Old 8th April 2010, 03:42   #7401  |  Link
archaeo
Banned
archaeo's Avatar
Originally Posted by soneca View Post
I have version 3133 installed and is working very well.
With newer versions of ffdshow have had problems with other programs.
when I loaded ripbot (with ffdshow 3133 already in place), it gave me an error that said at least version 3300 had to be installed. So I uninstalled 3133, and installed 3342.
still getting error:
cannot create file X:\bluray\hurtlocker\hurt_locker_NA\BDMV\STREAM\:\temp\RipBot264temp\job1\bluray_structure_getinfo.cmd".\xxx" the filename, directory name, or volume label syntax is incorrect
archaeo is offline   Reply With Quote
Old 8th April 2010, 10:45   #7402  |  Link
mmmmdonut
Originally Posted by rocket71 View Post
Thanks! I was converting to .mp4 and did not have the Copy Stream option. I am see that option in AVCHD and am going to try to convert a movie using those settings. So far everything looks beautiful, just need to get the soundtrack right.
mp4 container can only hold AAC audio.
@archaeo why is there just a : before temp? If you modified the ini file make sure your paths are correct.
mmmmdonut is offline   Reply With Quote
Old 8th April 2010, 12:20   #7403  |  Link
rocket71
Ok, when I utilized the AVCHD setting and Copy Stream option all the audio channels are in the correct place. What is wrong with my settings that when I do a .mp4 file the audio channels are all switched up? (ie..center channel in left rear). I want to utilize the .mp4 or .mkv containers instead of AVCHD but I want the audio correct. I appreciate everyones help so far. Thanks, B
rocket71 is offline   Reply With Quote
Old 8th April 2010, 13:34   #7404  |  Link
mmmmdonut
Cant say I've had my channels out of order ( I use mp4 container all time) so not sure whats going on with your setup/encode. I assume your receiver is configured properly, ie you've done a pink noise test on each channel? Also is your test file a standard 6 channel video or you working with something that has like 3 or 4 channel audio?
Old 8th April 2010, 14:47   #7405  |  Link
@archaeo
do you have similar problem with avi, mkv , mp4 ?
@rocket71
What kind of source do you have? mp4, mkv, vob ,....
When you convert file to mp4 do you select 2.0 AAC audio or 5.1 AAC?
You must send me untouched source. Otherwise I won't be able to help.
Old 8th April 2010, 14:59   #7406  |  Link
archaeo
Banned
archaeo's Avatar
@archaeo
At work now, will check later today when I return...
Old 8th April 2010, 19:10   #7407  |  Link
archaeo
Banned
archaeo's Avatar
OK, I caught a few minutes at lunch...
So, with an mkv file:
When I click the add button and go to browse for an .mkv file, and select - I don't get anything - no error message, no file loaded. The program doesn't appear to be loading the files in either case. I just get an error when trying to load the m2ts.
I also tried another m2ts file (small, < 300Mb), and this time I got the same error message as before, but it did go into the 'select streams' window, but while there it was stuck on "please wait, analyzing..." for at least five minutes before I closed it. It never loaded that file either.
Old 8th April 2010, 19:27   #7408  |  Link
jacksback
Hi Everyone
2 things
#1 - There seems to be a bug with RipBot when converting multiple movies/episodes to CQ 18 and setting the output video size to 720p. The first file works perfectly but the 2nd one in line sends the bitrate through the roof, resulting in a flickering green coloured video.
#2 - I often made the mistake of forgetting to permanently burn the non-english speaking subtitles into the frames when converting some of my movies. Is there any way to quickly merge these external subtitle files with the video permanently without running through a full re-encode? Almost like a CQ 0 (Zero), so don't touch the frame, just merge the subtitle track where required.
jacksback is offline   Reply With Quote
Old 8th April 2010, 19:45   #7409  |  Link
@archaeo
edit ripbot264.ini
StoreTempFilesin=AUTO
change to
StoreTempFilesin=C
it must be some decoding issue. Reinstall all required components. Use latest ffshow. Also if you have 1.15.1 use this http://forum.doom9.org/showthread.ph...95#post1387495
You can mux them using mmg.exe (I assume that you are encoding to mkv)
Old 8th April 2010, 23:32   #7410  |  Link
rocket71
@archaeo
@rocket71
The source is .m2ts. When I convert it to .mp4 I am using 5.1 CT AAC-LC 256.
Here is an another attempt at splitting up a file for you to look at...I put the original in DGSplit and selected one of the 100mb segments to upload. I see it has a _13 after the file extension. I don't know how else to split it if this isn't correct. If this still isn't correct, can you point me in the direction on how to use dgsplit correctly to get you the file upload.
http://www.mediafire.com/file/zznykmf0tzj/The Day After Tomorrow.mp4_13
Also, I checked my surround setup as someone suggested and it is correct. It is only my ripbot bluray converts that are doing this. Thanks, B
Old 9th April 2010, 00:03   #7411  |  Link
Well I would need sample of .m2ts.
Old 9th April 2010, 00:17   #7412  |  Link
archaeo
Banned
archaeo's Avatar
@archaeo
edit ripbot264.ini
change to
StoreTempFilesin=C
OK, that worked to at least get the file loaded However, after it demuxed the streams, it gave me the following error:
DirectShowSource: couldn't open file C:\Temp\RipBot264temp\job1\video.mkv:
No such interface supported
(C:\Temp\RipBot264temp\job1\getinfo.avs, line 2)
avs script in temp folder is as follows:
video=DirectShowSource("C:\Temp\RipBot264temp\job1\video.mkv",audio=false).ConvertToYV12()
LoadPlugin("C:\DVD_TOOLS\m2ts to dvd\ripbot\tools\AviSynth plugins\NicAudio\NicAudio.dll")
audio=NicAC3Source("C:\Temp\RipBot264temp\job1\audio_Undetermined.ac3")
AudioDub(video,audio)
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Framecount")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Framerate")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioRate")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioChannels")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioLength")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Width")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Height ")
Trim(0,-1)
Old 9th April 2010, 02:12   #7413  |  Link
mmmmdonut
@archaeo if you using 15.1 try this: http://forum.doom9.org/showthread.ph...95#post1387495
Old 9th April 2010, 02:33   #7414  |  Link
rocket71
Here is a link to the sample of the source:
http://www.mediafire.com/?nji5nkmzymo
Old 9th April 2010, 03:18   #7415  |  Link
archaeo
Banned
archaeo's Avatar
OK yeah, that did work...
Old 9th April 2010, 06:26   #7416  |  Link
pacaveli211
Originally Posted by jacksback View Post
Hi Everyone
2 things
probably what we discussed here:
http://forum.doom9.org/showthread.ph...70#post1376670
a burn in? no. a selectable subtitle track, yes (use mkvmerge as Atak said)
pacaveli211 is offline   Reply With Quote
Old 9th April 2010, 10:57   #7417  |  Link
jacksback
Thanks, was really hoping for a burn in option. I use mkvmerge but can never get the subtitle track to automatically start when playing the movie with my NMT.
Old 9th April 2010, 14:36   #7418  |  Link
@rocket71
http://www.mediafire.com/file/kgggmmtdjzi/00001-new.mp4
When I muted all channels in ffdshow except center I heard only voice. When I muted center channel voice was switched off. Frankly everything seems to be ok.
Old 9th April 2010, 14:49   #7419  |  Link
soneca
With the 3351 version of the ffdshow problem I had is gone.
Everything working.
Old 9th April 2010, 14:54   #7420  |  Link
what problem?
