11th October 2019, 14:29 | #17461 | Link |
Grumpy Old Man.
No I haven't !!
HTPC and/or streaming doesn't suit me, I don't like the idea of having a pc running, just to watch movies.
11th October 2019, 14:44 | #17463 | Link |
Because increasing bitrate also automagically increases quality doh
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 11th October 2019 at 14:47. |
11th October 2019, 16:56 | #17464 | Link | ||
ByteShare
Sorry. Try FFMS2 or GPU decode (if applicable). The LSmash slowness issues isn't RB's fault. Quote:
Are you encoding to HEVC/x265? If so your files should be smaller and still look the same even if you're using CRF18. As pointed out, it sounds like you're doing a lot of work for just getting your TV to play a file when you wouldn't have to do all of that if you got a stand alone set-top box like an Nvida Shield TV (don't need a PC to use Plex) or Mi Box (~$50 USD). LOL |
11th October 2019, 20:45 | #17465 | Link |
According to Windows scheduler it seems that Ripbot is not able to saturate my 1950X even in distributed encoding mode.
Processor utilization fluctuates between 78-85% with any number of encodes started.Ripbot sees only Numa node 0 with 32 threads instead of 0 and 1 with 16 each. Is this the problem? Interestingly, my 2990WX is fully saturated with it's 32 cores while all 4 nodes being correctly identified by Ripbot. Any help would be appreciated. |
11th October 2019, 20:48 | #17466 | Link |
1950x by default works in Uma mode (can be changed in bios) while 2990wx only supports NUMA mode.
11th October 2019, 21:06 | #17467 | Link | |
In UMA mode my 1950x seems to be like "turtle" compared to 2990wx. Is it possible that 1950x is not correctly recognized by Ripbot? My 2990wx is recognized as "AMD-2990wx" in distributed encoding window while my 1950x is not as something like "AMD-1950x". If I change my 1950x to NUMA mode Ripbot tells it still has only one node. I am going to play with my 1950x tomorrow to find out why it is slow and cannot saturate the cores using Ripbot. |
11th October 2019, 21:09 | #17468 | Link |
Does task manager also see single node?
11th October 2019, 21:18 | #17470 | Link |
Right Click on CPU graph and select NUMA nodes.
11th October 2019, 22:15 | #17471 | Link |
Now both Windows task manager and Ripbot shows 2 nodes...sorry...I must have been drunk.
Now I am on 100% with my 1950x as well...just need to enter NUMA mode. Thank you. Last edited by mparade; 11th October 2019 at 22:18. |
11th October 2019, 22:32 | #17472 | Link |
I suppose that intensive (latency/bandwith)communication between dies prevents you from 100% CPU usage. In NUMA mode both dies work on separated data.
12th October 2019, 02:05 | #17473 | Link | |
Grumpy Old Man.
Someone provide me with some proven 4K settings to equal original video quality, at a much lower bitrate & file size !!
12th October 2019, 05:50 | #17474 | Link | |
ByteShare
I've encoded enough video to know there is no perfect settings for all videos of all types. You can get good general settings but for better results you'll need to tweak settings per video. |
12th October 2019, 06:07 | #17475 | Link | |
Grumpy Old Man.
Some, are higher, and some are lower. With some of my recent encodes I have used a 1 pass with a bitrate set @ 60,000kbp/s (in the RB setting's). Some might use a CRF (CQ) number of say 18 or 16 to get a good result. With maybe a Slow preset...I'm not using any preset's at this stage. So not knowing what your experience is with 4K movies, can you suggest a starting point ??
12th October 2019, 06:18 | #17476 | Link | |
ByteShare
It isn't clear what you're trying to do to me. If I were to guess it just seems like you want to keep the quality the same as the source, no? If you want that and aren't doing filters than I'd just use Ultra-Fast downscale a lot and then at the end copy back in the source video. If you want to keep quality close to the source but still using filters, which filters are you using? Once you're using filters it really changes things. I tend to not like grain so I reduce that with some careful settings. |
12th October 2019, 06:49 | #17477 | Link | |
Grumpy Old Man.
For what I want & need to do to audio, can be dealt with other app's, as too, the subtitles. I have to agree, I don't like grain either, but fortunately most 4K's aren't very "noisy", so not a lot of filtering required. I know I need to try a few different options, but it's the time factor that's my main concern...imagine doing a high bitrate 4K HEVC, on a Slow preset, using MDGrain2....day's even with my "farm". But the other time waster is between when the encode is completed, and the start of the next job in queue...meaning the muxing, etc...it leaves a lot of resources doing nothing. , but having said that, I am yet to test this again, after putting some SSD's in the mix. One thing I would like to get around to doing is upscaling some 1080p to 4K, but do any filtering, etc, still @ 1080p, then once satisfied, do a 4K HEVC encode, and see how it turns out. But just imagine the time & resources involved when 8K is a lot more common place.
12th October 2019, 08:07 | #17478 | Link |
I am trying to edit the font when I hardcode subtitle into my encode, but it doesn't seem to be working. I edited the notepad file in Tools\AviSynth plugins\VSFilter\Default.style with the parameters below.
Style: Default,Univers CE 45 Light,41,16777215,0,16777215,0,-1,0,2,1,2,20,20,20,0,0 what it looks like with the above settings in RipBot https://ibb.co/S7xFvpn This is what it should look like.. The resolution is not as good but trust me, the font is not accepting the setttings https://ibb.co/92VB0Xt This is the setting from srt2ssa Synch Point: Side 1 0m00s Collisions: Normal Timer: 100.0000 Style: Default,Univers CE 45 Light,41,16777215,0,16777215,0,-1,0,2,1,2,20,20,20,0,0 Why am I getting a shadow Last edited by skylinekiller; 12th October 2019 at 08:11. |
12th October 2019, 10:39 | #17479 | Link | |
I am using 4x8GB memory in quad channel layout in both. Power supply units are also powerful enough in both and both are using same type of liquid cooling. Do you have any suggestion? I would really appreciate that. Last edited by mparade; 12th October 2019 at 10:43. |
12th October 2019, 10:45 | #17480 | Link |
Normally when PC shutdowns or resets I blame power supply. Especially when shutdowns/resets happen during heavy load (high power consumption). For testing purposes I would swap power supplies 1950x<->2990wx.
