Old 9th June 2020, 14:53   #21  |  Link
stax76
stax76's Avatar
A little "special" for a console tool
The documentation doesn't explain this well btw.
Old 9th June 2020, 16:01   #22  |  Link
Groucho2004
Yes it is.
That page merely gives a rough overview of the switches. The documentation is included in the distro. However, I'll probably "verbosify" this switch a bit.
Groucho's Avisynth Stuff
Old 9th June 2020, 22:25   #23  |  Link
crystalfunky
@crystalfunky
I have enabled MCTempDenoise and opened the preview in staxrip, after that I started an application called Process Explorer and clicked on the search toolbar button, in the search field I entered gpu and clicked enter, this showed me that the staxrip process has successfully loaded a DLL named FFT3dGPU.dll.
This means it's working here and the problem is specific to your machine, this DLL has gpu in its name which implies it could be a missing GPU driver or hardware, or it could be a dependency.
Ok I did what you did.
After enabling the filter in staxrip I clicked on preview and got the same error that the module cannot be found.
Searched in process explorer for gpu and the program couldn't find anything.
I'm using a Radeon RX 460 with current drivers.
Do I need to install anything besides Staxrip and all the apps that are required by Staxrip (e.g. Avisynth, Visual C++, etc.), which will be installed automatically?
@Groucho
Tried your method. I attached the log.
I checked with avsmeter. Will the program give me any errors?
crystalfunky is offline   Reply With Quote
Old 10th June 2020, 07:52   #24  |  Link
Groucho2004
Originally Posted by crystalfunky View Post
@Groucho
It looks as if you did not use the "-c" switch. Anyway, according to stax, each plugin resides in its own directory which would make checking with AVSMeter rather cumbersome.
You can still use the second option I pointed out in post #12:
Run the script with AVSMeter ("AVSMeter script.avs -lf) and post the created log file.
Old 10th June 2020, 08:44   #25  |  Link
crystalfunky
When I try to use the autoload script file "MCTemporalDenoise.avsi" renamed to avs at the end, with the command -lf then avsmeter tells me "invalid switch in this context: -lf"
I tried the -c command already and checked the MCTempDenoise folder, as well as the FFt3dGPU folder. Thats why I asked if the program will give me anything (errors, etc.), because it somehow just checked and gave me nearly nothing at the end.
Edit: Did everything again with your method. I hope it's all there now.
Old 10th June 2020, 09:15   #26  |  Link
Groucho2004
The "-lf" was a typo, sorry about that. You simply run "AVSMeter script.avs -log". I don't know why you would rename "MCTemporalDenoise.avsi" and run that. You're supposed to run the script that staxrip created.
Old 10th June 2020, 10:46   #27  |  Link
crystalfunky
ok, it just gave me the same error, which staxrip already gave me.
The module cannot be found (error 126). FFt3dgpu.dll
Edit: Just tried the whole thing on my laptop and I get the same error.
So either I'm missing something, or the problem is not my doing but in the program.
Used: Staxrip 2.1.1.2
Old 10th June 2020, 11:29   #28  |  Link
Groucho2004
I'll let stax take over from here, I don't know that gui at all. Still, can you post the script?
Old 12th June 2020, 08:13   #29  |  Link
crystalfunky
Hat to rename the file from .avs to .txt
Old 12th June 2020, 22:34   #30  |  Link
crystalfunky
Ok so it's getting interesting. I looked in the readme from FFT3dGPU folder. There was something about Dx9, so I installed that on my Windows 10 system.
It got me a new error in Staxrip 2.1.3.0 though. The last one (Error 126, file cannot be found) was gone.
The new one says: This is not an YV12 clip. Please convert to YV12 colorspace.
How the heck am I suppose to do that? It's a normal HDR 4K clip. The mediainfo says that it's YUV and 4:2:0 (Type 2).
If you know something guys, I would really appreciate your help.
Old 12th June 2020, 23:02   #31  |  Link
crystalfunky
I guess this doesn't make sense any more.
I would delete this thread, since my original question is another.
