18th July 2020, 18:37 | #29641 | Link |
Tested BD-RB v0.61.06
With Movie LE_MANS_66 UHD 60gig to BD50 using geforce gtx 1070 card. Worked a treat .Took about 1 hour to do .Very pleased with the result , on my oppo 203 Player , with all the menus and such . Here is the log: [07-18-20] BD Rebuilder v0.61.06 [12:27:33] Source: LE_MANS_66 - Input BD size: 60.18 GB - Approximate total content: [02:43:59.496] - Target BD size: 46.26 GB - Windows Version: 6.2 [9200] - Auto Quality: Very Good (Very Fast), ABR - X264 Tweak(s) enabled - Decoding/Frame serving: NVENCC - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [12:27:33] PHASE ONE, Encoding - [12:27:33] Processing: VID_00006 (1 of 1) - [12:27:33] Extracting A/V streams [VID_00006] - Extracting video streams [VID_00006] - Extracting audio/subtitle streams [VID_00006] - [12:33:35] Reencoding video [VID_00006] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 219,511 frames - Bitrate: 31,380 Kbs - [12:33:35] Reencoding: VID_00006, Pass 1 of 1 - [13:21:57] Video Encode complete - [13:21:57] Processing audio tracks - Track 4352 (eng): Keeping original audio - [13:21:57] Multiplexing M2TS [13:26:07]PHASE ONE complete [13:26:07]PHASE TWO - Rebuild Started - [13:26:07] Rebuilding BD file Structure [13:26:17] - Encode and Rebuild complete [13:26:17] JOB: LE_MANS_66 finished. |
18th July 2020, 21:06 | #29642 | Link | |
I'm having trouble converting UHD BDs in CQM Mode ... each one I tried so far fails on CQM prediction
Which one would you suggest for quality? Last edited by cartman0208; 18th July 2020 at 21:24. |
18th July 2020, 21:24 | #29643 | Link | |
Can you -- right after the encode fails: 1. Copy the content of LASTCMD.TXT (in the BD-RB folder) and post it here. 2. Cut and paste the command line from that file into a DOS prompt window and try to run it, and see what error it gets. Hmm... I wonder if the routine is inserting a "," instead of a "." when specifying the CQM value on the command line because of European notation for the decimal place? Thanks. Last edited by jdobbs; 18th July 2020 at 21:32. |
18th July 2020, 21:26 | #29644 | Link | |
One thing I see... since X264 isn't being used, I guess the message saying "tweaks enabled" isn't applicable and shouldn't be logged. Last edited by jdobbs; 18th July 2020 at 21:46. |
18th July 2020, 21:43 | #29645 | Link | ||
18th July 2020, 21:52 | #29646 | Link |
Ok... I see. It looks like the input file is too short for BD-RB to create a sample. I guess I never thought about that possibility when I added the new sampling method for HEVC.
There's only 1 frame in that file? I'm surprise it is even in the list to be encoded... you must have set the minimum encode length to 0, maybe? Would you mind posting the contents of your BDREBUILDER.INI file? Last edited by jdobbs; 18th July 2020 at 22:04. |
18th July 2020, 22:10 | #29647 | Link | |
[22:37:53] PHASE ONE, Encoding - [22:37:53] Processing: VID_00008 (5 of 14) - [22:38:24] Reencoding video [VID_00008] - Source Video: HEVC, 3840x2160 - Rate/Length: 24,000fps, 160.215 frames - [22:38:24] Performing CQM Prediction... - Analyzing 1,00 [22:38:28] - Failed video encode, aborted[/QUOTE] [QUOTE][Options] AC3_192=0 AC3_640=1 AC3_REENCODE=0 ALTAUTOCROP=1 ALTCRF=20 ALTMETHOD=0 ALT_CRF_TARGET=1024 ALT_TARGET=1024 ASSUME_DVD_PAL=0 AUDIO_DRC=0 AUDIO_TO_KEEP=deu;eng;ger; AUDIO_TRACK_LIMIT=1 AUTO_BURN=2 AUTO_QUALITY=0 AVCHD=1 BD25_SIZE=24500 BD50_SIZE=49000 BDMV_CERT_ONLY=0 COMPLETION_BEEP=0 CONVERT_WIDE=0 CUSTOM_TARGET_SIZE=23500 DECODER=0 DEINTERLACE=0 DTS_REENCODE=0 ENCODER=1 ENCODE_QUALITY=3 FRIMSOURCE=0 IGNORE_3D=0 IVTC_PULLDOWN=0 KEEP_HD_AUDIO=0 MODE=0 MOVIEONLY_TYPE=4 NEROAAC=0 NVENC_CAPABLE=1 ONEPASS_ENCODING=2 OPEN_GOP=0 OUTPUT_SBS=0 PGSTOSRT=0 REMOVE_OUTPUT=0 REMOVE_WORKFILES=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 SD_CONVERT=0 SD_TO_1080=0 SUBS_TO_KEEP=all SUBTITLE_TRACK_LIMIT=1 SUPTITLE=0 TARGET_SIZE=49000 USE_FILTERS=0 VERSION=0.61.0.6 MENU_BACKGROUND=U:\BD_Rebuilder\misc\menuback.jpg MENU_AUDIO=U:\BD_Rebuilder\tools\blankclip\blank.ac3 IMPORT_THRESHOLD=1 QUICK_PLAY_THRESHOLD=1 MENU_AUTO_BACKGROUND=1 MENU_AUTO_DVDAUDIO=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 IMPORT_LIMIT_LANG=0 IMPORT_KEEP_PLAYALL=0 IMPORT_PREPARE_MKV=0 [Paths] SOURCE_PATH=U:\FULLDISC\COLD_PURSUIT\ WORKING_PATH=U:\BD-OUTPUT\ DGIndexNV=U:\Tools\dgdecnv2053\x32 Binaries\DGIndexNV.exe DGDecNV=U:\Tools\dgdecnv2053\x32 Binaries\DGDecodeNV.dll Last edited by cartman0208; 24th July 2020 at 23:31. |
19th July 2020, 01:29 | #29648 | Link |
Not in the log that you posted:
[21:57:33] PHASE ONE, Encoding - [21:57:33] Processing: VID_00000 (1 of 14) - [21:57:33] Extracting A/V streams [VID_00000] - [21:57:38] Reencoding video [VID_00000] - Source Video: HEVC, 3840x2160 The 160 frames is for an entirely different M2TS (VID_00008). (5 of 14) - [22:37:53] Processing: VID_00008 (5 of 14) - [22:38:24] Reencoding video [VID_00008] - Source Video: HEVC, 3840x2160 Looking back at it now, though, it looks like even that one had over 1000 frames (I got confused by the use of "." rather than ",") Last edited by jdobbs; 19th July 2020 at 01:32. |
19th July 2020, 08:35 | #29649 | Link |
Sorry, that was the same movie, I just wanted some progress while waiting
I did the 1st vid ... when that failed, I posted that and switched to VBR When you asked for that command line, I was on the 5th vid of that movie, switched back to CQM, and posted the log... Sorry again for the confusion Should I switch regional settings on my OS? |
19th July 2020, 11:45 | #29650 | Link | ||
I set decimal separator to "." and digit grouping to "," (like here ) and now the encode runs fine in CQM mode... But I'd rather have my settings back to normal |
19th July 2020, 13:53 | #29651 | Link | |
BD-RB v0.61.07 It also adds the --repeat-headers fix when using UHD_V3_MODE=1 Also, I did some testing yesterday to compare CQM and VBR modes with NVENCC. At the same files size (bitrate) it seems that CQM gives a better SSIM. But... since the CQM prediction isn't perfect, its possible that you might have a lower file size and the better SSIM might not hold true. I'm looking at possible ways to improve prediction, or, since it's so fast -- maybe do a second CQM pass (using the first pass as the ultimate "prediction" sample). Last edited by jdobbs; 19th July 2020 at 14:00. |
19th July 2020, 14:15 | #29652 | Link |
Some time ago I found to my surprise that leaving --aq 'off' gave the best SSIM and VMAF values in CQM mode (adjusted for nearly same filesize) using NVEncC (AVC, h.264). Maybe it was specific to the source I tested and/or the --aq algo may have improved since, so don't quote me on that.....
19th July 2020, 19:07 | #29654 | Link |
CQM fails on 61.07, too:
[07.19.20] BD Rebuilder v0.61.07 [19:50:44] Source: UHD_GENTLEMEN - Input BD size: 60,94 GB - Approximate total content: [01:56:59.095] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), CQM - HEVC/V3 mode for BD disc enabled - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [19:50:46] PHASE ONE, Encoding - [19:50:46] Processing: VID_00000 (1 of 2) - [19:50:46] Extracting A/V streams [VID_00000] - [19:50:50] Reencoding video [VID_00000] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 610 frames - [19:50:50] Performing CQM Prediction... - Analyzing 1,00 [19:51:01] - Failed video encode, aborted I used a GTX 1660 for all tests. |
19th July 2020, 19:54 | #29655 | Link | |
If size is not that important to you, you may want to try with a fix quality factor rather than running the prediction, or you could try with the old prediction algo perhaps (NEW_CRF_PREDICTION=0 in the .ini). I didn't try it though. Last edited by Sharc; 19th July 2020 at 20:06. |
19th July 2020, 20:09 | #29656 | Link | |
Can you post the contents of LASTCMD.TXT (in the BD-RB folder) right after it fails? If possible, then copy the command to a DOS window and try and run it so we can see what error is occurring. Last edited by jdobbs; 19th July 2020 at 20:11. |
19th July 2020, 21:19 | #29657 | Link |
LASTCMD.TXT;
"C:\BD_Rebuilder UHD\tools\nvenc\nvencc.exe" --avhw -i "Q:\4K\WORKFILES\00000.AVS.SMPL.m2ts" --codec hevc --preset quality --profile main10 --output-depth 10 --repeat-headers --chromaloc 2 --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) --qp-min 0 --vbr 0 --vbr-quality 1 --aq-temporal --sar 1:1 --aud --pic-struct --vbv-bufsize 60000 --max-bitrate 60000 --gop-len 24 -o "Q:\4K\WORKFILES\TEMP.265" Last edited by jdobbs; 19th July 2020 at 21:30. |
19th July 2020, 22:16 | #29659 | Link | |||
I reseted my regionals back to normal and the Prediction fails on 61.07...
What I noticed ... VID_00020 only shows the copyright warning, still frame with no motion at all |
