Old 20th May 2009, 15:13   #21  |  Link
clsid
Same commands, but now split into two separate steps. First change owner, then adjust permissions.
MPC-HC 2.2.1
Old 20th May 2009, 15:16   #22  |  Link
Something like this ?
SetACL.exe -ot reg -on "HKLM\Software\Microsoft\DirectShow\Preferred" -actn setowner -ownr "n:Administrators;s:n"
SetACL.exe -actn ace -ace "n:Administrators;p:read,full;s:n;i:io,so;m:grant;w:dacl" -rec yes
Old 20th May 2009, 15:32   #23  |  Link
clsid
Second command must also specify the key name. Also, I have used 'm:set' instead of 'm:grant'.
MPC-HC 2.2.1
Old 20th May 2009, 15:37   #24  |  Link
Do I have to use 64bit SetACL.exe for 64bit OS?
Old 20th May 2009, 15:45   #25  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Now I get this error message when trying to use Win7DSFilterTweaker_0.4 on Win7 x86.
Keiyakusha is offline   Reply With Quote
Old 20th May 2009, 15:54   #26  |  Link
clsid
You need to use both.
Is caused by a typo. I will upload a fixed version in a moment.
MPC-HC 2.2.1
Old 20th May 2009, 16:45   #27  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
clsid
Just tried Tweaker 0.5, and... Finally, it works for me! Thanks for this great tool ^_^
Old 21st May 2009, 13:50   #28  |  Link
@clsid
I think that it's time to combine this tool with ffdshow installer.
Old 22nd May 2009, 00:41   #29  |  Link
zachdms
As someone who loves stability, this kind of thing frightens me.
I would suspect that if you tried to stabilize your architecture, someone would always find a way to introduce ways to destabilize it. Your "great cause" now is someone else's "uh oh whoops" three months from now.
speaking for myself only
zachdms is offline   Reply With Quote
Old 22nd May 2009, 13:41   #30  |  Link
clsid
Well, the tool can easily restore all settings to their defaults. So all changes that a user choses to make can be reverted.
MPC-HC 2.2.1
Old 25th May 2009, 13:18   #31  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
As someone who loves life, cars frighten me. I would suspect that if you tried to live, someone would always find a way to introduce ways to kill you. Your "great cause" now is someone else's "uh oh whoops" three months from now.
... Life can kill you, you know
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
Old 1st June 2009, 11:51   #32  |  Link
mr.duck
quack quack
Errrr all I get with version 0.5 is a list with the only option for every single codec is "Microsoft". I sure have more options than that installed. DScaler5 for MPEG2 for a start. I'm on Windows 7 64 bit.
mr.duck is offline   Reply With Quote
Old 1st June 2009, 12:24   #33  |  Link
clsid
As you can read in the opening post, it only detects a few third party filters. DScaler5 is not yet on that list. I will add it in a future version. If you have more request, let me know.
In case of ffdshow, the tool also actually checks if a format is enabled in ffdshow options, before it is displayed as a choice in the tool.
MPC-HC 2.2.1
Old 1st June 2009, 12:53   #34  |  Link
mr.duck
quack quack
Ya must add DScaler5 support since it's the best quality MPEG2 decoder and it's free
I just noticed that the cyberlink mpeg2 decoder I have installed isn't picked up either.
Old 1st June 2009, 14:26   #35  |  Link
clsid
New version can be found in first post.
MPC-HC 2.2.1
Old 1st June 2009, 16:02   #36  |  Link
mr.duck
quack quack
Both DScaler5 and Cyberlink are showing up now so seems to be working, thanks.
Old 1st June 2009, 19:04   #37  |  Link
Brazil2
Thanks for the addition of Dscaler5
Arcsoft video decoder for both H264 and VC1 please
Brazil2 is offline   Reply With Quote
Old 1st June 2009, 19:23   #38  |  Link
clsid
Could you give me the clsid values for those Arcsoft filters? That is all I need to know to be able to add them.
Edit:
I found value {B793E9A8-C53E-4845-9DE9-C32326EACCAD} belonging to ASVid.ax. Please confirm if that is the decoder you meant.
MPC-HC 2.2.1
Old 1st June 2009, 20:28   #39  |  Link
Brazil2
Confirmed:
Display name: ArcSoft Video Decoder
File name: ASVid.ax
CLSID: {B793E9A8-C53E-4845-9DE9-C32326EACCAD}
Media types: MPEG1, MPEG2, DVSD, H264, VC1, MPEG4 ASP.
Full list:
Media Types: 30
Type: 0
 MajorType: FourCC:vids MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
  MinorType: KSDATAFORMAT_SUBTYPE_MPEG2_VIDEO {E06D8026-DB46-11CF-B4D1-00805F6CBBEA}
Type: 1
 MajorType: KSDATAFORMAT_TYPE_MPEG2_PES {E06D8020-DB46-11CF-B4D1-00805F6CBBEA}
Type: 2
 MajorType: KSDATAFORMAT_TYPE_STANDARD_PACK_HEADER {36523B13-8EE5-11D1-8CA3-0060B057664A}
Type: 3
 MajorType: KSDATAFORMAT_TYPE_DVD_ENCRYPTED_PACK {ED0B916A-044D-11D1-AA78-00C04FC31D60}
Type: 4
  MinorType: KSDATAFORMAT_SUBTYPE_MPEG1Packet {E436EB80-524F-11CE-9F53-0020AF0BA770}
Type: 5
  MinorType: KSDATAFORMAT_SUBTYPE_MPEG1Payload {E436EB81-524F-11CE-9F53-0020AF0BA770}
Type: 6
 MajorType: KSDATAFORMAT_TYPE_STREAM {E436EB83-524F-11CE-9F53-0020AF0BA770}
  MinorType: KSDATAFORMAT_SUBTYPE_MPEG1Video {E436EB86-524F-11CE-9F53-0020AF0BA770}
Type: 7
  MinorType: FourCC:dvsd MEDIASUBTYPE_dvsd_ {64737664-0000-0010-8000-00AA00389B71}
Type: 8
  MinorType: FourCC:DVSD MEDIASUBTYPE_DVSD {44535644-0000-0010-8000-00AA00389B71}
Type: 9
Type: 10
Type: 11
  MinorType: FourCC:H264 {34363248-0000-0010-8000-00AA00389B71}
Type: 12
  MinorType: FourCC:h264 {34363268-0000-0010-8000-00AA00389B71}
Type: 13
  MinorType: FourCC:X264 {34363258-0000-0010-8000-00AA00389B71}
Type: 14
  MinorType: FourCC:x264 {34363278-0000-0010-8000-00AA00389B71}
Type: 15
  MinorType: FourCC:AVC1 {31435641-0000-0010-8000-00AA00389B71}
Type: 16
  MinorType: FourCC:avc1 {31637661-0000-0010-8000-00AA00389B71}
Type: 17
  MinorType: {5B64102C-0CB7-47E6-8EB1-8EF806CCCB3C}
Type: 18
  MinorType: {8D2D71CB-243F-45E3-B2D8-5FD7967EC09B}
Type: 19
  MinorType: {6F29D2AD-E130-45AA-B42F-F623AD354A90}
Type: 20
  MinorType: {DDF4B57D-C1D7-4595-A34B-56A2255E5E0F}
Type: 21
  MinorType: {629B40AD-AD74-4EF4-A985-F0C8D92E5ECA}
Type: 22
  MinorType: FourCC:xvid {64697678-0000-0010-8000-00AA00389B71}
Type: 23
  MinorType: FourCC:XVID {44495658-0000-0010-8000-00AA00389B71}
Type: 24
  MinorType: FourCC:divx {78766964-0000-0010-8000-00AA00389B71}
Type: 25
  MinorType: FourCC:DIVX {58564944-0000-0010-8000-00AA00389B71}
Type: 26
  MinorType: FourCC:dx50 {30357864-0000-0010-8000-00AA00389B71}
Type: 27
  MinorType: FourCC:DX50 {30355844-0000-0010-8000-00AA00389B71}
Type: 28
  MinorType: FourCC:mp4v {7634706D-0000-0010-8000-00AA00389B71}
Type: 29
  MinorType: FourCC:MP4V {5634504D-0000-0010-8000-00AA00389B71}
----- Pin 1 ------
Flags: Output:0 ZeroInst:0 Renderer:0 ManyInst:0
Instances: 0
Media Types: 3
Type: 0
  MinorType: KSDATAFORMAT_SUBTYPE_SUBPICTURE {E06D802D-DB46-11CF-B4D1-00805F6CBBEA}
Type: 1
Type: 2
----- Pin 2 ------
Flags: Output:1 ZeroInst:0 Renderer:0 ManyInst:0
Instances: 0
Media Types: 8
Type: 0
  MinorType: FourCC:YUY2 MEDIASUBTYPE_YUY2 {32595559-0000-0010-8000-00AA00389B71}
Type: 1
  MinorType: FourCC:YV12 MEDIASUBTYPE_YV12 {32315659-0000-0010-8000-00AA00389B71}
Type: 2
  MinorType: FourCC:UYVY MEDIASUBTYPE_UYVY {59565955-0000-0010-8000-00AA00389B71}
Type: 3
  MinorType: DDPF_RGB32 {E436EB7E-524F-11CE-9F53-0020AF0BA770}
Type: 4
  MinorType: DDPF_RGB24 {E436EB7D-524F-11CE-9F53-0020AF0BA770}
Type: 5
  MinorType: DDPF_RGB565 {E436EB7B-524F-11CE-9F53-0020AF0BA770}
Type: 6
  MinorType: DDPF_RGB555 {E436EB7C-524F-11CE-9F53-0020AF0BA770}
Type: 7
  MinorType: DDPF_ARGB32 {773C9AC0-3274-11D0-B724-00AA006C1A01}
----- Pin 3 ------
Instances: 0
Media Types: 3
Type: 0
 MajorType: KSDATAFORMAT_TYPE_AUXLine21Data {670AEA80-3A82-11D0-B79B-00AA003767A7}
  MinorType: KSDATAFORMAT_SUBTYPE_Line21_GOPPacket {6E8D4A23-310C-11D0-B79A-00AA003767A7}
Type: 1
  MinorType: FourCC:TVCC {43435654-0000-0010-8000-00AA00389B71}
Type: 2
  MinorType: {A793C893-B525-4E56-9FD9-6C7A9E2CC103}
Old 1st June 2009, 21:53   #40  |  Link
clsid
Added
MPC-HC 2.2.1
