Old 16th January 2021, 10:09   #18861  |  Link
What happens if use untouched recording in de mode? Try also remuxing in mkvtoolnix your edited MKV file.
Old 16th January 2021, 15:34   #18862  |  Link
Ryushin
Ryushin's Avatar
Show me your custom script
Variations of MDegrain with a different thSAD failue. Here is one:
#Denoise MDegrain2 Modified
Loadplugin("C:\Program Files\RipBot264\Tools\AviSynth plugins\mvtools\mvtools2.dll")
super=MSuper(video,pel=2)
bv1=MAnalyse(super,blksize=8,isb=true,delta=1,overlap=4)
bv2=MAnalyse(super,blksize=8,isb=true,delta=2,overlap=4)
fv1=MAnalyse(super,blksize=8,isb=false,delta=1,overlap=4)
fv2=MAnalyse(super,blksize=8,isb=false,delta=2,overlap=4)
video=MDegrain2(video,super,bv1,fv1,bv2,fv2,thSAD=200)
Old 16th January 2021, 15:36   #18863  |  Link
change to
#Denoise
Do not put extra text in marker's line
Old 16th January 2021, 15:47   #18864  |  Link
Ryushin
Ryushin's Avatar
Originally Posted by Pauly Dunne View Post
When I read your post, I knew that someone else had a very similar issue a couple of months back...
https://forum.doom9.org/showthread.p...93#post1927793 (post #18735, also #18725))
See if that helps (it did for me).
That looks like my problem. I'll modify all my scripts to make sure there is a #Custom marker.
Thanks Pauly and Atak.
Old 17th January 2021, 02:29   #18865  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Excellent
Live every day like it's your last, because one day, it will be !! (M$B)
Old 17th January 2021, 02:34   #18866  |  Link
Pauly Dunne
Grumpy Old Man.
OK, untouched is worse (see attached) https://www.mediafire.com/file/j4zcq...+file.jpg/file
Also a screenshot of another file from the same "set" (see attached) https://www.mediafire.com/file/r0ygk...eries.jpg/file
That first screenshot I sent (other post) WAS thru mkvtoolnix
However, if I run them thru Handbrake, they are fine, in DE..
Old 17th January 2021, 10:43   #18867  |  Link
Will you be ale to send original file? Trimmed 200MiB should be enough.
Old 17th January 2021, 10:46   #18868  |  Link
Pauly Dunne
Grumpy Old Man.
I was wondering if you were going to ask for that...
The original is just over 600mb (rar'ed up), not sure what to trim it with, that might affect it's problem...
Let me know what you'd prefer...
Old 17th January 2021, 12:04   #18869  |  Link
If you have fast upload speed then send whole 600MiB to Mediafire.
Old 17th January 2021, 12:43   #18870  |  Link
Pauly Dunne
Grumpy Old Man.
I don't, but I will post the whole thing..
Will send you a link, when it's ready.
Old 17th January 2021, 13:03   #18871  |  Link
slalom
slalom's Avatar
What about this error, when I set the KNLMeansC1
the path is correct
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
Old 17th January 2021, 13:21   #18872  |  Link
Pauly Dunne
Grumpy Old Man.
the path is correct
Hi, so the fresh setup didn't help !!!
I mentioned to you in FB Messenger that I loaded a job, and enabled those filters, and it worked ok.
Hopefully Atak will have an answer...
Old 17th January 2021, 13:24   #18873  |  Link
Pauly Dunne
Grumpy Old Man.
OK, here ya go...didn't take too long to upload
https://www.mediafire.com/file/xy2t8.../Ep_4.rar/file
I just hope that it has the same errors for you, as it did for me...
Old 17th January 2021, 14:15   #18874  |  Link
the path is correct
Incorrect AviSynth+ version? EncodingServer.exe shows what AviSynth version you have installed at the bottom field.
Old 17th January 2021, 14:40   #18875  |  Link
That file is ultra weird because decoder sees ONLY one key-frame for whole file!
example from video.mkv.lwi
<LSMASHWorksIndexVersion=0.0.2.0>
<LibavReaderIndexFile=16>
<InputFilePath>C:\Temp\RipBot264temp\job2\video.mkv</InputFilePath>
<FileSize=625585425>
<FileHash=0x65d6f4a4>
<LibavReaderIndex=0x00000000,0,matroska,webm>
<ActiveVideoStreamIndex>+0000000000</ActiveVideoStreamIndex>
<ActiveAudioStreamIndex>-0000000002</ActiveAudioStreamIndex>
<StreamInfo=0,0>
Codec=27,TimeBase=1/1000,Width=720,Height=576,Format=yuv420p,ColorSpace=2
</StreamInfo>
Index=0,POS=362,PTS=0,DTS=-9223372036854775808,EDI=0
Key=1,Pic=1,POC=0,Repeat=1,Field=1
Index=0,POS=9479,PTS=120,DTS=0,EDI=0
Key=0,Pic=2,POC=6,Repeat=1,Field=1
Index=0,POS=10636,PTS=40,DTS=40,EDI=0
Key=0,Pic=3,POC=2,Repeat=1,Field=1
Index=0,POS=10781,PTS=80,DTS=80,EDI=0
Key=0,Pic=3,POC=4,Repeat=1,Field=1
Index=0,POS=10924,PTS=240,DTS=120,EDI=0
Key=0,Pic=2,POC=12,Repeat=1,Field=1
Index=0,POS=12324,PTS=160,DTS=160,EDI=0
Key=0,Pic=3,POC=8,Repeat=1,Field=1
Index=0,POS=12478,PTS=200,DTS=200,EDI=0
Key=0,Pic=3,POC=10,Repeat=1,Field=1
Index=0,POS=12657,PTS=360,DTS=240,EDI=0
Key=0,Pic=2,POC=18,Repeat=1,Field=1
Index=0,POS=13920,PTS=280,DTS=280,EDI=0
Key=0,Pic=3,POC=14,Repeat=1,Field=1
Index=0,POS=14070,PTS=320,DTS=320,EDI=0
Key=0,Pic=3,POC=16,Repeat=1,Field=1
Index=0,POS=14263,PTS=480,DTS=360,EDI=0
Key=0,Pic=2,POC=24,Repeat=1,Field=1
Index=0,POS=15419,PTS=400,DTS=400,EDI=0
Key=0,Pic=3,POC=20,Repeat=1,Field=1
Index=0,POS=15562,PTS=440,DTS=440,EDI=0
Key=0,Pic=3,POC=22,Repeat=1,Field=1
Index=0,POS=15735,PTS=600,DTS=480,EDI=0
Key=0,Pic=1,POC=30,Repeat=1,Field=1
Index=0,POS=24816,PTS=520,DTS=520,EDI=0
Key=0,Pic=3,POC=26,Repeat=1,Field=1
Index=0,POS=24976,PTS=560,DTS=560,EDI=0
Key=0,Pic=3,POC=28,Repeat=1,Field=1
Index=0,POS=25164,PTS=720,DTS=600,EDI=0
Key=0,Pic=2,POC=36,Repeat=1,Field=1
Index=0,POS=26479,PTS=640,DTS=640,EDI=0
Key=0,Pic=3,POC=32,Repeat=1,Field=1
Index=0,POS=26656,PTS=680,DTS=680,EDI=0
Key=0,Pic=3,POC=34,Repeat=1,Field=1
Index=0,POS=26843,PTS=840,DTS=720,EDI=0
Key=0,Pic=2,POC=42,Repeat=1,Field=1
Index=0,POS=28110,PTS=760,DTS=760,EDI=0
Key=0,Pic=3,POC=38,Repeat=1,Field=1
Index=0,POS=28274,PTS=800,DTS=800,EDI=0
Old 18th January 2021, 02:02   #18876  |  Link
Pauly Dunne
Grumpy Old Man.
OK, so all that doesn't really mean a lot to me...
So let me try and get my head around this....the "decoder", which is Lsmash, correct ??, isn't "seeing everything" ??.
So before you implemented Lsmash into RB, was it FFMPEG that was used ??
Can that still be used ??
It seems strange that RB's decoder has this problem with this type of file (and unfortunately I have a LOT of them), BUT Handbrake doesn't (not knowing what decoder HB uses).
It would be nice NOT having to use HB, it just adds another step to the process, although there are a couple of advantages.
Anyway, do you have any suggestions ?? or do I just carry on with the current workflow ??
Cheers & thanks again.
Old 18th January 2021, 02:06   #18877  |  Link
Pauly Dunne
Grumpy Old Man.
the path is correct
Hi, again,
Just found the latest version of Avisynth...go and grab it
https://github.com/AviSynth/AviSynthPlus/releases
If you're unsure of which to download, pick AviSynthPlus_3.7.0_20210111_vcredist.exe
Old 18th January 2021, 02:30   #18878  |  Link
Pauly Dunne
Grumpy Old Man.
Update's
Atak,
I've found a few "important" updates :-
Avisynth 3.7.0 as in above post #18877
FFMPEG 20210106 https://ottverse.com/ffmpeg-builds/
L-Smash 12.12.2020 https://cloud.owncube.com/s/MXk3zBcZfNkrGF9
L-Smash 16.12.2020 https://cloud.owncube.com/s/C8SBjF53JTL7s73
https://forum.doom9.org/showthread.p...62#post1930562
also x265, 3.4+36 http://msystem.waw.pl/x265/
and x264, r3033 https://artifacts.videolan.org/x264/release-win64/
Old 18th January 2021, 08:50   #18879  |  Link
KNLMeansCL also had an update for compatibility with recent AviSynth+ versions by pinterf: https://github.com/pinterf/KNLMeansCL/releases
Old 18th January 2021, 13:43   #18880  |  Link
Ryushin
Ryushin's Avatar
Light MDGrain2
I wanted to give an example of what light MDegrain2 (thSAD value) can do for some files.
This is with Hickok (2017) 4K (Original source size of video is 50GB). Settings used CQ18 x265:
No MDegrain: 12.80GB
thSAD=100: 8.98GB
thSAD=150: 5.45GB
thSAD=200: 4.51GB
This is all relative to the video. I suspect the film is recorded with a digital camera and there is very light grain structure. Then MDegrain can remove just this light grain and then it cleans up beautifully. Hard to believe the file with thSAD=200 is less than 1/10 it's original size
I think it would be good to add an adjustable thSAD value to the UI.
I had not mentioned this in the past, but for those that use MDegrain3, you should be aware of something I've noticed over the last couple of years. The temporal function of MDegrain3 uses three frames and this can lead to some odd looking results. For example, what I've found, depending on the movie, if the camera is still and someone turns their face, the skin texture will smooth out during the turn and then the texture returns when they stop moving. Just something to be aware of. I don't use MDegrain3 very often and I'm more reluctant to do so now since I've been noticing this. The size difference from MD2 compared to MD3 is not that great. For example, 22GB vs 25GB. For super grainy sources, MD3 still the way to go.
