8th April 2019, 14:49 | #4642 | Link | |
8th April 2019, 16:08 | #4643 | Link | |
13th April 2019, 20:19 | #4645 | Link | |
Source code(s) available here: http://avisynth.nl/index.php/User_talk:Asd |
13th April 2019, 22:07 | #4646 | Link |
Many thanx Reel.Deel and especially Asd (dont seem to have D9 Account) for the x64 rendition and source.
13th April 2019, 23:49 | #4647 | Link |
Why not make a github organisation to keep plugins + source code organised? Like this one https://github.com/HomeOfVapourSynthEvolution
26th April 2019, 15:30 | #4649 | Link |
I made a test script to understand the new syntax for expressions but I'm having a hard time getting a grasp of it.
In the below case, I have a different behavior when working in 16 or 8 bit. Code:
blankclip(length=1,width=700,height=480, pixel_type="YV12") ConvertBits(16) expr(" sx width / range_max * ", "","", scale_inputs = "none" ) #~ ConvertBits(8) # comment and uncomment strength = string(1.1) expr( last, " x "+strength+" scalef ^ ","","", scale_inputs = "floatf" ) edit: In case anyone's interested here's the function it works but 8b and 16b give different results (strength is not scaled correctly I think) Code:
function Vignette(clip c, float "Vignette", bool "show") { strength = string(Default(Vignette, 0.7)) show = Default(show, false) a=expr( c, " sx width 2 / - abs width 2 / / range_max * 1.5 "+strength+" 2 / + ^ range_max / 0 max ", "","", scale_inputs = "none" ) b=expr( c, " sy height 2 / - abs width 2 / / range_max * 1.5 "+strength+" 2 / + ^ range_max / 0 max ", "","", scale_inputs = "none" ) msk=expr(a,b,"x y + range_max - abs", "range_half","range_half", scale_inputs = "none" ) show ? msk : expr(msk,c,"x y * range_max / ", "y", "y", scale_inputs = "none" ) } Also, is there an internal function similar to mt_merge() for YUV? I could replicate it with expr() at some extent, only for luma, I could split planes but I don't know if there's a more elegant solution? Code:
expr(video, msk,"x z range_size - abs * y z * + range_max / ","","",scale_inputs="none") Last edited by Dogway; 26th April 2019 at 18:22. |
27th April 2019, 12:41 | #4650 | Link |
What is the difference between "https://github.com/AviSynth/AviSynthPlus/releases/download/Rel-r1576/AviSynthPlus-r1576.exe" from http://avs-plus.net/ and "https://github.com/pinterf/AviSynthPlus/releases/download/r2772-MT/AviSynthPlus-MT-r2772.exe" from https://github.com/pinterf/AviSynthPlus/releases ? Is it just one newer than the other ? Or a fork ? Thank you. |
27th April 2019, 13:07 | #4651 | Link |
avs-plus.net was just simply not updated much after a couple years. Even ultim released newer versions than r1576 (from the MT branch). pinterf's repo and releases are the current development HEAD, yes, and it is not a fork.
27th April 2019, 15:55 | #4653 | Link |
Yes, nobody should be using r1576, unfortunately Pinterf dont have control over the first post of this thread.
27th April 2019, 16:51 | #4655 | Link |
Time for a new thread or a moderator to update the first post. I think the latter is a better option.
Groucho's Avisynth Stuff |
27th April 2019, 17:07 | #4656 | Link |
Moderator update of 1st post would be repeatedly required, (and the mods are so busy as is),
Pinterf has been deliberating whether or not to open new thread (since before XMAS I think), Guess we just have to wait for the black smoke or the white smoke, to signal a decision.
27th April 2019, 17:27 | #4657 | Link |
True, didn't consider that. So, a new thread then.
27th April 2019, 17:41 | #4658 | Link | |
Broadcast Encoder
I wasn't very keen to move from Avisynth 2.6.1 myself even though I do follow Doom9 and I post here quite often, only 'cause everywhere else people were commenting about the stability issues and other severe bugs and I was so afraid to break my workflow that I kept Avisynth 2.6.1 'till 2017. (Stainless probably remembers the posts about my concerns). As a matter of fact, later on, in 2017, I found out that all these "rumors" were about the "old" Avisynth+, not the (at the time current) branch maintained by Ferenc. In fact, when I switched, it not only was faster, but it also fixed some pretty particular "bugs" (more like inconsistencies to be fair) that the legacy Avisynth had and it even allowed me to finally ditch 16bit stacked/interleaved in favor of a real 16bit, it allowed me to apply LUTs, to tone-map and to do many other things that were just not possible with the legacy Avisynth. In a nutshell, from my experience, I think that many people are misguided and end up installing the wrong/old version of Avisynth/Avisynth+ due to the lack of proper and clear documentation, which is a shame, really, for the community, so I'm totally in favor of starting a new topic and perhaps updating the Wiki and make it clear that the Ferenc's version is the only one that is still developed and that it should really be the only one to be used. Last edited by FranceBB; 27th April 2019 at 17:44. |
27th April 2019, 21:04 | #4660 | Link |
