18th March 2012, 01:31 | #14861 | Link |
Ha! About the same thought I had.. Mail it to him, include everything needed for him to return it to you. :-) The disk, not the entire Box Set. ;-)
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 18th March 2012 at 01:36. |
18th March 2012, 15:08 | #14862 | Link |
Windows 7
Jdobbs manythanks for your excellent software which I've used sucessfulling for over a year. Unfortunately, my Win 7 64bit system crashed and I needed to reload Windows 7 and reinstall BDRB. I've been at it for a week and have followed the threads of previous posts on this issue. I've launched as administrator for ffreset, launched as admin for the BDRB application and get confirmation that the changes were made but continue to get the following message when running Inspect:
- Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3326], Ok - WIN7 preferred AVC CODEC: Not Set correctly - WIN7 preferred VC-1 CODEC: Not Set correctly - WIN7 preferred MPEG2 CODEC: Not Set correctly - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.40.0.8, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok I did run through one encoding which went to the end and produced an error code prior to burn of [2306 13:12:58 Do EncodingO 00053 2306]. I presume it was due to the Win7 codecs Not Set Correctly messages. I saw the frequent pointer to "other programs" making changes however I can't detect which programs might be suspect. There are sites which claim to have "tweekers" for Direct Show but I'm afraid to run them as they quickly change their program titles to something else which I suspect is a for fee type of service. Anyway, can you make any suggestions to get BDRB functioning. |
19th March 2012, 01:24 | #14863 | Link |
jdobbs, Forgive my ignorance regarding the "Movie and Menus" mode but is it possible to have an option to select a specific playlist (mpls) to re-encode with menus instead of blanking/editing individual streams associated with playlists?
jidelite |
19th March 2012, 02:17 | #14864 | Link |
@Prz: You don't happen to have UAC active by any chance do you? Ifso, pretty sure that's the problem. Disable UAC, launch BDRB as admin and let it do it's thing. You can then reset UAC to it's previous position but imo i'd leave that crap off. Does more harm then good anyway
19th March 2012, 03:30 | #14865 | Link |
Three Musketeers - Full Disc Copy?
Has anybody successfully made a FULL DISC copy of "The Three Musketeers" Blu-ray? If so:
1) What version number of what program did you use? 2) Are you CERTAIN it's a proper copy and NOT one that contains 51 chapters (Pieces of each of the real 17 chapters repeated 3 times throughout)? Last edited by setarip_old; 19th March 2012 at 06:24. |
19th March 2012, 11:11 | #14866 | Link | |
usind VERSION 0.40.08 Last edited by By-Tor; 19th March 2012 at 11:13. |
19th March 2012, 15:33 | #14867 | Link | |
SlySoft says they are working on it, so maybe it is a ripping issue. BD-RB did not make a proper full backup of this title that was ripped with 7.0.2.0, even though the rip completed without any errors. However, I believe a proper movie only backup was successful choosing playlist 00437.mpls. |
19th March 2012, 23:28 | #14869 | Link | |
20th March 2012, 04:34 | #14870 | Link | |
jidelite |
20th March 2012, 10:25 | #14872 | Link | |
narnia not worked done 1st three muskerteer's worked fine done second it was anydvd hd 7.0.1.0 and have tried using 7.0.2.0 with the same results . Last edited by By-Tor; 20th March 2012 at 10:29. |
20th March 2012, 10:29 | #14873 | Link |
I've tried using 7.0.2.2. "Peer" has said it cannot be fixed at the moment, until they acquire a disc to correct the "bug" with anydvd.
20th March 2012, 12:35 | #14874 | Link | ||
So I guess changes made in 39.05 resulted in the "BD Rebuilder Experienced an error 2007 [time] CorrectEPData() 00006 2007" error. I hope this helps. Last edited by musiclover; 20th March 2012 at 13:23. |
20th March 2012, 17:34 | #14875 | Link |
Buggy When Copying Pirates 2
Okay, I've been using this software for some months now, and usually it works fine, but recently, I was making a copy of Pirates 2 and while attempting to convert to BD-25, I got the following error message:
[03/20/12] BD Rebuilder v0.40.08 (beta) [11:53:18] Source: PIRATES2 - Input BD size: 39.88 GB - Approximate total content: [03:38:30.905] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [11:53:18] PHASE ONE, Encoding - [11:53:18] Processing: VID_00001 (1 of 18) - [11:53:18] Extracting A/V streams [VID_00001] - Error in attempt to extract audio/subs. - AV frame too large (35724 bytes). Increase AV buffer. [11:58:39] - Failed to retrieve audio, aborted Since I'm NO expert on this stuff, I do not know how to increase the AV buffer. Any help would be greatly appreciated! Thanks!!! Logfile posted below: [Status] LABEL=PIRATES2 VERSION=v0.40.08 (beta) SOURCE_SIZE=42818591118 SOURCE_VIDEO_SIZE=41777516544 TARGET_SIZE=24641536000 REDUCTION=.564908194127433 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 QUICK=0 [00001] AUDIO=11000 PGS=100000 |
20th March 2012, 19:28 | #14876 | Link |
The error seems to be a tsMuxeR error (http://linkai8425.wordpress.com/2008...o-large-error/).
I have just recently begun ripping and copying Blu-rays, so this explanation is more involved than I am used to. Maybe there's an easier way to fix this problem in BD-Rebuilder - if so, I'd appreciate someone posting the fix. Thanks!!! |
21st March 2012, 06:07 | #14878 | Link |
With 40.08, Alternate MKV Intact Audio; chapters aren't being included. I'm also noticing chapters aren't being included in Movie-Only Backup, Custom Target Size. In both modes, they aren't in the Working Path directory upon TSMUXER extracting.
21st March 2012, 13:20 | #14879 | Link |
Game of Thrones Disk 5
I am having problems to make a FULL DISC copy of disk 5 from the TV Series GAME OF THRONES.
I removed all audio streams except english and removed all subtitles streams except english and spanish. BDRB gets stuck at the 31 of 42 title (at 16.99% overall progress). Had no problems at all with the first 4 blu-rays. Any suggestions? Last edited by Guest; 21st March 2012 at 13:27. Reason: rule 6 |
