Old 4th July 2016, 00:10   #1921  |  Link
Reel.Deel
Originally Posted by ultim View Post
Did you guys install the new runtime?
Yes, 1st thing I did.
Edit: the filters that have been updated to support HBD allow 16/32-bit, is there a way to specify what bit depth to use?
Reel.Deel is offline
Old 4th July 2016, 00:13   #1922  |  Link
qyot27
qyot27's Avatar
Yup, I'd had VS2015 installed for a long while too, but switched back to VS2013 once pinterf really got going and I tried testing 64-bit because Wine didn't like VS2015 binaries. But I did go ahead and install the runtime again, just in case.
And I can also reproduce with my own VS2013 builds, so VS2015 miscompiling it isn't a factor here.
qyot27 is offline
Old 4th July 2016, 00:37   #1923  |  Link
ultim
AVS+ Dev
ultim's Avatar
Fixes for the resizer corruption (it only affected some HBD formats) and XP support are on GitHub. I will publish a new build tomorrow, assuming I get a handle on the crashes, because I haven't been able to reproduce them yet. Help appreciated in making them reproducible.
AviSynth+
ultim is offline
Old 4th July 2016, 01:18   #1924  |  Link
Reel.Deel
Found something odd, If use BlankClip().TurnLeft() it works, but if I use it like the example below it gives me the access violation error.
BlankClip()
TurnLeft()
Error from AVSMeter:
Exception 0xC0000005 [STATUS_ACCESS_VIOLATION]
Module: Unknown module
Address: 0x00000001
Old 4th July 2016, 01:51   #1925  |  Link
Groucho2004
BlankClip()
TurnLeft()
Address: 0x00000001
The "Unknown module" is probably avisynth.dll but access may be restricted. Do you have UAC enabled? Run AVSMeter as admin.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 4th July 2016, 02:10   #1926  |  Link
Reel.Deel
I have UAC disabled, turned it on but it gives the same error. I was using AVSMeter 2.2.8 , update to 2.2.9 and now it gives the "AVSMeter - Avisynth Script Testing has stopped working". Here's the details:
Problem signature:
Problem Event Name: BEX
Application Name: AVSMeter.exe
Application Version: 2.2.9.0
Application Timestamp: 5776dcf1
Fault Module Name: StackHash_0a9e
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 00000001
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Without loading a script, if I right click AVSMeter.exe, run as admin I get the error above, same as without run as admin. 64-bit works fine.
Edit: works fine in Avs+ r1576 and Avs 2.6.1. Any other Avs+ version, same error. Tested all the way down to r1828.
Old 4th July 2016, 02:17   #1927  |  Link
Groucho2004
Haven't seen that before. I assume this only happens with this particular Avisynth version?
Old 4th July 2016, 02:37   #1928  |  Link
Groucho2004
So this only happens with the latest version of AVSMeter?
Old 4th July 2016, 02:38   #1929  |  Link
Reel.Deel
Correct.
Old 4th July 2016, 02:56   #1930  |  Link
Groucho2004
Unfortunately, I can't reproduce this. Could you please try this test build?
Old 4th July 2016, 03:04   #1931  |  Link
Reel.Deel
No I get the same error as in post #1931, with or without a script.
Old 4th July 2016, 03:12   #1932  |  Link
Groucho2004
So, the same as 2.2.8, right?
Old 4th July 2016, 03:29   #1933  |  Link
Reel.Deel
Yes. I reverted back to pinterf's r1858, run AVSMeter test build and now I get "bad array new length". Could this have something to do with updating to MS redistributable 2015 update 3? I see that update 2 is gone from the programs list.
Old 4th July 2016, 03:35   #1934  |  Link
Groucho2004
No idea...
The difference between AVSMeter 2.2.8 and 2.2.9 is that the new version enumerates and checks the auto-load plugins right at the start and not just when using the "-avsinfo" switch. Maybe you have a dodgy plugin. You should try with an empty auto-load directory.
Old 4th July 2016, 03:51   #1935  |  Link
Reel.Deel
No idea...
I used r1858 and the plugins included with Avs+ r2003. I downgraded to what I had (core plugins from r1825 and pinterf's recent VDub filter) and now 32-bit works with v2.2.8 again. So it must be something with the distributed plugins in ultim's r2003.
Edit: using the updated plugins from r2003, if I remove DirectShowSource.dll then 32-bit r1858 works again.
Old 4th July 2016, 04:45   #1936  |  Link
qyot27
qyot27's Avatar
The only-first-function works thing is really weird. It does 'work' if you use the . syntax, but only for the first *two* functions, the third in the . syntax then fails with an Access Violation.
Bisecting it appears to point to the merge commit fcae803fbd. git log fcae803fbd^..fcae803fbd shows that it merges in some stuff from classic's CVS from very early on in the 2.6.1 cycle, which presents some difficulty in trying to figure out which one to try and revert (and moreover, why this merge would even do anything, since the file paths are different and it should have just been the history that was merged...right?). 10e4dc50a5b seems to be the last commit prior to the merge which works like expected.
qyot27 is offline
Old 4th July 2016, 05:19   #1937  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Originally Posted by rean View Post
Do you understand the more important problem? You enter hundreds of Avisynth users to use your own non-intuitive term.
I even cannot remember this HBR DRB BDR etc. It just a letter noise. For example "Stacked" is many years well know term here.
Please write code for real users, not robots or assembly programmers. It is the most common computer software problem for API developers. They create over-complicated stuff in cases where it is not required.
When we consider that these 2 functions exist for the sole purpose of supporting Stack16 format, and Stacked implies that we're working with HBD, "ConvertToStacked" and "ConvertFromStacked" work just fine.
Just like "ConvertToShader" and "ConvertFromShader" in AviSynthShader. I switched to different names and then came back to that. What format it converts to isn't part of function name, but is rather the "format" and "lsb" arguments.
MysteryX is offline
Old 4th July 2016, 08:12   #1938  |  Link
pinterf
Uh, what a weekend!
While I was chasing Strava KOMs on my bike in the nice tailwind, ultim gave avisynth+ a tailwind, too I will look at all these merging things in the evening, but anyway, it was a good job!
pinterf is offline
Old 4th July 2016, 08:39   #1939  |  Link
fAy01
Uh, what a weekend!
Is there a point of having 4-5 different branches of avs+?
fAy01 is offline
Old 4th July 2016, 08:47   #1940  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Pinterf had to create a new branch for his new development.
Ultim has the official branch and is merging all the changes both from Pinterf and from v2.6.1 into it. That's a good thing.
Whether there's a point in having a v2.6.1 branch, an official AVS+ branch and Pinterf's dev branch is irrelevant; we have that. What matters is to merge it into an official build.
MysteryX is offline
