Old 12th August 2018, 16:21   #601  |  Link
vorob
maybe thats because i'm saving via virtualdub from 2013?
vorob is offline   Reply With Quote
Old 12th August 2018, 19:40   #602  |  Link
real.finder
maybe, but post the script and sample clip
See My Avisynth Stuff
Old 12th August 2018, 19:48   #603  |  Link
We know only little about your video. May it have a height which is not at least a multiple of 4? And the whole workflow has so many variables... no details - no clue.
By the way: Get up to date, use VirtualDub2. It's superior, especially in cooperation with AviSynth+ (and VapourSynth).
Old 13th August 2018, 07:10   #604  |  Link
vorob
Looks like multithreading was wrong, instead of SetMTMode (5, 6) i had SetMTMode (4, 8).
What's the best lossless codec? With smallest size? I used Lagarith, but i dunno it's ffmpeg command.
I've got only prores one, take a look:
ffmpeg -i "Washington, Datcha.avs" -c:v prores -profile:v 3 -pix_fmt yuv422p10le "Washington, Datcha_Deint.avi"
Since I just copypasted this line from another tutorial, can you help me with underlined part? What should i put there to have Lagarithone? Prores weigh too much.
Old 13th August 2018, 07:39   #605  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
Well, Lagarith will 'weigh' much more as ProRes is lossy.
Assuming this video is from a video8 tape you might want to think hard about whether storing this as 10 bit 4:2:2 lossless isn't a bit overkill.
Cary Knoop is offline   Reply With Quote
Old 13th August 2018, 08:13   #606  |  Link
A lossless codec with good compression and wide support (both supporting different raw formats, and being supported in software with ffmpeg core) is the Ut Video Codec Suite (VideoHelp Software archive).
Old 13th August 2018, 15:15   #607  |  Link
magiblot
Eurobeat Fan
FFMpeg is unable to encode with Lagarith, but VirtualDub/2 can (although you must configure the codec within VirtualDub so that it will use YV12, YUY2 or RGB compression).
magiblot is offline   Reply With Quote
Old 13th August 2018, 16:16   #608  |  Link
StainlessS
StainlessS's Avatar
Some time ago, it kind of surprised me that Lagarith could produce considerably smaller files than UT_Video, when source has
quite a few duplicate frames, I had just assumed that UT_Video would produce null frames as Lagarith does.
EDIT:
https://forum.doom9.org/showthread.p...86#post1716986
Lossless output smaller than original :- https://forum.doom9.org/showthread.php?p=1711191
Perhaps of interest:-
https://forum.doom9.org/showthread.php?p=1719490
https://forum.doom9.org/showthread.php?p=1749940
This Lagarith Arithmetic encoder problem is later debunked as rubbish by someone well known of the D9 (Cant find it or remember who)
https://forum.doom9.org/showthread.p...40#post1768540
EDIT: Here is the big name, our very own PDR:- https://forum.doom9.org/showthread.p...72#post1812972
I sometimes post sober.
Old 19th September 2018, 01:05   #609  |  Link
Lynx_TWO
Apologies if this has been answered, but I can't find anything on it... Is there a way to run QTGMC multithreaded in Vapoursynth?
Lynx_TWO is offline   Reply With Quote
Old 19th September 2018, 01:16   #610  |  Link
poisondeathray
Yes, havsfunc
https://forum.doom9.org/showthread.php?t=166582
https://github.com/HomeOfVapourSynthEvolution/havsfunc
Old 19th September 2018, 04:21   #611  |  Link
Lynx_TWO
Perfect, thanks!
EDIT: for anyone else wanting to use StaxRip Vapoursynth with sweet multithreaded power, just open the havsfunc.py file in Notepad++ (or Notepad, but the layout will be messy) and replace all instances of
core = vs.get_core()
with the number of threads. For example, I'm rocking two 10-core Xeon E5-2630v4 CPUs, so in this case it would be
core = vs.get_core(threads=40)
Can confirm QTGMC works perfectly on this. I set x264 for Very Slow, Threads: 18, Lookahead Threads: 9, Sync Lookahead: 250.
3-4 instances encoding at once maxes out all 40 threads
Old 22nd September 2018, 07:10   #612  |  Link
Forteen88
Herr
More threads in x264 results in worse image-quality.
Forteen88 is offline   Reply With Quote
Old 27th September 2018, 10:14   #613  |  Link
Kurogane
I'm trying to use this plugin but i can't get to work.
I've installed this Core QTGMC.
C:\Program Files (x86)\AviSynth+\plugins64+\masktools2.dll  [2.2.18.0]
C:\Program Files (x86)\AviSynth+\plugins64+\mvtools2.dll  [2.7.31.0]
C:\Program Files (x86)\AviSynth+\plugins64+\nnedi3.dll  [0.9.4.51]
C:\Program Files (x86)\AviSynth+\plugins64+\RgTools.dll  [0.97.0.0]
C:\Program Files (x86)\AviSynth+\plugins64+\QTGMC.avsi  [3.358s]
C:\Program Files (x86)\AviSynth+\plugins64+\SMDegrain.avsi  [3.1.2.100s]
When i try to do a simple option as this
QTGMC(Preset="slower")
Give me this error
System execption - Illegal Instruction
C:\Program Files (x86)\AviSynth+\plugins64+\QTGMC.avsi line 879
C:\Program Files (x86)\AviSynth+\plugins64+\QTGMC.avsi line 636
What i do wrong?
Kurogane is offline   Reply With Quote
Old 27th September 2018, 10:35   #614  |  Link
pinterf
Give me this error
What i do wrong?
Problematic line:
	interp = (InputType == 1)            ? Input : \
	         (EdiMode == "NNEDI3")       ? Input.NNEDI3( field=-2, nsize=NNSize, nns=NNeurons, qual=EdiQual, threads=EdiThreads, U=CEed,V=CEed ) : \
	         (EdiMode == "NNEDI2")       ? Input.NNEDI2( field=-2, nsize=NNeurons, qual=EdiQual, threads=EdiThreads, U=CEed,V=CEed ) : \
	         (EdiMode == "NNEDI")        ? Input.NNEDI( field=-2, U=CEed,V=CEed ) : \
	         (EdiMode == "EEDI3+NNEDI3") ? Input.EEDI3( field=-2, mdis=EdiMaxD, threads=EdiThreads, U=CEed,V=CEed, \
		                                                sclip=Input.NNEDI3( field=-2, nsize=NNSize, nns=NNeurons, qual=EdiQual, threads=EdiThreads, U=CEed,V=CEed ) ) : \
	         (EdiMode == "EEDI3")        ? Input.EEDI3( field=-2, mdis=EdiMaxD, threads=EdiThreads, U=CEed,V=CEed ) : \
	         (EdiMode == "EEDI2")        ? Input.SeparateFields().EEDI2( field=-2, maxd=EdiMaxD ) : \
	         (EdiMode == "Yadif")        ? isyuy2(Input) ? Input.nonyuy2clipin(true).Yadifmod2( mode=3 ).nonyuy2clipout(true) : Input.Yadifmod2( mode=3 ) : \
	         (EdiMode == "cYadif")       ? Input.Yadif( mode=3 ) : \
	         (EdiMode == "TDeint")       ? Input.TDeInt( mode=1 ) : \
	         (EdiMode == "RepYadif")     ? isyuy2(Input) ? Repair( Input.nonyuy2clipin(true).Yadifmod2( mode=3 ), default( Fallback, Input.QTGMC_Bob( 0,0.5 ) ).nonyuy2clipin(true), 2, 0 ).nonyuy2clipout(true) : \
	         (EdiMode == "RepcYadif")    ? isyuy2(Input) ? Repair( Input.Yadif( mode=3 ).nonyuy2clipin(true), default( Fallback, Input.QTGMC_Bob( 0,0.5 ) ).nonyuy2clipin(true), 2, 0 ).nonyuy2clipout(true) : \
	         	         	                       Repair( Input.Yadif( mode=3 ), default( Fallback, Input.QTGMC_Bob( 0,0.5 ) ), 2, 0 ) : \
Since for "slower" NNEDI3 is used, probably the crash occurs in that module. You'll need to specify your exact processor type for the solution (which I suppose will be a bugfix)
pinterf is offline   Reply With Quote
Old 27th September 2018, 18:36   #615  |  Link
Kurogane
But happens in all presets from Very Fast to Placebo.
I've i7-4930K
Old 27th September 2018, 20:23   #616  |  Link
Groucho2004
I've i7-4930K
Which of the nnedi3 DLLs from the package are you using?
Groucho's Avisynth Stuff
Old 27th September 2018, 20:53   #617  |  Link
Kurogane
Originally Posted by groucho2004 View Post
which of the nnedi3 dlls from the package are you using?
w7 avx2
Old 27th September 2018, 20:57   #618  |  Link
And does your CPU support AVX2 at all? Which CPU do you have exactly?
Old 27th September 2018, 21:03   #619  |  Link
Kurogane
w7 avx2
Oh i thought my processor support AVX2 when search again i saw its was AVX, My bad.
Old 20th October 2018, 12:56   #620  |  Link
DeafYakuza
This is my first question that I'm asking.
I have some problems with QTGMC V3.34 with Avisynth 2.6.
Can someone maybe help me what it means?
TemporalSoften: Scenechange not available on RGB32
(QTGMC.avsi. line 413)
I installed that as following like here: https://forum.doom9.org/showthread.php?t=156028
But the problem didn't be solved.
What I want to do with that. I want deintalace a video. It's an avi (UT Video Codec).
SetMemoryMax(512)
AVISource("myvideo.avi")
QTGMC(Preset="Slower", SourceMatch=3, Lossless=2, EdiThreads=1)
SelectEven()
I am grateful for your support.
DeafYakuza is offline   Reply With Quote
