17th January 2016, 10:38 | #35421 | Link | |
https://dl.dropboxusercontent.com/u/...78/madvrc3.txt |
17th January 2016, 10:54 | #35423 | Link | |
Did some quick testing, as follows: - Play 3D Video = It is in 3D! - Stop and Play same file again = SBS D9 mode - Stop and Play a 2D Video = Fine - Stop and Play the 3D File = It is in 3D but playback is not advancing. I need to press Pause then Play and it then plays fine Do you want some Debug logs of this? |
17th January 2016, 11:09 | #35425 | Link | ||
Edit: You'll need a new debug build for this, with the crash bug fixed. Will upload that in 2 hours or so... |
17th January 2016, 11:14 | #35426 | Link |
Yes it is possible to grab the debug logs in this method. It's 9pm here so once I have the new build I'll generate them tomorrow and upload a pack just showing the issues. Thanks for the quick to and fro on this and fixing the crash (makes it easier to find the rest)!
edit - also I don't care about losing the first few seconds when switching modes, more that I thought the loss of HDMI signal during the switching may cause some of the issues. Last edited by jmone; 17th January 2016 at 11:29. |
17th January 2016, 11:16 | #35427 | Link | |
Another problem is if I play more than 1 hour, I will get massive frame drop in FSE. I have to pause play and switch to windowed mode wait few seconds then the frame drop gone. disable frame packing playback like SBS is the most reliable way in my system. Last edited by 4h4h270; 17th January 2016 at 12:30. |
17th January 2016, 11:44 | #35428 | Link | |
Bad news are: osd says "D3D11 windowed 3D" but video is shown in 2D. And rendertimes are higher as normal 80ms instead of 38ms. Any idea? I'm using a LG 4K passive tv. Could that be a problem? Edit: OSD says, movie resolution is 1080p and scaling to 2160p... shouldn't it be shown in 1080p 3D mode without scaling? Edit 2: My native desktop resolution is 38040x2160. It can manually change to 3D mode in nvidia control panel to 1080p(3D) mode. The my desktop is shown in 3D with 1080p resolution. If I start a 3D MVC Mkv now, madvr crashes and my tv is telling me that there is no 3D signal and changing back to 2D mode. When desktop is switching back to 3D mode, tv gets a message that there is 3D mode active again.
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64) LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set Last edited by Sunset1982; 17th January 2016 at 12:13. |
17th January 2016, 12:47 | #35429 | Link | ||||
Bug report? |
17th January 2016, 13:08 | #35430 | Link | ||
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64) LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set Last edited by Sunset1982; 17th January 2016 at 13:11. |
17th January 2016, 13:20 | #35431 | Link |
@madshi:
found the bug... the bug was me!!! forgot to write down 1080p23 mode under the display modes tab!! now 3D is working!! And the crash by selecting 1080p3D mode was, because I was manually switching to 1080p24 and not 1080p23 mode. If I select 1080p23, it works!
17th January 2016, 13:41 | #35432 | Link | |
17th January 2016, 13:46 | #35433 | Link | |
I watched Full-SBS yesterday with no issues, the only problem is the amount of GPU power consumed, my 970 could only handle Jinc3 Upscaling + Chroma sampling and ordered dithering on 2160p Full-SBS mode. Frame-packed mode seems to drain like 4x less power, and since upscaling 3D content to 4k seems near impossible frame-packed is the way, the only issue is that it's very buggy at the moment, my custom profile still has bugs when switching from 2D to frame-packed. I'll try drop a debug If i got time. |
17th January 2016, 15:32 | #35436 | Link | |
17th January 2016, 17:15 | #35437 | Link | |
Please create the logs with this new test build (contains both release and debug build, but only 32bit): http://madshi.net/madVR3dlog.rar |
17th January 2016, 17:28 | #35438 | Link | |
17th January 2016, 17:57 | #35439 | Link |
ok, created the two logfiles. hopefully if done it right.
https://www.dropbox.com/s/uql4cdtsqp...23%29.txt?dl=0 https://www.dropbox.com/s/gttyauk62f...23%29.txt?dl=0
17th January 2016, 18:07 | #35440 | Link | |
