Old 5th January 2020, 22:32   #58301  |  Link
you should fix that at your display device.
Old 5th January 2020, 22:35   #58302  |  Link
WuNgUn
I'm not able to at the display...
WuNgUn is offline   Reply With Quote
Old 5th January 2020, 22:42   #58303  |  Link
WuNgUn
"Custom" size is an option when not at 60Hz...
But selecting it doesn't reveal size/position option on the TV.... Still greyed out.
At 60Hz, only factory resolution is available.
Old 5th January 2020, 23:08   #58304  |  Link
Klaus1189
The OSD looks like Samsung and there is an issue with PC mode
Go from here on:
https://forum.doom9.org/showthread.p...12#post1892212
Old 5th January 2020, 23:30   #58305  |  Link
WuNgUn
It is a Sammy, and the firmware is on 1335...newer than the update mentioned in the link you sent to avoid...
Still isn't fixed obviously.
Old 6th January 2020, 07:54   #58306  |  Link
shimarin
Especially true of NGU high and very high, NGU low is less impressive. Medium is a definite improvement over Jinc but NGU high or very high are the 'real' NGU algorithms in my opinion.
what differences do you see between medium and high?
shimarin is offline   Reply With Quote
Old 6th January 2020, 08:39   #58307  |  Link
Asmodian
Do test it for yourself, if medium looks the same to you do not pay for extra electricity and run your PC hotter only because I said I liked high or very high more.
High looks more natural and detailed, with 'naturalness' being more of an issue with NGU sharp or standard than AA but they all noticeably improve. I do use NGU AA high for chroma upscaling and AA or sharp very high for image doubling when watching 1080p -> 2160p.
madVR options explained
Old 6th January 2020, 20:32   #58308  |  Link
Alexkral
FYI, AA has the lowest PSNR, even lower than DXVA or Bilinear. It's the same with other similar metrics that account for distortion. Obviously when you compare them visually, DXVA and Bilinear are noticeably more blurry, so I don't know the reason for this.
Visually, AA is only slightly less sharp than Jinc.
Old 6th January 2020, 21:00   #58309  |  Link
you should never use DXVA for comparison for anything it can be different with driver version it is different between amd, intel and nvidia and it could be different between generations of GPUs from the same vendor.
Old 6th January 2020, 22:31   #58310  |  Link
Mano
Is there a more updated version of madshi XySubfilter?
Mano is offline   Reply With Quote
Old 7th January 2020, 02:50   #58311  |  Link
the version on git is newer:
https://github.com/Cyberbeing/xy-VSFilter/releases
Old 7th January 2020, 10:54   #58312  |  Link
oldpainlesskodi
Re the RX 5700 xt, I have to say Kodi Matrix 19.0 HDR Windows API does a great job with HDR. Not a keeper for me though, as without MadVr it's a blur fest lol. Oh well.
Sorry if off topic, but just wanted to share.
Old 7th January 2020, 12:49   #58313  |  Link
mclingo
sadly I agree, what workaround for the low SAT/BT2020 issue are you using for HDR / MADVR on your RX5700XT at the moment then?
Old 7th January 2020, 12:51   #58314  |  Link
oldpainlesskodi
Just manually using the windows HDR toggle before starting a HDR movie.
Old 7th January 2020, 12:52   #58315  |  Link
Klaus1189
I downloaded the Kodi HDR 19 rc3 because I want to test it but I don't get HDR at all and the image is very grey. Did I miss a setting that must be enabled to get HDR passthrough working?
Old 7th January 2020, 13:06   #58316  |  Link
mclingo
cool, thats you best option, yours is a pretty decent HDR TV so its worth using proper HDR.
Old 7th January 2020, 13:09   #58317  |  Link
mclingo
make usre you've got the latest version, one version didnt work, he's made quite a few recently for different python versions, I installed and tested Kodi-HDR-Edition-4.0-rc3-Python2.exe - working fine for me.
Old 7th January 2020, 14:11   #58318  |  Link
DMU
This version has been removed.
R3 3200G / Vega8 / Samsung UE40NU7100
Win11Pro 21H2 / 4K RGB 59Hz / AMD last driver
MPC-HC 1.9.17 / madVR 0.92.17 / FSW / SM / 8bit
DMU is offline   Reply With Quote
Old 7th January 2020, 14:37   #58319  |  Link
Klaus1189
I have downloaded Kodi-HDR-Edition-4.0-rc3-Python3.exe
Right, I wanted to download the Python2.exe but all versions of 4.0 rc 3 have been removed, strange
But now end here since its offtopic, probably better in a dedicated thread or does one exist already in any form?
sorry for offtopic
Old 7th January 2020, 15:13   #58320  |  Link
mclingo
here:
https://forum.kodi.tv/showthread.php?tid=345566
