2nd May 2018, 08:10 | #50541 | Link |
In the latest Win10 there is a new power plan in Windows Power Settings called "Bitsum Highest performance" - might be worth checking our for those with issues using MadVr after upgrading.
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema |
2nd May 2018, 08:21 | #50543 | Link |
Under Control Panel\Hardware and Sound\Power Options there is a new power setting, as I mentioned above, and it may or may not help.
2nd May 2018, 08:30 | #50544 | Link | |
2nd May 2018, 08:39 | #50546 | Link |
If you read my signature, do you see a laptop?
2nd May 2018, 08:48 | #50548 | Link |
Is this for real?
Ok I lowered the queue sizes down to 8, and yes that helped. I only dropped 3 frames when I opened the file now. But as you see in this image, the render queue and present queue is still very low. Something is wrong or has changed.
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED |
2nd May 2018, 08:49 | #50549 | Link | |
Is this for real?
Edit : The frames are not only dropping in the beginning, they are dropping during the entire episode.
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED Last edited by Betroz; 2nd May 2018 at 09:00. |
2nd May 2018, 09:10 | #50552 | Link | |
K
2nd May 2018, 09:56 | #50554 | Link | |
try the old back buffer presentation by disabling "present several frames in advance". |
2nd May 2018, 10:03 | #50555 | Link |
Do you honestly believe they change something about custom resolutions in every new driver that breaks it in new and fancy ways? Because I'm pretty sure they don't, because its likely a feature they just don't care about whatsoever. Its probably just not fully understood under which conditions it works right now, making you believe it breaks with different drivers again and again.
2nd May 2018, 10:13 | #50556 | Link | |
Is this for real?
My point is that the 1803 update changed something. What I do not know. The fact that I can't use the same MadVr settings now that worked before kind of proves that. And as I said, I did a clean install aswell. Could it be that BIOS and OS fixes for Meltdown and Spectre vulnerabilities is the culpit here?
2nd May 2018, 10:31 | #50557 | Link | |
All I can say is i think there is a long standing bug that has been reported on the Nvidia forums (i've only just found out), that if you use Nvidia Colour Settings, both full and limited range are borked, and regardless of what setting I use on my display its wrong. However, I have used CRU to create a custom 23.976 at 12bit, then choose Use Default Colour Settings, and Voila, perfect render chain at Full>Full>Full RGB at 12bit with one repeated frame every several hours (which will do me). I really don't know who to kick - me or Nvidia! I have disabled all Windows Updates, and certainly Nvidia (sticking with 397.40), as now I am extremely happy, at last.
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema Last edited by oldpainlesskodi; 2nd May 2018 at 11:05. Reason: Typo |
2nd May 2018, 10:36 | #50558 | Link | |
and they do nothing for normal user and most important are part of older windows updates. |
2nd May 2018, 10:41 | #50559 | Link |
That doesn't seem right, I also have the BIOS and OS fixes for Meltdown and Spectre.
Did you turn the Windows game bar/game mode off again? I am on 1803, 397.31, madVR v0.92.14 both 64 and 32 bit. MPC-HC and Zoom Player. Skylake X. edit: I notice my composition rate is 23.976 while your's is 23.970. That is odd.
madVR options explained Last edited by Asmodian; 2nd May 2018 at 10:45. |
2nd May 2018, 10:52 | #50560 | Link |
Is this for real?
I know, but the CPU feeds data to the GPU...
Maybe Madshi knows if Microsoft did any changes to Direct3D with the 1803 build.
