8th December 2009, 14:05 | #61 | Link |
the defaults are all very well rounded at this point. i don't think i would worry about changing anything if i were you. if you would like to tweak, this really explains everything you need to know.
http://mewiki.project357.com/wiki/X264_Settings I would consider playing with crf, if you don't need to hit an exact file size. it sounds more like you just wanna keep the bitrates pretty low. The problem with using the exact same bitrate for every source is that some are going to be more complex than others. I would consider experimenting with crf values between 25-30(im just guessing,higher crf=lower bitrate), so just keep raising your crf until the video doesn't look good enough to you anymore and then stick with the highest acceptable value. |
8th December 2009, 14:13 | #62 | Link | |
now i am getting why same bitrate doesnt give better quality with diff sources. about deblocking well i guess -1:-1 gives ok results as it has been like that on all SLOWER profiles till date.. abiut the size well i try to make em small with bit rates in the range of 500 on an av for a dvd and for HD i try like 600 to 700. but yeah my friends always ask me for a smaller size possible LOL also Turbo is by default on in automated 2pass , you cant unchk it i have just noticed. |
8th December 2009, 14:18 | #63 | Link | |
First of all I want to thank you for continuing the MeGUI development. I'm now using Stable Build version of your MeGUI. The first problem that I instantly notice is that when I select "Automated 2pass" in the x264 setting, the checkbox for "Turbo" seems to be checked by default and can't be unchecked. Please advice. Last edited by nakTT; 8th December 2009 at 14:21. |
8th December 2009, 14:50 | #66 | Link |
In the Blu-ray profile the default for partitions shouldn't be --partitions all. Also, --profile high is default. In the rate control tab the values for vbv buffer and vbv max bitrate are not passed to command line.
8th December 2009, 15:13 | #67 | Link | |
the other two problems u mentioned are fixed in the development build Last edited by quantum5uicid3; 8th December 2009 at 15:16. |
8th December 2009, 15:19 | #68 | Link |
--partitions all must be supported since RipBot264 uses it for it's Bluray profile.
8th December 2009, 15:23 | #69 | Link |
the reason why it looks like you can't change the vbv options is he set it up to where anything you specify in custom commandline options overides any attempted change in the gui. so the bluray compliancy settings are essentially locked on the profile he created.
8th December 2009, 15:27 | #70 | Link | |
EDIT: Actually I read my post again and can see how you made that assumption. |
8th December 2009, 18:13 | #72 | Link |
I noticed how megui passes a parameter to neroencaac.exe that creates a fake chapters in the mp4/m4a container. If this could be fixed so it doesn't create fake chapters,it'd help muxing mp4 and uploading to youtube without using mp4box as a cli.
8th December 2009, 18:35 | #74 | Link | ||||||||
Waaah, so much postings
8th December 2009, 18:45 | #75 | Link |
Thanks - I wasn't aware of that and I'll keep it in mind. However, that works for autoencode and is helpful, but it still doesn't change the default on the main screen, which is useful when you are putting multiple items into the Queue. It would still be helpful to be able to set the default (or just have it remember last selected, either way) on the main screen.
8th December 2009, 18:54 | #76 | Link |
Dear Zathor and Quantum i have a suggestion :
you guys are so good at it and now as the thread is getting so many replies , why dont you guys gradually take over and develop megui builds which are compatible as the big guys are busy, i mean something like a full fledged patch over the latest build which takes care of the major issues. I can tell you for sure that more than 50% of megui users are suffering since the updates have stopped and since the messups have started.. it took me whole 3 days to figure it out and i am a member since 1 year .. guys please consider this , i am asking on behalf of all the affected folks. regards Glenn i am still testing the second patch of urs dear zathor which quantum has made into a consolidated exe. will revert .... |
8th December 2009, 21:08 | #78 | Link | ||
I solve this issue restart Megui again forcing the update of "STAudio" restart again Megui and finally update Tx264 & TXviD .... yes I know a little bit confused procedure but works! |
8th December 2009, 21:56 | #80 | Link | |
