
And if it is reproducible also with Fizick's version, we should ask him.
Nevertheless, I will try it when I have time; bwt, is it hard to recognize, or I will see an obvious garbage?
Old 17th June 2016, 14:52   #25  |  Link
GMJCZP
GMJCZP's Avatar
Test results only with AvsMeter:
Log file created with:                 AVSMeter 2.2.8 (x86)
[Clip info]
File.avi
Number of frames:                 2447
Length (hh:mm:ss.ms):     00:01:21.656
Frame width:                       512
Frame height:                      384
Framerate:                      29.967 (100000/3337)
Colorspace:                       YV12
Active MT Mode:                      0
Audio channels:                    n/a
Audio bits/sample:                 n/a
Audio sample rate:                 n/a
Audio samples:                     n/a
[Script]
function PreF_MDeGrain(clip src, int "radius", int "P_thSAD")
radius = default(radius, 2)
P_thSAD = default(P_thSAD, 400)
preNR = src.frfun3b(s=8,T=2,tuv=7)
preNR_super = preNR.MSuper(pel=2, sharp=1)
src_super   = src.MSuper(pel=2, sharp=1, levels=1)
backward_vec3 = MAnalyse(preNR_super, isb = true,  delta = 3, overlap=4)
backward_vec2 = MAnalyse(preNR_super, isb = true,  delta = 2, overlap=4)
backward_vec1 = MAnalyse(preNR_super, isb = true,  delta = 1, overlap=4)
forward_vec1  = MAnalyse(preNR_super, isb = false, delta = 1, overlap=4)
forward_vec2  = MAnalyse(preNR_super, isb = false, delta = 2, overlap=4)
forward_vec3  = MAnalyse(preNR_super, isb = false, delta = 3, overlap=4)
radius >= 3 ? src.MDegrain3(src_super, backward_vec1, forward_vec1, backward_vec2, forward_vec2, backward_vec3, forward_vec3, thSAD=P_thSAD) : \
radius == 2 ? src.MDegrain2(src_super, backward_vec1, forward_vec1, backward_vec2, forward_vec2, thSAD=P_thSAD) : \
src.MDegrain1(src_super, backward_vec1, forward_vec1, thSAD=P_thSAD)
[Results]
MVTools 2.7.0.22 XP (pinterf):
[Runtime info]
Frames processed:               2447 (0 - 2446)
FPS (min | max | average):      4.663 | 10.79 | 5.337
Memory usage (phys | virt):     368 | 364 MiB
Thread count:                   1
CPU usage (average):            50%
Time (elapsed):                 00:07:38.488
MVTools 2.6.0.5 (cretindesalpes):
[Runtime info]
FPS (min | max | average):      4.372 | 12.48 | 6.170
Memory usage (phys | virt):     367 | 364 MiB
Thread count:                   1
Time (elapsed):                 00:06:36.585
MVTools 2.5.11.22 (Fizick):
[Runtime info]
FPS (min | max | average):      5.836 | 14.11 | 6.548
Memory usage (phys | virt):     364 | 362 MiB
Thread count:                   1
Time (elapsed):                 00:06:13.685
By law and justice!
GMJCZP's Arsenal
Old 17th June 2016, 16:21   #26  |  Link
Groucho2004
@GMJCZP
The script is incomplete. It seems you cut arbitrary parts out of the log file.
If you want us to try and reproduce it you'll have to post the entire script.
Groucho's Avisynth Stuff
Old 17th June 2016, 17:59   #27  |  Link
GMJCZP
GMJCZP's Avatar
@GMJCZP
Do you mean include performance data?
By law and justice!
GMJCZP's Arsenal
Old 17th June 2016, 18:12   #28  |  Link
Groucho2004
No, the full script.
Old 17th June 2016, 18:27   #29  |  Link
GMJCZP
GMJCZP's Avatar
Here:
[Script]
#  PLUGINS
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\avstimerf.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\dgdecode.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\Decomb521VFR1.3_PPro-P3.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\mt_masktools-26.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\TIVTC.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\masktools.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\dither.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\Deen_beta.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\EEDI2_imp.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\deblock.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\Tnlmeans.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\dfttest.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\nnedi3.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\RemoveGrain.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\RemoveGrainTSSE3.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\KNLMeansCL.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\yadifmod2.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\nnedi2.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\RemoveDirtSSE2.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\WarpSharp.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\aWarpSharp2.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\nnedi.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\nnedi2.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\asharp.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\awarpsharp.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\Average.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\TcannyMod.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\DeFlicker.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\ChromaShift.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\gradfun2db.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\cnr2.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\mvtools2.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\unfilter.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\ColorMatrix.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\frfun3b.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\fft3dfilter.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\ReduceFlickerSSE3.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\Toon-v1.1.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\DctFilter.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\Repair.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\RepairTSSE2.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\tdeint.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\TBilateral.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\tmm.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\sangnom.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\undot.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\vinverse.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\VagueDenoiser.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\SSIQ.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\MVTools.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\DeGrainMedian.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\FillMargins.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\MSharpen.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\mipsmooth.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\VSFilter.dll")
#LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\DeDup.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\autoadjust.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\VerticalCleanerSSE3.dll")
LoadPlugin("C:\ARCHIV~1\GORDIA~1\AviSynthPlugins\Convolution3DYV12.dll")
import("D:\Tipos de archivo de audio y video\Avi\Herramientas Avi\AviSynth\Scripts\Sharpening\SeeSaw\SeeSaw.avs"
import("D:\Tipos de archivo de audio y video\Avi\Herramientas Avi\AviSynth\Scripts\Sharpening\FastLineDarken\FastLineDarkenMod.avsi")
import("D:\Tipos de archivo de audio y video\Avi\Herramientas Avi\AviSynth\Scripts\Correccion color\YLevels\YLevels_mt.avsi")
import("D:\Tipos de archivo de audio y video\Avi\Herramientas Avi\AviSynth\Scripts\Fix Chroma\ChromaShift_SP\ChromaShift_SP.avs")
import("D:\Tipos de archivo de audio y video\Avi\Herramientas Avi\AviSynth\Scripts\DeBanding\Dither\dither.avsi")
import("D:\Tipos de archivo de audio y video\Avi\Herramientas Avi\AviSynth\Scripts\DeBanding\Dither\mt_xxpand_multi.avsi")
import("D:\Tipos de archivo de audio y video\Avi\Herramientas Avi\AviSynth\Scripts\Compresion de videos\SPresso.avsi")
import("D:\Tipos de archivo de audio y video\Avi\Herramientas Avi\AviSynth\Scripts\Restauracion de frames\Imagenes en Avisynth\RescueFrame.avsi")
import("D:\Tipos de archivo de audio y video\Avi\Herramientas Avi\AviSynth\Scripts\John Meyer MVDeGrain\PreF_MDeGrain.avsi")
avisource("File.avi",audio=false)
PreF_MDeGrain()
By law and justice!
GMJCZP's Arsenal
Old 17th June 2016, 19:23   #30  |  Link
pinterf
That is quite a big difference, worth the inspection
Old 17th June 2016, 21:16   #31  |  Link
Groucho2004
I'm getting very similar results, different source but the trend is the same:
[Runtime info]
Frames processed:               200 (0 - 199)
FPS (min | max | average):      3.139 | 4.879 | 3.190
Memory usage (phys | virt):     360 | 357 MiB
Thread count:                   2
CPU usage (average):            25%
Time (elapsed):                 00:01:02.687
[Runtime info]
FPS (min | max | average):      3.625 | 5.432 | 3.688
Memory usage (phys | virt):     353 | 350 MiB
Thread count:                   2
Time (elapsed):                 00:00:54.227
[Runtime info]
FPS (min | max | average):      3.494 | 5.718 | 3.938
Memory usage (phys | virt):     380 | 378 MiB
Thread count:                   2
Time (elapsed):                 00:00:50.791
Old 17th June 2016, 21:56   #32  |  Link
pinterf
I wonder if its only the xp build that is slow?
Old 19th June 2016, 18:51   #33  |  Link
yup
dct=5 issue
pinterf
Avisynt+ 32 bit ant Your version MVTools work without problem.
Testing script
SetMemoryMax(1536)
SetFilterMTMode("DEFAULT_MT_MODE",2)
SetFilterMTMode("AviSource",3)
AVISource("samplevhs.avi")
AssumeTFF()
QTGMC(dct=5)
Prefetch(8)
sample video https://www.dropbox.com/s/5exreq9j9e0r0hs/test.avi?dl=0
yup.
Old 20th June 2016, 17:09   #34  |  Link
pinterf
SetMemoryMax(1536)
AssumeTFF()
QTGMC(dct=5)
yup.
Nasty bug. But reproducible. So far that's all.
Something within MVAnalyze is broken on x64.
This modification works:
QTGMC(/*Preset="Slower",*/dct=5, ChromaMotion=false)
Old 21st June 2016, 09:40   #35  |  Link
yup
pinterf!
Yes, it is work
chromamotion=false
I am using this option for my VHS capture video.
yup.
Old 4th August 2016, 10:56   #36  |  Link
pinterf
Dear users, 2016 is a lucky year, MvTools2 finally got YUV 4:2:2 and 4:4:4 support (YV16 and YV24).
See source and binaries here:
MVTools2 2.7.0.22c
Please try this *test* build, which works for me with my usual scripts and YV16 gives identical output as with the former YUY2 format.
No need hacking YUY2 sources any more to special planar format and back, convert your source once to YV16 and process it.
P.S.
Could not try it with SMDegrain.avsi, because the script internally assumes YV12 for planar YUV format. BTW the script is full with YUY2 conversion, maybe it can be lighter, too.
Old 4th August 2016, 11:00   #37  |  Link
yup
pinterf!
Work with QTGM without problems, practically at same speed like YV12.
yup.
Old 4th August 2016, 13:27   #38  |  Link
Reel.Deel
Very nice. Thank you pinterf!
P.S.
Yes, both QTGMC and SMDegrain are quite bloated due to the planar YUY2 hack. A while back I started modding QTGMC to remove the hack, I never finished but MVTools supporting YV16 makes it a lot easier.
Reel.Deel is offline   Reply With Quote
Old 5th August 2016, 03:57   #39  |  Link
GMJCZP
GMJCZP's Avatar
Hi pinterf, and Windows XP problem?
Anyway thank you for your effort.
By law and justice!
GMJCZP's Arsenal
Old 5th August 2016, 07:13   #40  |  Link
pinterf
Did you try it?
