11th August 2010, 02:45 | #1421 | Link |
4 Movies crashed in audio conversion.
<2010-08-10 20:45:35> START PROCESS <> <2010-08-10 20:45:35> PROJECT SETTINGS DVD Video Standard: NTSC DVD Titles number: 1 DVD Size: 4450/4450 MB (100%) DVD Output Setup: DVD Folder DVD Label: TOUT_UN_PAPA DVD Menu: No Menu Output Folder: E:\DVD-TEMP Delete Temp Process Files: Yes Delete Working Files: Yes Edit Command Parameters: No Post Process Task: Show Progress Status window PREFERENCES AVS Source Filter: DirectShowSource AVS UpSize/DownSize Filter: Lanczos4Resize/Spline36Resize Video Resolution: 0 Video BitRate Min: 3000 Video BitRate Level 1: 8500 Video Profile Level 2: 8500 Video BitRate Max: 9000 Keep DVD Compliant Video: 1 AC3 Audio Encoder: 0 PAL SpeedUp: 0 DVD Audio Format: 0 DVD Audio BitRate: 448 Keep DVD Compliant Audio: 1 Normalize Audio: 0 DVD Audio Language: FR - French DVD Subs Language: FR - French DVD Subs Font: Tahoma 18pt Bold Chapters Interval: 5 Use Source Chapters: 1 DVD Burning Drive: F: HL-DT-ST DVDRAM GH22NS50 TN02 DVD Burning Speed: 4x Auto Erase DVD RW: 1 Save Log file: 1 Save General Settings: 0 Unload ActiveMovie library: 0 Adjust ffdshow mixer: 1 <> <2010-08-10 20:45:35> TITLE 1 SOURCE FILES Video: E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts Info: AVC - 5606 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:38:40 hours - 141959 frames Audio 1: E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts Info: AC3 - 384 kbps - CBR - 6ch - 48000Hz - 1:38:32 hours - Internal Subs: [MediaInfoLib - v0.7.32] <> <2010-08-10 20:45:35> AVISYNTH SCRIPT Video = DirectShowSource("E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts", fps=23.976, audio=false) # Audio is frameserved by AviSynth just for Preview and Edit purposes. Audio = DirectShowSource("E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts", video=false) Video = Video.ConvertToYV12 #Using DGPulldown/HCenc to upsize FPS Video = Video.Spline36Resize(720,480) AudioDub(Video, Audio) <> <2010-08-10 20:45:35> START VIDEO ENCODING OPERATIONS Encoding Profile: HCenc VBR 2-pass Target Video FileSize: 4083.3 MB HCenc Parameters: -ini "E:\Temp\TOUT_UN_PAPA_4_TOUT_UN_PAPA.HCenc.ini" HCenc ini file: *INFILE E:\Temp\TOUT_UN_PAPA_4_TOUT_UN_PAPA_1.avs *AVSRELOAD *OUTFILE E:\DVD-TEMP\TOUT_UN_PAPA_4_TOUT_UN_PAPA.m2v *LOGFILE E:\Temp\TOUT_UN_PAPA_4_TOUT_UN_PAPA.HCenc.log *MAXBITRATE 9000 *BITRATE 5785 *PROFILE BEST *ASPECT 16:9 *PROGRESSIVE *TFF *PULLDOWN *BIAS 60 *DC_PREC 9 *MATRIX MPEG *AQ 1 *LUMGAIN 1 *SMP *PRIORITY IDLE *WAIT 2 <> <2010-08-10 21:33:59> END VIDEO ENCODING OPERATIONS Created File: E:\DVD-TEMP\TOUT_UN_PAPA_4_TOUT_UN_PAPA.m2v (4083.6 MB) OUTPUT VIDEO INFO: MPEG-2 Video - 5827 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:38:40 hours - 141958 frames <> <2010-08-10 21:33:59> START AUDIO DEMUXING OPERATIONS (Track 1) FFmpeg Parameters: -i "E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts" -acodec copy "E:\DVD-TEMP\TOUT_UN_PAPA_4_TOUT_UN_PAPA_1.ToFix.ac3" <> <2010-08-10 21:34:00> Problems encountered during Title 1 AUDIO encoding operations. START (BACKUP) AUDIO ENCODING OPERATIONS (Track 1) FFmpeg Parameters: -i "E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts" -map 0:1 -y -vn -ac 6 -ar 48000 -ab 384k "E:\DVD-TEMP\TOUT_UN_PAPA_4_TOUT_UN_PAPA_1.ac3" <> <2010-08-10 21:42:54> PROCESS ABORTED DURING TITLE 1 AUDIO (TRACK 1) ENCODING OPERATIONS. CHECK LOG FILE <E:\DVD-TEMP\TOUT_UN_PAPA_4.LOG> FOR MORE INFO. <> <2010-08-10 21:42:54> Log file created by AVStoDVD Release 2.3.1 <> Code:
<2010-08-10 14:17:29> START PROCESS <> <2010-08-10 14:17:29> PROJECT SETTINGS DVD Video Standard: NTSC DVD Titles number: 1 DVD Size: 4450/4450 MB (100%) DVD Output Setup: DVD Folder DVD Label: THIRST DVD Menu: No Menu Output Folder: E:\DVD-TEMP Delete Temp Process Files: Yes Delete Working Files: Yes Edit Command Parameters: No Post Process Task: Show Progress Status window PREFERENCES AVS Source Filter: DirectShowSource AVS UpSize/DownSize Filter: Lanczos4Resize/Spline36Resize Video Resolution: 0 Video BitRate Min: 2500 Video BitRate Level 1: 8500 Video Profile Level 2: 4000 Video BitRate Max: 8500 Keep DVD Compliant Video: 1 AC3 Audio Encoder: 0 PAL SpeedUp: 0 DVD Audio Format: 0 DVD Audio BitRate: 448 Keep DVD Compliant Audio: 1 Normalize Audio: 0 DVD Audio Language: FR - French DVD Subs Language: FR - French DVD Subs Font: Tahoma 18pt Bold Chapters Interval: 5 Use Source Chapters: 1 DVD Burning Drive: F: SONY DVD RW DRU-V200S 1.60 DVD Burning Speed: 4x Auto Erase DVD RW: 1 Save Log file: 1 Save General Settings: 0 Unload ActiveMovie library: 0 Adjust ffdshow mixer: 1 <> <2010-08-10 14:17:29> TITLE 1 SOURCE FILES Video: E:\BLURAY\Thrist FRENCH DTS 720P F DVD9.AVCHD\BDMV\STREAM\00000.m2ts Info: AVC - 6600 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:14:06 hours - 192930 frames Audio 1: E:\BLURAY\Thrist FRENCH DTS 720P F DVD9.AVCHD\BDMV\STREAM\00000.m2ts Info: DTS - 1536 kbps - CBR - 6ch - 48000Hz - 24bit - 2:14:06 hours - Internal Subs: [MediaInfoLib - v0.7.32] <> <2010-08-10 14:17:29> AVISYNTH SCRIPT Video = DirectShowSource("E:\BLURAY\Thrist FRENCH DTS 720P F DVD9.AVCHD\BDMV\STREAM\00000.m2ts", fps=23.976, audio=false) Audio = DirectShowSource("E:\BLURAY\Thrist FRENCH DTS 720P F DVD9.AVCHD\BDMV\STREAM\00000.m2ts", video=false) Video = Video.ConvertToYV12 #Using DGPulldown/HCenc to upsize FPS Video = Video.Spline36Resize(720,480) AudioDub(Video, Audio) <> <2010-08-10 14:17:29> START VIDEO ENCODING OPERATIONS Encoding Profile: HCenc VBR 1-pass Target Video FileSize: 3898.5 MB HCenc Parameters: -ini "E:\Temp\THIRST_0_THIRST.HCenc.ini" HCenc ini file: *INFILE E:\Temp\THIRST_0_THIRST_1.avs *AVSRELOAD *OUTFILE E:\DVD-TEMP\THIRST_0_THIRST.m2v *LOGFILE E:\Temp\THIRST_0_THIRST.HCenc.log *MAXBITRATE 9000 *1PASS *BITRATE 4064 *PROFILE BEST *ASPECT 16:9 *PROGRESSIVE *TFF *PULLDOWN *BIAS 40 *DC_PREC 9 *MATRIX MPEG *AQ 1 *LUMGAIN 1 *SMP *PRIORITY IDLE *WAIT 2 <> <2010-08-10 15:45:30> END VIDEO ENCODING OPERATIONS Created File: E:\DVD-TEMP\THIRST_0_THIRST.m2v (3909.7 MB) OUTPUT VIDEO INFO: MPEG-2 Video - 4102 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:14:06 hours - 192929 frames <> <2010-08-10 15:45:30> START AUDIO ENCODING OPERATIONS (Track 1) Wavi+Aften Parameters: "E:\Temp\THIRST_0_THIRST_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "E:\DVD-TEMP\THIRST_0_THIRST_1.ac3" <> <2010-08-10 17:48:54> Problems encountered during Title 1 AUDIO encoding operations. START (BACKUP) AUDIO ENCODING OPERATIONS (Track 1) QuEnc (AC3) Parameters: -i "E:\Temp\THIRST_0_THIRST_1.avs" -o "E:\DVD-TEMP\THIRST_0_THIRST_1.ac3" -priority 5 -1 -nohq -novbr -mpeg2mux novideo -audiocodec ac3 -audiobitrate 448 -auto -close <> <2010-08-10 18:05:50> END AUDIO ENCODING OPERATIONS (Track 1) Created File: E:\DVD-TEMP\THIRST_0_THIRST_1.ac3 (429.7 MB) OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 2:14:06 hours <> <2010-08-10 18:05:50> START DVD AUTHORING OPERATIONS BatchMux Parameters: -arglist "E:\Temp\THIRST_0_BatchMux.ini" BatchMux ini file: -d "E:\DVD-TEMP\THIRST_0\VIDEO_TS" -mxp "E:\Temp\THIRST_0_MuxMan.mxp" -l "E:\Temp\THIRST_0_MuxMan.log" -muxman "C:\Program Files (x86)\AVStoDVD\MuxMan" -prio LOW -v "E:\DVD-TEMP\THIRST_0_THIRST.m2v" -vidmode LB -a1 "E:\DVD-TEMP\THIRST_0_THIRST_1.ac3" -a1lang fr -cellfr "E:\Temp\THIRST_0_THIRST_MuxMan.txt" -progfr "E:\Temp\THIRST_0_THIRST_MuxMan.txt" -chapfr "E:\Temp\THIRST_0_THIRST_MuxMan.txt" <> <2010-08-10 18:13:18> CHECK DVD SIZE DVD Folder (actual) Size: 4438.1 MB vs Estimated Size: 4450 MB -> 0.3% undersize vs Assets Size: 4339.5 MB -> OK <> <2010-08-10 18:13:18> END DVD AUTHORING OPERATIONS Created Folder: E:\DVD-TEMP\THIRST_0 (4438.1 MB) <> <2010-08-10 18:13:19> Log file created by AVStoDVD Release 2.3.1 <>
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 11th August 2010 at 05:07. |
11th August 2010, 12:46 | #1423 | Link |
AVStoDVD Dev
But log files are 2... and only first has failed...
BTW in the first one project, FFmpeg has both refused to demux the AC3 track and to encode it (as backup routine). I would suggest to run the m2ts thru TsRemux and fix it or extract the required video/audio streams. Bye |
11th August 2010, 12:47 | #1424 | Link | |
AVStoDVD Dev
Bye |
11th August 2010, 13:47 | #1425 | Link |
Not following..sorry for the ignorance. I'm converting a MKV with 5.1 DTS audio. I'm pretty sure DTS is allowed (compliant) . Iv'e checked and unchecked the box for adjust ffdshow mixer, but it still takes my 6 channel down to 2 channel.
11th August 2010, 16:44 | #1426 | Link | |
AVStoDVD Dev
2. Mixer: have you installed AC3Filter too, other than ffdshow? If yes, uninstall it. 3. What is your operating system? If W7, than install Preferred Filter Tweaker and select ffdshow as AC3 decoder. 4. Post the project log file Bye |
11th August 2010, 16:57 | #1427 | Link | |||
Thanks! |
11th August 2010, 19:41 | #1430 | Link |
AVStoDVD Dev
Thus the remaining option is to setup both AC3Filter and ffdshow mixer as 5+1 output.
(I have no W7 system, so I can only quote other AVStoDVD+W7 users experience in this thread or outside Doom9). Bye Last edited by MrC; 11th August 2010 at 19:44. |
12th August 2010, 22:33 | #1431 | Link | |
How does we fix an m2ts? Did txmuserGUI has a settings to check for errors? Thanks!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
13th August 2010, 16:39 | #1433 | Link |
Could someone please assist me in getting 6 channel audio from a 6 channel audio source?
I've tried the Win7Tweaker, no AC3 option. I have AC3 installed, but have watched the toolbar during the audio encoding phase (FFMpeg) and AC3 is not loaded I have went into FDSHOW Audio Encoder, mixer and tried same as input and 3/0/2 option..still 2 channel. Also, after the AVSto DVD process, if I go BACK and check FFDSHOW audio encoder options..it's back to 2/0/0 in the mixer option...even after changing it prior. A screenshot of what I'm supposed to do would help. I'm running Win7 TIA |
13th August 2010, 21:28 | #1434 | Link |
AVStoDVD crashing
Hi MrC,
I don't know if it has been reported earlier but version 2.31 crashes on my W7 64bit when I enable the checkbox "Use External player" on the Paths tab in preferences I get an error Run-Time Error '5': Invalid procedure call or argument. BTW Works fine on my other machine with XP SP3 ggtop Last edited by ggtop; 13th August 2010 at 21:52. |
14th August 2010, 12:42 | #1435 | Link | |
AVStoDVD Dev
Please follow these steps: - Uninstall AC3Filter and any other AC3 directshow decoder other than ffdshow - Open AVStoDVD - Make sure that 'Preferences'/'Misc'/'Adjust ffdshow Mixer Output at runtime' is on - Setup your AVStoDVD project - Make sure that 'Title Edit'/'Audio'/'Channels Mode' is '5.1' (it should be, if input title has 5+1 audio) - Run the project - Copy and paste here the project log file Bye |
14th August 2010, 12:52 | #1436 | Link | |
AVStoDVD Dev
That routine checks if the reg key: Code:
HKEY_LOCAL_MACHINE\SOFTWARE\Gabest\Media Player Classic\ExePath Code:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\AVIFile\shell\open\command Bye |
14th August 2010, 14:46 | #1438 | Link |
AVStoDVD Dev
No ini file, but there is a reg key for AVStoDVD as well
HKEY_LOCAL_MACHINE\SOFTWARE\AVStoDVD Or you can simply select the 'Previewer Player Path' using the form 'Preferences'/'Paths' and then 'Save current Preferences as default' Bye P.S. your HKEY_LOCAL_MACHINE\SOFTWARE\Gabest\Media Player Classic\ExePath string is with or without ""? |
