12th September 2017, 22:01 | #26421 | Link | |
At first I didn't see such a setting. On a whim, I clicked on the automatic and opened it again and there they were. Suggestion: Have all of the settings below automatic there, but grayed out. Then, when the automatic is turned off, they are no longer grayed out (without the dialog box going away). |
12th September 2017, 22:04 | #26423 | Link | |
HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{278407C2-558C-4BED-83A0-B6FA454200BD}\InprocServer32 For a 32 bit system it is: HKEY_CLASSES_ROOT\CLSID\{278407C2-558C-4BED-83A0-B6FA454200BD}\InprocServer32 It does the same for the LAV splitter. Last edited by jdobbs; 12th September 2017 at 22:07. |
13th September 2017, 00:28 | #26424 | Link | |
Yep
C:\Program Files (x86)\LAV Filters\x86\LAVVideo.ax |
13th September 2017, 08:48 | #26425 | Link |
VFR detection incorrect
I've discovered that BDRB can handle H.264/4.2.2 videos and when the Backup is done, the recoding is done at H.264/4.2.0, which allows me to edit the files with VideoReDo.
But, I've run into an issue. The CW promo feed from 9/11 has no issues. But 24 hrs later, the CW promo feed is considered to be VFR, when in fact it is not. Both files are from the same satellite transponder, which is up 24/7. MediaInfo for the promo feed from 9/11: Code:
General ID : 1 (0x1) Complete name : G:\BD-Rebuilder\CW-promos\CW-H264-promos-170911-422.ts Format : MPEG-TS File size : 674 MiB Duration : 4mn 57s Overall bit rate mode : Variable Overall bit rate : 19.0 Mbps Movie name : Program Name Video ID : 142 (0x8E) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High 4:2:2@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : 27 Duration : 4mn 57s Bit rate mode : Constant Bit rate : 15.2 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.245 Stream size : 530 MiB (79%) Code:
General ID : 1 (0x1) Complete name : G:\BD-Rebuilder\CW-promos\CW-H264-promos-170912-422.ts Format : MPEG-TS File size : 1 000 MiB Duration : 7mn 21s Overall bit rate mode : Variable Overall bit rate : 19.0 Mbps Movie name : Program Name Video ID : 142 (0x8E) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High 4:2:2@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : 27 Duration : 7mn 21s Bit rate mode : Constant Bit rate : 15.2 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.245 Stream size : 787 MiB (79%) Code:
---------------------- [01:43:20] Importing: CW-H264-PROMOS-170911-42 - [01:43:21] Importing video file: (1 of 1) - Preparing TS for processing... - Collecting audio/video streams from source... - Converting audio, Track #2, MP2 to AC3... - Converting audio, Track #3, MP2 to AC3... - Converting audio, Track #4, MP2 to AC3... - Integrating into pseudo-BD structure... - [01:43:52] Creating Quick-Play Menu... - Encoding menu background... [01:43:58]ERROR: Failed quick menu creation. No menus. [01:43:58] Video import completed successfully. ---------------------- [09/13/17] BD Rebuilder v0.50.24 [01:44:00] Source: CW-H264-PROMOS-170911-42 - Input BD size: 0.19 GB - Approximate total content: [00:04:57.982] - Target BD size: 22.95 GB - Windows Version: 5.2 [3790] - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [01:44:06] PHASE ONE, Encoding - [01:44:06] Processing: VID_00001 (1 of 1) - [01:44:06] Extracting A/V streams [VID_00001] - [01:44:15] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 8,931 frames - Bitrate: 35,000 Kbs - [01:44:15] Reencoding: VID_00001, Pass 1 of 2 - [01:47:26] Reencoding: VID_00001, Pass 2 of 2 - [01:55:03] Video Encode complete - [01:55:03] Processing audio tracks - Track 4352 (und): Keeping original audio - [01:55:03] Multiplexing M2TS [01:55:14]PHASE ONE complete [01:55:14]PHASE TWO - Rebuild Started - [01:55:14] Rebuilding BD file Structure [01:55:17] - Encode and Rebuild complete [01:55:17] JOB: CW-H264-PROMOS-170911-42 finished. ---------------------- [02:00:42] Importing: CW-H264-PROMOS-170912-42 - [02:00:44] Importing video file: (1 of 1) - Preparing TS for processing... - Scanning for Variable Frame Rate... - Collecting audio/video streams from source... - Converting VFR source to CFR format... - Converting audio, Track #2, MP2 to AC3... - Converting audio, Track #3, MP2 to AC3... - Converting audio, Track #4, MP2 to AC3... - Integrating into pseudo-BD structure... - [02:05:26] Creating Quick-Play Menu... - Encoding menu background... - Building menu structure... [02:05:35] Video import completed successfully. ---------------------- [09/13/17] BD Rebuilder v0.50.24 [02:13:54] Source: CW-H264-PROMOS-170912-42 - Input BD size: 0.55 GB - Approximate total content: [00:07:22.843] - Target BD size: 22.95 GB - Windows Version: 5.2 [3790] - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [02:14:01] PHASE ONE, Encoding - [02:14:01] Processing: VID_00001 (1 of 1) - [02:14:01] Extracting A/V streams [VID_00001] - [02:14:21] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 59.940fps, 26,512 frames - Bitrate: 35,000 Kbs - [02:14:21] Reencoding: VID_00001, Pass 1 of 2 - [02:20:00] Reencoding: VID_00001, Pass 2 of 2 - [02:30:14] Video Encode complete - [02:30:14] Processing audio tracks - Track 4352 (und): Keeping original audio - [02:30:14] Multiplexing M2TS [02:30:30]PHASE ONE complete [02:30:30]PHASE TWO - Rebuild Started - [02:30:30] Rebuilding BD file Structure [02:30:34] - Encode and Rebuild complete [02:30:34] JOB: CW-H264-PROMOS-170912-42 finished. BTW, the filenames are getting truncated. They should end in "-422". Added: No matter what the filename is, the last character is being truncated. So filename.ts has a source name of "filenam".
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 13th September 2017 at 11:29. |
14th September 2017, 04:03 | #26426 | Link |
I wanted to go with something easier. Less SUP or SRT "complicated". So, I picked a movie I've merged only 1 SRT for. I kept the 1st Subtitle enabled.
[19:03:11] Importing MKV: BLAZING_SADDLES - Scanning for Variable Frame Rate... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [19:15:16] Video import completed successfully. ---------------------- [09/13/17] BD Rebuilder v0.50.23 [19:17:24] Source: BLAZING_SADDLES_00000 - Input BD size: 16.98 GB - Approximate total content: [01:32:51.774] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MP4, Intact Video, Intact Audio - Quality: High Quality (Default) - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448 [19:17:26] PHASE ONE, Encoding - [19:17:26] Processing: VID_00000 (1 of 1) - [19:17:26] Extracting A/V streams [VID_00000] - [19:24:00] Reencoding video [VID_00000] - [19:24:00] Keeping original video (no reencode) - [19:24:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio [19:24:00]PHASE ONE complete [19:24:00]PHASE TWO - Rebuild Started - [19:24:00] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MP4BOX) [19:24:01] - Failed to REBUILD Code:
[09/13/17] BD Rebuilder v0.50.23 [19:35:33] Source: BLAZING_SADDLES_00000 - Input BD size: 16.98 GB - Approximate total content: [01:32:51.774] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MP4, Intact Video, Intact Audio - Quality: High Quality (Default) - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448 [19:35:36] PHASE ONE, Encoding - [19:35:36] Processing: VID_00000 (1 of 1) - [19:35:36] Extracting A/V streams [VID_00000] - [19:40:20] Reencoding video [VID_00000] - [19:40:20] Keeping original video (no reencode) - [19:40:20] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio [19:40:20]PHASE ONE complete [19:40:20]PHASE TWO - Rebuild Started - [19:40:20] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MP4BOX) [19:40:20] - Failed to REBUILD Code:
[09/13/17] BD Rebuilder v0.50.23 [19:43:01] Source: BLAZING_SADDLES_00000 - Input BD size: 16.98 GB - Approximate total content: [01:32:51.774] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MP4, Intact Video, AutoGOP, Auto-AAC - Quality: High Quality (Default) - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448 [19:43:05] PHASE ONE, Encoding - [19:43:05] Processing: VID_00000 (1 of 1) - [19:43:05] Extracting A/V streams [VID_00000] - [19:47:19] Reencoding video [VID_00000] - [19:47:19] Keeping original video (no reencode) - [19:47:19] Processing audio tracks - Track 4352 (eng): Reencoding audio to AAC... - Track 4353 (eng): Reencoding audio to AAC... [19:53:50]PHASE ONE complete [19:53:50]PHASE TWO - Rebuild Started - [19:53:50] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MP4BOX) [19:53:50] - Failed to REBUILD PINFO.INF [TextSubs] 00000=ENG_0000_001.SRT ENG_0000_001.SRT is there at 71.9KB. Workfiles: Code:
00000.track_4113.vc1 00000.track_4352.ac3 00000.track_4353.ac3 00000.track_4608.sup 00000.track_4609.sup 00000.track_4610.sup AUD_00000.meta AUD_00000_4352.AAC AUD_00000_4352.AVS AUD_00000_4353.AAC AUD_00000_4353.AVS mChapters.chp MUX_MOVIE_ONLY.meta VID_00000.AVS VID_00000.CHP VID_00000.DGI
14th September 2017, 05:57 | #26427 | Link |
Ha....I had forgotten.......that MP4Box doesn't deal with VC1. Or rather, MP4 doesn't allow for VC1. Those have to be converted. Next is SUP. SUPs are ignored by MP4. Which is why every time I check a finished project Subtitles of any kind are empty. Unsure why BD-RB is converting SRT to SUP.
14th September 2017, 06:52 | #26428 | Link |
I decided to switch to MKV & import. I'm well aware that I didn't have to switch BD-RB first, but...
[22:15:17] Importing MKV: BLAZING_SADDLES - Scanning for Variable Frame Rate... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [22:27:40] Video import completed successfully. ---------------------- [09/13/17] BD Rebuilder v0.50.23 [22:31:58] Source: BLAZING_SADDLES_00000 - Input BD size: 16.98 GB - Approximate total content: [01:32:51.774] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video, Intact Audio - Quality: High Quality (Default) - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448 [22:31:58] PHASE ONE, Encoding - [22:31:58] Processing: VID_00000 (1 of 1) - [22:31:58] Extracting A/V streams [VID_00000] - [22:38:26] Reencoding video [VID_00000] - [22:38:26] Keeping original video (no reencode) - [22:38:26] Processing audio tracks - Track 4352 (eng): Keeping original audio [22:38:26]PHASE ONE complete [22:38:26]PHASE TWO - Rebuild Started - [22:38:26] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MKVMERGE) [22:38:28] - Failed to REBUILD [09/13/17] Checking System Settings - BD-Rebuilder v0.50.23 - Windows Version: 6.1 [7601] - Working Path Free Space: 144.01GB - AVISYNTH Version: 2.6.0.6, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [09/13/17] Systems Settings Check complete Code:
[09/13/17] BD Rebuilder v0.50.23 [22:42:38] Source: BLAZING_SADDLES_00000 - Input BD size: 16.98 GB - Approximate total content: [01:32:51.774] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video, Intact Audio - Quality: High Quality (Default) - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448 [22:42:41] PHASE ONE, Encoding - [22:42:41] Processing: VID_00000 (1 of 1) - [22:42:41] Extracting A/V streams [VID_00000] - [22:49:07] Reencoding video [VID_00000] - [22:49:07] Keeping original video (no reencode) - [22:49:07] Processing audio tracks - Track 4352 (eng): Keeping original audio [22:49:07]PHASE ONE complete [22:49:07]PHASE TWO - Rebuild Started - [22:49:07] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MKVMERGE) [22:49:09] - Failed to REBUILD 00000.track_4352.ac3 00000.track_4608.sup 00000.track_4609.sup 00000.track_4610.sup AUD_00000.meta AUD_00000_4352.AVS ENG_0000_001.SRT mChapters.chp MUX_MOVIE_ONLY.meta VID_00000.AVS VID_00000.CHP VID_00000.DGI None of which are empty.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 14th September 2017 at 07:01. |
14th September 2017, 17:48 | #26429 | Link |
Hellooo, hello everyone. I've switched over to MKVs for a bit since I know that accepts, or should, everything. I attempted to convert one of my MKV Movies, which the name doesn't matter, that has 2 PGS and 1 SRT. I've enabled all Subtitles in BD-RB's GUI. The output MKV only has SRT in it. I confirmed this with MKVmerge GUI and MPC-HC. Checking more files.
15th September 2017, 17:30 | #26430 | Link | |
15th September 2017, 18:03 | #26431 | Link |
I know BD-RB doesn't add them. But could have been a typo in the BD-RB code that passes the info to mkvmerge. I'm checking with a little older version of mkvmergeerge see if that "fixes" what I've noticed.
16th September 2017, 21:37 | #26434 | Link |
Not sure what to do. LAVF seems to be working ok for me. As for the VFR scanning, you might try setting IMPORT_VFR_SCAN=0 in your INI -- but it should default to "0" anyway unless it has been changed.. If, though, MEDIAINFO identifies the frame rate as "Variable" -- it will do it anyway.
16th September 2017, 22:24 | #26435 | Link | |
I thought BD-RB had been passing PGS (SUP) and SRT to MKV all along, but no. I had been converting my BD's to MKV and disc for a while, as well as importing MKVs to make BDs to get around Cinivia and other stuff. Not noticing SRT wasn't being retained but converted. OOps! Usually I'm more astute than that. Hmm.. May I sneak in *hehe hehe* a request? Mark SRTs as SRT in the GUI rather than PGS_XXX_Language? Like SRT_XXX_Language? That way we all know which is which, from beginner to advanced users?
17th September 2017, 00:52 | #26436 | Link | |
That is what my recently checking was for. To keep SRT from either within the MKV container or outside of it but have it retained and usable with MKV/MP3 alternate. I prefer within, because some of my backups have multiple SRTs.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 17th September 2017 at 00:57. |
17th September 2017, 02:30 | #26437 | Link | |
Just when is the check for LAV install done?
I can send you a small sample that you can look at. I wouldn't mind so much if the resulting file was 29.97fps interlaced, but it comes out as 59.94 fps. Each frame is duplicated. Maybe a IMPORT_VFR_SCAN=2 setting where it means do not do VFR checking under any circumstances. |
17th September 2017, 08:27 | #26440 | Link |
APPCRASH x264L-64.exe
Application x264L - 64.exe me in different parts processing falls, see error dump from window below:
Name events problem: APPCRASH Name application: x264L-64.exe Version application: 0.148.2665.0 Clock stamp application: 569d4b9b Name incorrect module: x264L-64.exe Version incorrect module: 0.148.2665.0 Clock stamp incorrect module: 569d4b9b Code exception: c000001d Shift exception: 000000000023370d Version operating system: 6.1.7601.2.1.0.256.48 ID national environment: 1033 Next information 1: 62b9 Next information 2: 62b912cee843efabb3e23eb3c2bcb8 Next information 3: 5dbb Next information 4: 5dbb00d83bfa0590eeee90fc96153e Names events problem: BEX64 Name application: x264L-64.exe Version application: 0.148.2665.0 Clock stamp application: 569d4b9b Name incorrect module: StackHash_0e6a Version incorrect module: 0.0.0.0 Clock stamp incorrect module: 00000000 Shift exception: 0000000004c4fb28 Code exception: c0000005 Data exception: 0000000000000008 Version operating system: 6.1.7601.2.1.0.256.48 ID national environment: 1033 Next information 1: 0e6a Next information 2: 0e6a129dfb5d0f7bc9ef3f6f766ce9 Next information 3: b548 Next information 4: b54816bd1dd91a75016123ca0ca639 Thank for fixed and new release. Staina |
