26th February 2018, 10:09 | #15561 | Link |
Looks like simple audio delay -250ms fixes a/v sync. Please verify for each movie in PREVIEW SCRIPT before encoding!
Btw. MPC-HC will crash if width is not divisible by 16 in preview script! Resize to common 1920x800.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 26th February 2018 at 10:42. |
26th February 2018, 15:08 | #15563 | Link |
There is no such thing as "updated version for threadripper". Your downloaded files are broken/corrupted. That's all.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 26th February 2018 at 15:10. |
26th February 2018, 19:10 | #15565 | Link | |
Thank you for the fix in the a/v sync. Turned out to be -500ms. Also now resizing to 1920 x 800 as well. I appreciate all your work on this great program!! |
26th February 2018, 20:40 | #15566 | Link |
Thanks for making my wishes a reality. HDR/SDR per job and no demux at job create.
Maybe just a cosmetics, I know what it means, but maybe you can rename the choices from BT.2020/BT.709 to HDR/SDR. Will be easier for novices in encoding. |
26th February 2018, 21:08 | #15567 | Link |
But I like weird numbers...
26th February 2018, 22:46 | #15568 | Link | |
Updated to newest version 1.22.2 and added a few movies using the batch mode, setting Color Pri to BT.2020. But in DE mode it encode a HDR movie in BT.709. I even tried to stop encoding and making sure its BT.2020 and still keeps encoding in BT.709. So something isnt working.
Its fubar, cant force it to use BT.2020, no matter what I choose in the color pri box its stuck at bt709. Hope you can do a quick fix for this! And no I dont have the "Force HDR to SDR Conversion..." checked under settings. Will the color pri. automatically be set to BT.2020 when a HDR movie is detected or will it also start out in BT.709 mode ? Last edited by GZZ; 26th February 2018 at 22:56. |
27th February 2018, 00:32 | #15569 | Link | |
wrong on one of your releases you said updated for ryzen/threadripper and it shows as the newest versions encode very much faster for me with my threadripper but when i tryd 1.18 all files encoded 100% perfect but with an added 2hours on each file encode time |
27th February 2018, 12:02 | #15570 | Link | |
27th February 2018, 13:21 | #15571 | Link |
It is HDR, tried several UHD movies and the symbol is on.
I know there is a few UHD movies in SDR (Stranger Things is one of them), but this is not one of them. I can upload a screenshot later today to prove it and also post the mediainfo file. One thing I also noticed and your screenshot proves it, is why does it set Color Pri to BT.709 when the HDR symbol is one, shouldnt it be default to BT.2020 when its HDR ? Last edited by GZZ; 27th February 2018 at 13:26. |
27th February 2018, 13:59 | #15572 | Link | |
My screenshot proves nothing... Just post mediainfo report. All my HDR movies/Samples have this (required) information. Code:
Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0050 cd/m2, max: 4000.0000 cd/m2 Maximum Content Light Level : 1529 cd/m2 Maximum Frame-Average Light Level : 380 cd/m2 Ps. Happy now? Code:
"C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "C:\Temp\RipBot264temp\job1\job1.avs" -strict -1 -f yuv4mpegpipe - | "C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\tools\x265\x265_x64.exe" --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)" --max-cll "1529,380" --crf 20 --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 10059 --sar 1:1 --profile main10 --output-depth 10 --y4m --output "C:\Temp\RipBot264temp\video.265" -
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th February 2018 at 14:18. |
27th February 2018, 18:49 | #15573 | Link | |
Im sorry for wasting your time. I found the issue, I had a movie added in the queue from previous version of ripbots (1.22.1) and I then updated the application and tried to encode the already added movie and that didnt work out as it should.
So after a bit more testing I ended up removing the movie and added it again and this time it worked as it should. Mediainfo on the movie: Quote:
28th February 2018, 19:02 | #15575 | Link |
ByteShare
Error while batch importing:
----------[2018-02-28 11:39:49]---------- File: C:\Dracula - Sovereign of the Damned [No Audio].mkv I don't know what 'erlace' means. (C:\Temp\RipBot264temp\job492\getinfo.avs, line 2) Code:
General Unique ID : 230681051269935516350657022109326458464 (0xAD8B8DEEC111A49E04D6F61FC0333E60) Complete name : C:\Dracula - Sovereign of the Damned [No Audio].mkv Format : Matroska Format version : Version 4 / Version 2 File size : 963 MiB Duration : 1 h 29 min Overall bit rate : 1 502 kb/s Encoded date : UTC 2018-02-28 16:06:37 Writing application : mkvmerge v20.0.0 ('I Am The Sun') 64-bit Writing library : libebml v1.3.5 + libmatroska v1.4.8 Video ID : 1 Format : MPEG-4 Visual Format profile : Simple@L1 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : V_MS/VFW/FOURCC / FMP4 Duration : 1 h 29 min Bit rate : 1 500 kb/s Width : 704 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.148 Stream size : 962 MiB (100%) Writing library : Lavc51.40.4 Default : Yes Forced : No Update: also same error with a MPEG-4 Visual (DIV3) file. Both worked after encoding them to H.264 RF0 in HandBrake Side note: moving an encode up 400 positions (not wanting to turn everything else off) is a lot of work. Some better queue management would be the last thing I think RipBot is missing IMO. Last edited by byteshare; 28th February 2018 at 19:47. Reason: more testing |
28th February 2018, 20:01 | #15576 | Link |
audio and subtitles not demuxing for .mkv files
My v1.22.2, which was recently tweaked by the Auto-update function, no longer demuxes audio or subtitle tracks when loading .mkv files.
28th February 2018, 20:14 | #15577 | Link |
@byteshare
upload job492 folder (without audio, video and subtitles)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 28th February 2018 at 20:17. |
28th February 2018, 20:15 | #15578 | Link |
See if option "SKIP DEMUXING PROCESS" is not checked.
28th February 2018, 20:24 | #15580 | Link |
Try this.
1) Check it 2) Apply 3) Uncheck it 4) Apply
