7th July 2020, 09:10 | #581 | Link |
My take on this using common sense:
Anyone downloading the files-only package has Avisynth+ already installed either via regular installer or Universal Installer. Either option installs/contains the colors_rgb.avsi file. So, no need to put it in the package unless there were changes to it which I believe happens only once a decade.
Groucho's Avisynth Stuff |
7th July 2020, 11:18 | #582 | Link | |
Last change to colors_rgb.avsi was (2015) removal of a double entry for color_palegoldenrod,
https://forum.doom9.org/showthread.p...65#post1711065 Quote:
The double entry is in the image when topmost color is OrangeRed. EDIT: Only the RGB colors are in colors_rgb.avsi, the other YUV color values are calculated from those, see linked thread.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 7th July 2020 at 11:32. |
10th July 2020, 04:28 | #583 | Link |
Avisynth 3.6.2
Have not tried whether it is the same with the 3.6.x versions If MP_Pipeline is in a script, this script can no longer be loaded with AviSource. This is a huge problem for me, with Delphi 'AviSource' is the only way to open a script when MCTD is called in that script. I would like to know why that is with Delphi and 'MCTD', it has been plaguing me for a few months and I just can't figure it out. Edit: That with Avisynt 3.6.2 and AviSource was my mistake. There was a 3.6.1 version in one system directory, after replacement AviSource works again.
Live and let live Last edited by gispos; 10th July 2020 at 06:01. |
10th July 2020, 13:05 | #585 | Link |
Probably that can be used as example how to use them in plugins: https://github.com/AviSynth/AviSynth...ader.cpp#L1189
11th July 2020, 12:46 | #588 | Link | |
Suggest Search on:- keyword "Properties", Show result as Posts, user name Pinterf, search in forum(s) Capturing & Editing Video/Avisynth Developement.
13th July 2020, 07:38 | #589 | Link |
There is a report in the German Gleitz forum about audio issues with MeGUI (it locks up, no progress) when SuperEQ is used to upmix stereo to 6Ch. MeGUI prepares an AviSynth script and a subdirectory with SuperEQ parameter files per channel. But the conversion apparently gets stuck. This happens also when the script is fed directly into ffmpeg. I did not yet test this myself. But I guess it could be worth an investigation whether any regression was introduced in the audio part (depending on the exact AviSynth+ DLL version)...
MeGUI: 2924 x86 AviSynth+ 3.5 (r3106, 3.5, i386) |
13th July 2020, 20:58 | #590 | Link |
This is a follow-up to this older post:
https://forum.doom9.org/showthread.p...19#post1916219 I have no idea what to make of it, but after a few days of testing with different HD sources (only testing 32-bit AVS+) I can clearly reproduce that version 3.6.1 Test 8 is by far more stable in MT mode than the later versions 3.6.1 stable (tested only the "standard" non-XP version) and also the latest 3.6.2 Test 1 version. Test platform: ThinkPad T530 with a Core i5-3230M (Ivy Bridge, 3rd generation) 8 GB of RAM Win7 Pro 64-bit AVS+ Prefetch value was set to 4 threads I converted HD sources (AVC or HEVC video at 50 fps, AAC, AAC-LATM or E-AC3 audio) to SD with AVC video and AAC audio. I used older 2.6 and 2.5 plugins. MT settings from the mtmodes.avsi taken from the AVS+ Wiki page, additions taken from this post by almosely: https://forum.doom9.org/showthread.p...79#post1865279 The changes are in the 3rd paragraph of the post. These tweaks made AVS+ 3.5.x quite stable already, but with some exceptions. After establishing a job in StaxRip (latest stable 32-version) it turned out that it was mostly necessary to save the job first, reboot and then start the job. Also Web browsing during the X264 encode was not really safe. If I did not take these precautions, X264 would crash randomly, mostly near the end of the conversion. After experimenting with the AVS+ 3.6.1 test builds I found that the MT behavior had improved. Especially with Test 8 it was possible to browse the Web, even streaming a YouTube clip during the encode. Also a reboot before starting the actual encode was no longer required. But the joy stopped after installing the stable version 3.6.1. The old occasional crashes were back again. I used the "standard" non-XP build. And last I tested 3.6.2 Test 1, this build is XP-compatible again. So I hoped that the stability of 3.6.1 Test 8 would reappear, but it did not. Same random crashes as with 3.5.x and 3.6.1 stable. The conclusion is that these differences in MT stability have nothing to do with the fact if the build is XP compatible or not. It looks more like something in the code itself has changed after 3.6.1 Test 8, and this change affects memory handling in multitasking mode. No way for a user to debug this, only pinterf or qyot27 could possibly find out what is going on here. I am back to version 3.6.1 Test 8 for the time being... Cheers manolito Last edited by manolito; 14th July 2020 at 02:58. |
14th July 2020, 11:37 | #591 | Link | ||
15th July 2020, 03:16 | #593 | Link | |
http://www.mediafire.com/file/xzjmyb...bisect.7z/file That's a pack of five of those commits (two of them don't compile on their own, but require the following commit). You can test those and see if one of them is where the issue was introduced. |
15th July 2020, 23:14 | #595 | Link |
So I was experimenting with the CUDA version of Avisynth+ which was merged into the main Avisynth+ branch. It seems that it results in a memory leak. While using MeGUI, it gets stuck on the pre-processing phase, then the memory usage goes through the roof (99% RAM usage with 16 GB installed) before the app locks up.
LoadPlugin("C:\MeGUI 64-bit\tools\lsmash\LSMASHSource.dll") LWLibavVideoSource("Z:\Outer Limits\Season 3\Disc 4\Dead Man's Switch.mkv", cachefile="D:\Temp\eksmcibs.nc1\Dead Man's Switch.mkv.lwi") #crop #resize OnCPU(2) KTGMC(Preset="Slow") OnCUDA(6) Last edited by magnetite; 16th July 2020 at 06:04. |
16th July 2020, 00:47 | #596 | Link | ||
...looks like the problem #3 is still there, but much harder to trigger with these new test builds compared to test8... ...nevermind, i forgot to test them without Prefetch, it was masking both problems #2 & #3, both of which are still present... ...Still haven't encountered problem #4 with any of these builds yet, however i noticed that without Prefetch both builds 'r3297f-git_0c09510f' & 'r3298f-git_82a06eee' are much slower than the rest and 'r3294f-git_7a0aa2f3' is a little bit slower than the ones before it. Last edited by Nuihc88; 16th July 2020 at 15:09. Reason: More Information & Corrections... |
17th July 2020, 23:29 | #597 | Link |
r3298f is the same as the final release of 3.6.1. There are absolutely zero code differences between them. The two commits that separate 3298 from 3300 are docs and comments only. The only practical difference is that I did update to the latest version of VS2019 before running off all these test builds.
18th July 2020, 00:48 | #598 | Link |
I am still in the middle of my tests, it turned out to be a little more difficult than I anticipated...
It turned out that the random crashes only occur with long source files (duration of more than 2 hours). Makes testing very time consuming. My results so far are that r3290 (Test 8) up to r3292 have no problems with MT, but r3294 caused crashes again. I will test r3297 later tonight and report back. |
18th July 2020, 01:42 | #599 | Link | |
(Void Linux ppc glibc; musl chokes on something in AviSynth+, or something in the loader in avs2yuv or FFmpeg, probably the atexit handler) Although I think that's a bit over-the-top; all it required was adding the predefined macros for PPC into avs/config.h. A Talos II or Blackbird setup would make more sense, but unless it's significantly trickier to do, POWER9-based CPUs supposedly can operate in ppc64le mode. Some of the filters may produce unexpected results - Version().ConvertTo444() was okay, the resulting output from x264 played with correct colors using the media player in the live session, but ConvertToYV12().BilinearResize(640,352) caused incorrect colors (not sure if it was the conversion to YV12 or the resizer). To actually test efficiently, I'd have to do a real install so I can test FFmpeg/FFplay directly instead of piping in. ¹only because the G3 iBook I have access to didn't want to boot from either CD or USB so that I could test with a modern Linux that still supports that platform. And there's no way I was going to try to figure out how to get a suitably-modern version of GCC or Clang running on OS X 10.2. |
18th July 2020, 02:15 | #600 | Link | |
See My Avisynth Stuff |
